Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 30th November 2007, 10:29   #1546 (permalink)
I'm thinking of starting a new thread titled "My E-3 Fund". It will have my account number.
Torqy is offline   Reply With Quote
Old 30th November 2007, 13:51   #1547 (permalink)
Hellcat's Avatar
First look video of the 1DS Mark III......drool
Canon EOS 1Ds Mark III - First Impression Video by DigitalRev - DigitalRev.com
Hellcat is online now   Reply With Quote
Old 30th November 2007, 17:29   #1548 (permalink)
mail4ajo's Avatar
You need a more solid and heavy tripod to support a dSLR. At least aim for 4Kg or above, it will be mentioned in the tripod specs.
What are the pros and cons of a monopod part from that it cant stand on its own? Havent used or seen one being used. What shooting suitations will it work best in? Any good brands to consider?
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 30th November 2007, 17:51   #1549 (permalink)
Team-BHP Moderator
tsk1979's Avatar
A monopod will give you 2-3 stops advantage.
__________________
Old 30th November 2007, 18:23   #1550 (permalink)
Hellcat's Avatar
How To Use The Monopod.
How To Use A Monopod & Multi-Purpose Tripod
Old 30th November 2007, 20:57   #1551 (permalink)
Apart from being easy to carry around, it works well for panning shots.
E.g. Motor Sports.
(I'm yet to get one though.)
Manfrotto is a good brand. There are even more expensive ones....varies with the material / and the head.
-- Torqy
Old 2nd December 2007, 22:03   #1552 (permalink)
Team-BHP Moderator
Samurai's Avatar
Monopod is for specialised needs, for general needs tripod is better.
Some user comparisons:
E3 vs 5D: Two weeks with my E-3, and couldn't be happier . . . . [Page 1]: Olympus SLR Talk Forum: Digital Photography Review
E3 vs D300: Tried the D300, 40D, Pentax 10D, and E-3 yesterday ...: Olympus SLR Talk Forum: Digital Photography Review
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 3rd December 2007, 01:53   #1553 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Happy users indeed.
I have seen that depending on the forums the "happy camera" changes.
On Olympus forum, E3 is the second coming, and on the Canon Forums 40D is the return of Eden.
What these guys don't realize that neither E3 nor the D40 can make coffee. For that you need nescafe coffee machine
__________________
Old 3rd December 2007, 07:02   #1554 (permalink)
Team-BHP Moderator
Samurai's Avatar
If you want to go that way, monopod is better than tripod. The monopod can be used as a weapon (stick) for self defence purposes, where as tripod is awkward in the respect.
__________________
Samurai
Old 3rd December 2007, 07:40   #1555 (permalink)
condor's Avatar
May be some one will design a monopod with a mini-tripod as bottom piece. This mini-tripod can be unlocked using a foot-operated lever, and will allow simultaneous adjustment of all three tripod feet. Once user has the correct position, he can release the foot-operated lever to lock the tripod legs in place. Stability will be through holding this monopod. The function of the mini-tripod part will be more do provide a level base.
Or is there anything like this in the market today ?
__________________
Life is Analog. Digital is an approximation.
Old 3rd December 2007, 08:03   #1556 (permalink)
Team-BHP Moderator
Samurai's Avatar
That won't work condor. As you know the center pole of most tripod can be raised, like in the image below.
But this contributes to more vibrations, and is actually discouraged. You can get maximum stability in a given tripod if the tripod head is resting one the 3 legs than raised one the solitary pole. Then comes the sturdiness of the tripod itself, recently my manfrotto 190DB tripod failed to provide the amount of support needed by Rudra's 400mm lens resulting in vibrations.
Therefore, a monopod on 3 tiny legs is not really useful. May be slightly better than monopod, but no closer to a real tripod.
__________________
Samurai
Old 3rd December 2007, 08:28   #1557 (permalink)
Team-BHP Moderator
navin's Avatar
,,,neither E3 nor the D40 can make coffee. For that you need nescafe coffee machine
Ugh! sacriliage! why nescafe? even the stuff sold at "Philips" coffe house (it tastes like it is 35%+ chicory) is better. Atleast it tastes like coffee. Nescafe is synthetic.
__________________
Scixelsyd Etinu
Old 3rd December 2007, 08:34   #1558 (permalink)
condor's Avatar
Not as a substitute for a monopod. More an enhancement to increase stability of a monopod a little. Thing is, a monopod is still vulnerable to shakes (not jerks). Having a little support at the bottom can help reduce the shakes.
An alternate to this tri-pod bottom piece can be a ball-head. Just a means to provide a larger contact area where the monopod rests on the ground, while retaining the manoeuverability of a monopod. Either way, when using a monopod, the weight of the camera is supported by the user by holding the monopod.
__________________
Old 4th December 2007, 16:26   #1559 (permalink)
jkdas's Avatar
how much for EOS 400D
can someone pm me if you have contacts to buy one.
__________________
"She may not look like much, but she's got it where it counts, kid."
jkdas is online now   Reply With Quote
Old 5th December 2007, 18:26   #1560 (permalink)
rsjaurr's Avatar
Finally i received my favourite Canon S5 digicam along with this bag and 8GB SDHC memory card. I'm lo..ving it...so far
BTW plz suggest the way to take pictures of my kid,mostly indoor who moves too much and i am getting blurred pics.I know there is plenty of knowledge available online but dont have enough time to dig too deep
__________________
Fate is 2 faced..it depends on you to decide on which side to look at.
rsjaurr is offline   Reply With Quote
Thread Tools
The Mobile Phone Thread - Queries, decisions, discussions all here. ravi_28_8 Gadgets, Computers & Software 3542 24th July 2008 00:58
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
