Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 5th December 2007, 18:43   #1561 (permalink)
extreme_torque's Avatar
Originally Posted by rsjaurr View Post
Finally i received my favourite Canon S5 digicam along with this bag and 8GB SDHC memory card. I'm lo..ving it...so far
BTW plz suggest the way to take pictures of my kid,mostly indoor who moves too much and i am getting blurred pics.I know there is plenty of knowledge available online but dont have enough time to dig too deep
Click in aperture priority mode (Av on the dial) with the flash raised. It will give you a shutter speed of around 1/60 which is good enough to freeze your moving son. Happy Clicking and do post the pics here while you are at it.
__________________
My Clicks:
extreme_torque is offline   Reply With Quote
Old 5th December 2007, 18:49   #1562 (permalink)
condor's Avatar
doc, can you track a subject with this camera ?
__________________
Life is Analog. Digital is an approximation.
All kinds of animals come here ... and the occasional demon too !
Old 6th December 2007, 00:51   #1563 (permalink)
mail4ajo's Avatar
Which would be the best value for money choice among these three similar spec lenses:
1. Canon EF 70-300mm III USM
2. Tamron 70-300mm Di LD
3. Sigma 70-300mm APO Macro
I cant afford and my use do not require the L series which I know is quality glass.
I personally want the Canon EF 70-300mm IS USM, but way expensive than the above mentioned lenses closer in quality and price to the 70-200mm F4 L series. Any user feedback will be great. Want to buy in March 08.
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 6th December 2007, 06:39   #1564 (permalink)
condor's Avatar
Try to stick to Canon (I assume you have a Canon body).
__________________
Old 6th December 2007, 07:04   #1565 (permalink)
Samurai's Avatar
If this was the case why did you go for dSLR? If you just wanted longer reach, there are many long zoom P&S cameras that can outperform most dSLRs with cheapo tele-zoom lenses. And they will be cheaper too.
One should switch to dSLR for achieving technical excellence. But after switching to dSLR, if you still want to buy cheap lenses, then you are defeating the purpose of switching to dSLR.
I know what you are thinking, you are thinking of the long reach the 70-300 can give, but when you find that it will give you bad images in most but the best condition, you will regret the decision.
Last year I had to choose between, 50-200mm Zuiko lens and 50-500mm Sigma (Bigma). Price was quite similar. I was thinking 50-500mm is VFM because I can get more reach for the money. Finally it took Rudra to show me the light, I went with the Zuiko 50-200mm, currently that is my best lens, I use it as much as my primary 14-54mm lens. Meanwhile I know people in PAAI who bought the bigma, but want to sell it since they don't know what to do with it.
I asked this question to another member recently, Do you want to shoot long range ordinary shots or excellent normal shots?
A dSLR system owner should spend 70% of their investment on lens and rest on body. The lens will stay much longer with you than the body. Don't go cheap on the lens. You can take great shots even with a cheap dSLR body, but you can't do the same with cheap lenses.
Actually borrow a L lens for a day, try it out, then think whether you want cheapo lens.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 6th December 2007, 08:58   #1566 (permalink)
Hellcat's Avatar
Some Good Lens if you are on a budget.
Sigma 70-300mm f/4-5.6 APO DG Macro II
Tamron AF55-200mm f4-5.6 Di II Macro LD
Personally I would recomend you to go for the Canon EF 70-200mm f/4.0L USM, its one of Canon's lowest priced "L" series lenses. Optically excellent, probably as good as the 70-200/2.8. A stop slower of course. And Accepts both the EF 1.4x TC and 2x TC.
Hellcat.
Hellcat is offline   Reply With Quote
Old 6th December 2007, 11:09   #1567 (permalink)
tsk1979's Avatar
Samurai, You can get good shots from non L lenses. Shots which would not have been possible with a P&S.
On the 70-300 front, there are 2 lenses which you can go for
1. Sigma 70-300
2. Canon 70-300
go for the former as it has macro also. 70-200L with 1.4x TC is also good buy you will loose a stop with the TC. No big deal since the 70-300 are F5.6 at the long end.
__________________
Reclaiming.....!
Old 6th December 2007, 11:51   #1568 (permalink)
Samurai's Avatar
Sure, under best of conditions and in certain F stops. I wrote a long post because he said he doesn't want quality glass.
Are you sure? Never heard of a TC that doesn't rob a stop.
mail4ajo, spend couple of hours with Krishna, he's got good quality glass. Then you will rethink whether you don't want quality glass.
__________________
Samurai
Old 6th December 2007, 12:27   #1569 (permalink)
tsk1979's Avatar
Yes if you lens is F4, and you put a TC 1.4x you can go down to F5.6 atmost(1 stop loss).
If you TC is 2x then your maximum aperture will decrease a step more (F6.3 I think)
__________________
Reclaiming.....!
Old 6th December 2007, 12:49   #1570 (permalink)
praJEEP's Avatar
I am planning to buy a digital camera, my budget max 24k can strech more that, experts please do advice..
my options
canon powershot S51S,
__________________
A wise man should have money in his head,
but not in his heart.
jonathan swift
praJEEP is online now   Reply With Quote
Old 6th December 2007, 14:11   #1571 (permalink)
Samurai's Avatar
Oops, I misread your post. I thought you said without loss of a stop, my mistake.
mail4ajo, it is better to have 1 good lens instead of 3 ordinary lenses. That's all I gotta say.
__________________
Samurai
Old 6th December 2007, 15:29   #1572 (permalink)
kvish's Avatar
Canon makes amazing high end lenses, but their aam-aadmi offerings are below par to some of the lenses being offered by Sigma and tamron. Sigma and tamron are cheaper too. Check out both before taking a decision. I am also in the lookout for a tele, since sigma has launched two new lenses (50-150 and 70-200) I think I'll wait.
kvish is offline   Reply With Quote
Old 6th December 2007, 15:38   #1573 (permalink)
tsk1979's Avatar
Agree with you kvish, but before buying any sigma or tamron, check for focus accuracy. The entry level SLRs(esp the 350D) is notorios for throwing up focusing issues.
So try before you buy
If I use the 50mm at F1.8, about 20-30% of my shots come OOF.
And thats a canon lens. Looking at web forums, this is a problem with the XT, and most people shoot at F2.8.
With Sigma and Tamron telephoto offerings, you may miss focus quite often for some samples.
So try the lens, if it focuses, buy it.
__________________
Reclaiming.....!
Old 6th December 2007, 19:05   #1574 (permalink)
mail4ajo's Avatar
Thanks for the comments especially from Samurai. Was an eyeopener. I was under the impression that L series are used only by proffessionals for very high quality results and hence said that I dont require it.
I spoke to a few proffesionals in my native and they echoed the same comments on the 300mm lenses. What I am going to do now is to either rent or borrow a L series and a 300mm one for comparision.
I have also heard that the Canon 70-300mm IS USM gives good results and is considered a "hidden L lens". Its priced almost equal to the entry level 70-200mm L series. I think the IS and the extra 100mm is value for money.
__________________
Old 6th December 2007, 20:59   #1575 (permalink)
guyonblackybx's Avatar
I would love to do that too where in Hyd can I get to rent lens like these I have Sigma 70-300mm and not happy with the quality of pictures that I get with it. I can't afford a high end IS lens. Any one around here who knows a place to rent lens?
__________________
Escorts Yamaha YBX(2001)
Fiat Palio Stile 1.6 Sport 2007
guyonblackybx is offline   Reply With Quote
Thread Tools
The Mobile Phone Thread - Queries, decisions, discussions all here. ravi_28_8 Gadgets, Computers & Software 3895 10th October 2008 22:43
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
