Old 1st August 2007, 10:47   #1
Thanked: 116 Times
Default Help needed - Desktop conked
Yesterday I got a cable broadband connection from Hathway. The installer laid the cable and installed a software (some 24Online client) on my desktop.
After that my desktop which runs Windows XP - SP2 began to reboot after running for 2-3 minutes. Once I got an error related to IP address, I couldn't read it completely since the machine again re-booted.
That was the last time machine booted. After that I tried booting it in Win XP - Safe Mode and in Kubuntu 6.0. But kept on hanging, and never booted.
I tried to boot it through Kubuntu DVD but that too didn't work, it hanged again. I tried re-installing Windows-XP; it starts well, but at a point when the installation says - "Starting Windows XP" it again hangs. I even tried after disabling the on-board LAN card, but even then the same problems.
Now I don't know what to do with my desktop, I am not able to even re-install any OS on it, and effectively it's useless now.
Gurus, help me out. Tell what can be the possible cause and what to do?
P.S. I installed the same software (24Online client) on my laptop running Windows Vista - Home Premium and it's working fine.
Nitin
ntomer is offline   Reply With Quote
Old 1st August 2007, 11:15   #2
tsk1979's Avatar
Thanked: 15,682 Times
Did you try booting using a Live CD, like knoppix?
While bootup take note of all the kernel messages which come up.
On first look it appears to be a hardware failure, but it also could be boot area corruption.
Old 1st August 2007, 12:01   #3
Thanked: 116 Times
I tried booting using the Kubuntu 6.0 Live DVD but even that hangs after sometime, it is not able to load completely.
What possible hardware failure can occur due to broadband installation. All that guy did was changing the IP of my machine and installed a software. Any idea how can I diagnose it?
Nitin
Old 1st August 2007, 13:52   #4
cypher's Avatar
My 2 cents -
If the Kubuntu CD is also not booting, it could be a hardware issue that cropped up during the install.
Check if the CPU fan is in place. I've experienced a similar problem with my system rebooting when the CPU fan failed, and the processor was overheating.
The next thing I would do is take out the HDD, plug it into a external USB housing and backup ALL the data.
cypher is offline   Reply With Quote
Old 1st August 2007, 16:56   #5
xbox360's Avatar
Thanked: 76 Times
I had installed 24Online client for my broadband on my desktop and my laptop at home. Both machines kept crashing and blue screening frequently. Tried everything and finally on my IT desk's request uninstalled the 24Online client and things have worked like a charm ever since (I moved over to BSNL Broadband as well).
The seemingly innocuous 24Online messes a lot with the registry and drivers.
xbox360 is offline   Reply With Quote
Old 1st August 2007, 19:51   #6
toiingg's Avatar
Thanked: 73 Times
I have been using the same 24Online software for about 2 years now and haven't faced any problems.
Seems to me to be a HDD crash.
Can you boot in Dos mode and access your C drive? Or just plug in your HDD into some other PC and see if you can access all your files.
toiingg is offline   Reply With Quote
Old 2nd August 2007, 14:56   #7
Thanked: 116 Times
To un-install the 24Online client, I need to boot-up the machine :-(
Catch-22
Old 2nd August 2007, 17:37   #8
ashwin390's Avatar
This seems to be a good idea.
Boot up problems can be generally classified into two categories - Issues with BIOS, in which case you will not even see the Windows XP start-up screen. The other option is a problem with your hard disk. Especially, with your boot sectors - if these have been damaged, you system will generally crash at boot-up, when the system tries to access data from these sectors.
In your case, you seem to be facing the second issue. What you can do is, back up all your data on another HDD using another system. Then, if your system / HDD is still in warranty, you can get a free replacement of your HDD.
ashwin390 is offline   Reply With Quote
Old 2nd August 2007, 18:07   #9
Thanked: 294 Times
I think while putting the lan cable something in the PC has misplaced...hmm try cleaning the inside of the PC by removing the cover...remove the RAM, and other card if there and reconnect them and then try again....
Old 2nd August 2007, 18:11   #10
merve_extreme's Avatar
Thanked: 12 Times
Did you format your C drive during XP reinstall?
Secondly did you try booting into Kbuntu by removing the cable attached to the LAN.I believe this is a live boot DVD so a corrupted partition is not an issue.If you havent done this try it.
merve_extreme is offline   Reply With Quote
Old 2nd August 2007, 18:51   #11
Thanked: 116 Times
I am not reaching the stage where it asks to format the drive. Computer hangs before that.
I disconnected the cable and even disabled the on-board LAN but it made no difference.
\N
Old 2nd August 2007, 19:10   #12
jkdas's Avatar
Thanked: 1,419 Times
unplug all external devices before you (or anyone) do an installation.
Try recovery console.
run chkdsk /p
see if tell you that you have errors
if so run chkdsk /r
see if it fixed the errors.
if you get a blue screen, note down the 0x........ number (its 8 digit) Google it or post about it in here
Old 2nd August 2007, 20:07   #13
Thanked: 12 Times
Where does it hang precisely?Does the setup load upto the screen where it detects previous windows installation?
Old 2nd August 2007, 20:47   #14
phamilyman's Avatar
Thanked: 3,454 Times
Have you tried booting kubuntu with hdd unplugged? or a separate hdd swapped in? Methinks it tries to use swap space on disk, or tries to access, hangs and crashes. I used 24Online for an year with Win2000. Zero issues, except the generally useless nature of my cablewala/Hathway. They were as down as the tide - twice a day, with no hope, except time
Old 2nd August 2007, 21:41   #15
Thanked: 116 Times
Nope, it hangs before that. After loading the drivers, a message - "Starting Windows XP" comes at bottom tool-bar and it hangs. :-(
\N
Radiator fan conked off in my Fabia! mayank123 Technical Stuff 13 21st November 2014 08:48
Combination switch conked off. Can't find one in the market! FanaticOnWheels Technical Stuff 6 16th April 2010 12:34
High Beam Suddenly Conked Out mobike008 Technical Stuff 22 10th April 2010 10:19
Help me configure a desktop cooldude1988765 Gadgets, Computers & Software 3 5th September 2009 17:10
Help-Unknown File on desktop rahul_intlad Shifting gears 5 23rd August 2007 13:03
