Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 31st July 2007, 13:26   #1 (permalink)
2fast4u's Avatar
Default CPU Config suggestions
i have gone thru the ongoing pc configs discussion and am alot confused on which processor, what motherboard etc. etc
I have a samsung 210T with speakers and now on the lookout for a good cpu
i am looking for moderate usage home pc with windows xp, more of children games (not hitech gaming), mp3, photos and anything more that i should look at suggestions welcome.
pls suggest me whether to go for branded stuff, if yes then the brand with model number or if assembled then
1) which processor
2) motherboard
3) hard disk capacity
4) cd / dvd burner (for good music / movies)
5) how much ram
6) speed
7) whether to go for bluetooth connectivity
8) what all would i need like USB, firewire etc.
9) graphics card for Dvi output
10) any further suggestions
as i would like to have a neat config with a moderate budget pls suggest in a way that i can get it between 15 to 20k
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 31st July 2007, 13:44   #2 (permalink)
xinome's Avatar
15 to 20 k
and not hightech
ok got the perfect config
Amd Athlon 64 bit 939 pin 3200+ or 3500+
MSI K8NGM2 ( its got everything you require )
Sony dvr rw
all this will cost you a mear 12000 rupees
__________________
I meant what I said and I said what I meant. "
बूम शाकालाका बेबी
xinome is offline   Reply With Quote
Old 31st July 2007, 17:51   #3 (permalink)
Amey's Avatar
1) which processor ---> AMD Athlon 64 X2 4000+ = 4k
2) motherboard ----> Asus M2N-MX = 3.8k
3) hard disk capacity------> 160GB SATAII = ~ 2.5k
4) cd / dvd burner (for good music / movies) -----> LG H44N = 1.4k
5) how much ram -----2GB DDR2 667MHz = 3.8k
6) speed
7) whether to go for bluetooth connectivity----Helps if you have BT handset
8) what all would i need like USB, firewire etc.---There are plenty of USB ports on the motherboard, No firewire though.
9) graphics card for Dvi output ------> Nvidia 6200LE if you are not a gamer = 2k max.
10) any further suggestions---> Dont forget a good PSU.People tend to neglect it.Preferably go for Powersafe 500W. = 2.2k or so
I hope that helps you.
Amey is offline   Reply With Quote
Old 31st July 2007, 18:07   #4 (permalink)
2fast4u's Avatar
thanks xinome & amey
one more question whats the amd equivalent to against intel
and should i go for intel if offered.
__________________
636
RB20DET NISSAN
Old 31st July 2007, 19:40   #5 (permalink)
low_bass_makker's Avatar
6) speed
Just get a bigger Hdd thats all as 320 GB is for 3.2k. For firewire get a add one card will be for .5k , for power supply there is a cooler master 380 watts for 1k. which will be more than enough for your application.
Intel is faster than AMD but it is cheaper than the same. here is a simple average comparison of speeds. as you are going to use it is a media centre , AMD 4000+ X2 is more than enough as you are never going to use it full potential never.
low_bass_makker is online now   Reply With Quote
Old 1st August 2007, 10:43   #6 (permalink)
Amey's Avatar
For intel, you can think of Intel Pentium E2140/E2160 which are based on the Core architecture, same as all Core 2 Duo and Core 2 Quad ones. They are cheap, run extremely cool, very cheap.
Any of the 2 models mentioned above coupled with a 945G or 946 chipset based Asus/Intel motherboard.
Old 1st August 2007, 12:13   #7 (permalink)
2fast4u's Avatar
thanks for the info LBM & Amey very helpful will let u know what i finally get.
__________________
636
RB20DET NISSAN
Old 1st August 2007, 23:25   #8 (permalink)
devarshi84's Avatar
Intel C2D 64-bit cpu
Asus Chipset
Nvidia-ATI DX10 GPU
capacity depends on your needs
2gb is bare minimum for vista (make sure its Dual-channel DDRII)
rest all is upto you. price will go around 35-45
__________________
boyracer.blogspot.com
devarshi84 is offline   Reply With Quote
Old 2nd August 2007, 00:29   #9 (permalink)
Asus Chipset
Nvidia-ATI DX10 GPU
the C2D is a 32-bit processor not a 64 bit. It can emulates it as 64-bit.
and I dont think he need so powerfull config. A AMD dual core can do a fantastic job.
Old 2nd August 2007, 02:46   #10 (permalink)
reignofchaos's Avatar
Naa Core 2 duo is native 64bit. Atleast it runs 64bit software properly and runs it faster than any AMD chip out there. How it does internally, no clue!
reignofchaos is online now   Reply With Quote
Old 2nd August 2007, 06:53   #11 (permalink)
goldsun's Avatar
I have recently gone for CPU upgrade for Rs. 22K and the config is ...
- Intel Core2 duo E6320 (1.86 GHz)
- 120 GB SATA HDD
- 2 GB RAM
- DVD RW
- Intel DG965RY Mother board (With onboard Audio, Graphics, LAN, etc)
- Casing with SMPS
and it is performing far better than my previous Pentium IV 2.8 GHz.
__________________
Have a pleasant and safe driving
goldsun is offline   Reply With Quote
Old 2nd August 2007, 07:22   #12 (permalink)
BIKeINSTEIN's Avatar
If you plan to overclock and AMD based then
1) which processor> AMD AM2 X2 3600+ 1.9Ghz Brisbane- 3k max
2) motherboard > Jetway 692GDG 3K or lower or Asus M2N-MX- 3k odd
3) hard disk capacity> 160GB Hitachi SataII- 2.2k or lower and the bare min imho
4) cd / dvd burner (for good music / movies)> LiteOn 20A1P/S or Sony AWG170S
5) how much ram- Kingston 2x1GB DDR2 667- 3.7k odd
6) speed< ???????????????????
7) whether to go for bluetooth connectivity- a usb bluetooth dongle for 300 bucks and upwards should do the job
8) what all would i need like USB, firewire etc.- mobos thes days have 8-10 USB ports, Firewire if u strictly need FW- USB 2.0 is quite fast
9) graphics card for Dvi output- both mobos above have built in onboard gfx for mild low level gaming
10) any further suggestions> get a good psu- a cheap but effective powersafe 500W is the bare minimum imho
BIKeINSTEIN is offline   Reply With Quote
Old 2nd August 2007, 07:35   #13 (permalink)
For intels- i second this- for a cheap and nice rig.
These new intel babies Overclock a lot too iirc.
So a better motherboard will take care of that but add to expenses as the cheapest decent OCer mobo is the XFX 650i at 5.5k odd.
a cheap gfx card like the 6200LE/TC or 7100GS(almost akin to amd onboard gfx in performance) will another 2-2.5k more.:(
edit:
The AMD X2 3600+ can be easily run at 2.4Ghz with slight tweaks- maybe someone can help you with it in case u need help.
The Jetway mobo has decent enough gfx with DVI out onboard.
For dvi input in other mobos, you will need a dedicated gfx card like the 6200/LE/TC, 7100GS and higher models.
Old 2nd August 2007, 07:39   #14 (permalink)
for a little more expensive setup that doesnt compromise on performance much when not overclocking will be the intel core2duo chips 4300/4400- 5-6k
and the XFX 650i mobo and a budget gfx card.:P
Old 2nd August 2007, 22:54   #15 (permalink)
msdivy's Avatar
I want to upgrade my home PC. I want to just replace the mainboard & CPU. But I really don't know what to with existing mainboard (Kobian P4M266) & CPU (Pentium 4 1.5G). Any suggestion on how to dispose:
1. Working computer components.
2. Non-working computer components.
EDIT: I also have 17" CRT which I want to replace with 17" LCD. Again no idea what to do with CRT monitor.
msdivy is offline   Reply With Quote
Thread Tools
CPU usage for Windows explore,check this ECM Shifting gears 4 11th December 2006 12:20
My config for comp.. good?? barbar Gadgets, Computers & Software 26 3rd July 2006 20:59
ICE config for Palio amitverma Ask the Gurus 6 10th May 2006 12:42
Proposed Audio Config.. allajunaki Ask the Gurus 38 31st August 2005 23:44
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
