Old 9th August 2007, 13:10   #1
benbsb29's Avatar
Thanked: 4,281 Times
Question Issue with my Pendrive
Hi guys,
I use a 1GB Memorex pen drive for transporting data between my office as well as home PC. When i insert it at my office computer, i see the folders in the following view :
The same when viewed on my PC at home, doesnt show some of the folders and i cannot understand why. This is how it looks:
The folder settings at home are set to show even hidden files, and so this shouldnt be the reason.
Any pointers?
Old 9th August 2007, 13:26   #2
Bass&Trouble's Avatar
Thanked: 71 Times
I'm just guessing.
Maybe some of those folders are 'hidden' folders. One comp is set to 'show' hidden folders, other to 'hide'??
Old 9th August 2007, 13:27   #3
benbsb29's Avatar
B&T, thats what i thought too. But as i have mentioned above, even on the home PC, the folder settings are set to show all folders, hidden or not.
I even reset to default folder settings and tried, to no avail.
EDIT : Replying to vid's post below.
Vid, tried the same too. It only shows the same folders as i have put up in Pic 2. :(
Old 9th August 2007, 13:28   #4
Vid6639's Avatar
Thanked: 21,083 Times
You have the U3 software which is like a small OS installed on the pendrive. From office it looks like a normal drive whereas from home the U3 autoplays and you see the software.
Launch U3 and explore the drive from there.
Old 9th August 2007, 13:42   #5
Thanked: 71 Times
Oops, sorry. I totally missed that part of your post. But in the picture, the Pics folder does look a bit darker than the other folders, somewhat like the view when showing hidden and regular folders together.
Old 9th August 2007, 13:44   #6
benbsb29's Avatar
Nice observation, B&T. The other folders do look like hidden folders, which is why i checked that out first. Mysterious.
Old 9th August 2007, 13:53   #7
rjstyles69's Avatar
Thanked: 795 Times
Can you post up the occupied space on both instances Benny.
Old 9th August 2007, 13:57   #8
Vid6639's Avatar
What comp do you have at home? The comp at home is not detecting the folders created which are formatted for the U3 software.
On the net search for the U3 help page, I'm sure there will be a fix there.
Old 9th August 2007, 14:04   #9
techn9ne's Avatar
the underlined should be unchecked for viewing all folders
techn9ne is offline   Reply With Quote
Old 9th August 2007, 14:12   #10
HellwratH's Avatar
Thanked: 57 Times
One thing I noticed was this document folder's modified date is 22/jan/08..howz that possible? :O Moreover, I think its an issue of hidden files as if you see closely the pics folder has a darker shade of yellow in the first picture as compared to others. So my assumption here would be that the folders documents, for_b, music and system are internal and are used by U3. And you are able to view them on your office PC coz of some setting which is disabled in your home PC. Hope this helps
HellwratH is offline   Reply With Quote
Old 9th August 2007, 14:12   #11
benbsb29's Avatar
Riju, since the problem is with the PC at home, shall put up the space occupied tommorow.
Vid, this issue didnt exist till about 2 days back. It used to show up as the same on both PCs. As far as i remember, i havent done any change in the settings too, on my PC at home.
Shall recheck at home, yet again.
Old 13th August 2007, 20:12   #12
rjstyles69's Avatar
Thanked: 795 Times
***bump*** Any updates Benny?
Budget HU for Liva - Only USB and pendrive required(CDs optional) tsk1979 In-Car Entertainment 15 22nd March 2012 17:24
Sos: Issue with HP 4GB Pendrive lejhoom Gadgets, Computers & Software 16 12th January 2010 00:35
Beware of Fake 32 GB Kingston Pendrive Sarvodaya Gadgets, Computers & Software 4 15th November 2009 18:51
Sandisk Pendrive 4GB cruzer titanium(From where to get in delhi) somebodystopme Gadgets, Computers & Software 9 10th September 2007 10:32
Pendrive/External memory to HU? SRK In-Car Entertainment 5 23rd July 2007 21:19
