Old 7th December 2007, 10:13   #1576
condor's Avatar
Thanked: 4,810 Times
navin : Of that 60% I would spend more on the lens you will use most.
That's why the 50-200mm (Zuiko) makes a lot of sense. Most of one's shooting can happen within the range of this lens. Beyond that, a wide-angle is a good choice.
If you shoot birds & wildlife, then you can go for a tele-photo.
Old 7th December 2007, 12:27   #1577
kvish's Avatar
Thanked: 136 Times
In olympus, its 2x magnification. I am not sure if a 100-400(eq) lens is going to fall 'in most used range'. Well, the same 2x magnification on the other hand makes even a 50-200 lens usable for birds and wildlife.
kvish is offline   Reply With Quote
Old 7th December 2007, 13:21   #1578
tsk1979's Avatar
Thanked: 15,854 Times
A note to oly users.
When you look at test reports of 50-500, you will get much better performance than tests. This is because you don't use the corners, which are the problem area.
Same lens will perform bad on a full frame, better on 1.6x crop and amazingly on the 2x crop.
You are using the sweet center spot. And even cheap non high quality lenses perform as good as expensive lenses if you look at the image quality around the center.
So the 50-500 may be a problem for the full frame land, or even for the 1.5x,1.6x crop domain, but on the Oly, its amazing.
Oly E-3 + 12-60 + 50-500 = Serious Bada$$ combo!
Old 7th December 2007, 14:28   #1579
Samurai's Avatar
Thanked: 15,339 Times
50-200mm vs 50-500mm = 1070g vs 1,842g
The bigma is not so sharp, especially closer to 500mm. You might get really close shot, but if it is not sharp, it defeats the purpose.
Old 7th December 2007, 14:54   #1580
tsk1979's Avatar
Its not sharp as you go away from center. With 2x you are always close to center.
Old 7th December 2007, 16:47   #1581
kvish's Avatar
Thanked: 136 Times
While checking out the olympus site, bumped into this news item
One step too soon
Old 7th December 2007, 17:22   #1582
condor's Avatar
kvish : In olympus, its 2x magnification. I am not sure if a 100-400(eq) lens is going to fall 'in most used range'. Well, the same 2x magnification on the other hand makes even a 50-200 lens usable for birds and wildlife.
@kvish, can you explain a little more about what you mean by '2x' here ?
Old 7th December 2007, 17:30   #1583
gkrishn's Avatar
Thanked: 36 Times
The sensor size is 1/2 of the legacy 35mm film. So a 50mm lens on 35mm film will be like a 100mm(fov) lens on oly slr. This is what he meant by 2x.
Its a crop factor... not sure angle of view also changes from 50mm to 100mm.
gkrishn is offline   Reply With Quote
Old 7th December 2007, 17:42   #1584
condor's Avatar
@gkrishn, thanks.
If Olympus cameras have a different crop factor, then pls make calculations accordingly. (I'm a Nikon user). I have used traditional /film camera focal lengths in my post.
Old 7th December 2007, 20:28   #1585
sabret00the's Avatar
Thanked: 45 Times
I'am getting a deal on my credit card on a Canon PowerShot A550 for Rs.6000 (+ Rs.100 for delivery). They are also offerring Nikon Coolpix L11 & L12. But I did some research and found that the Canon A550 is a better camera and would thus like to buy it. I just wanted to know it is worth buying for that price?
I'am not a photographer and I'am upgrading from a Sony Ericsson k790i cybershot phone to a digital camera. I really have no idea about digital cameras and their prices. Hence I was trying to find out if this was a good deal or not?
sabret00the is offline   Reply With Quote
Old 7th December 2007, 20:50   #1586
neoranjit's Avatar
Thanked: 191 Times
Default Opteka 650-1300
Hi, Can anyone let me know if this is a good buy ?
Opteka 650-1300mm High Definition Telephoto Lens - OPT 1300
neoranjit is offline   Reply With Quote
Old 7th December 2007, 22:28   #1587
mail4ajo's Avatar
Thanked: 257 Times
I still use the previous model of this camera, the A520 (4MP, 4x optical zoom) even though I have upgraded to a DSLR. I am sure you will not be disappointed. But the price may be higher than other brands as Canon charges a premium on most of their cams.
mail4ajo is offline   Reply With Quote
Old 7th December 2007, 22:48   #1588
mail4ajo's Avatar
Thanked: 257 Times
The aperture rating says f/8-16. That means it will be very very soft on the tele end. People are crying foul over the image sharpness at 300mm on a lens with f/5.6 at tele end. I seriously doubt this lens.
Looks like all their lens are ultra slow. Nothing less than f/8!!!!
Old 7th December 2007, 23:37   #1589
condor's Avatar
neoranjit : Hi, Can anyone let me know if this is a good buy ?
Also, What is your intended use of such a lens ?
Old 8th December 2007, 00:09   #1590
navin's Avatar
Thanked: 4,179 Times
Same lens will perform bad on a full frame, better on 1.6x crop and amazingly on the 2x crop.Oly E-3 + 12-60 + 50-500 = Serious Bada$$ combo!
actually I thought lense for CMOS and CCD cameras need to be designed so that all the incident rays on the CCDs are at right angles to the CCD/CMOS sensor. Film was not as sensitive to this issue. Hence Film lenses are not really suited for digital.
as far as DSLRs go
Oly is a 2 x crop and no FF
Nikon 1.5 x crop as well as FF
Canon has a 1.6 and 1.3 x crop as well as FF
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
