| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #2086 (permalink) | |
| Senior - BHPian Join Date: Feb 2006 Location: Cok tmw?!?
| Quote:
I had the ISO@400 and the AWB on Evaluate (not auto) in the MANUAL MODE/SETTINGS ... I was under the assumption if I select full auto it will pick the default settings - but looks like it inst doing that! Don't know if thats the problem but I have put everything on Auto even in the manual settings.. and am off to Ooty tomorrow !! The results will speak for itself but something tells me this must be it! And yes... I am willing to pick up a DSLR - something that gives excellent shots with great "depth" - I am a BIG fan of DEPTH in shots!... somehow dont like how most camera's (the P&Ss that is) don't give you the feeling of depth. Depth makes portraits and landscape come alive! I don't mind the bulk - but I do want ONE lens - or maybe max Two (Tele). BUT both of them have to be quick on the draw - that is give me the ability to take a shot on the run without having to dawdle on the settings. Suggestions are most welcome - along with an indicative price. Edit: The Batt- 840mAh - used to last me almost 100 odd snaps with flash when new - more if flash was not used as much. I have a spare which really seems to have copped it - gives me only some 15 odd shots now (with flash) - Hence was thinking might make more sense to buy a new camera than go in for two new batteries. Ixus 430 was launched some time in Feb 04 and I picked it up in April 04 - this was the top of the line then with 5 megapixels just getting in . But now 8-10 seem the way to go!
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 27th April 2008 at 22:30. | |
| | #2087 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. | |
| | #2088 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
DOF can be controlled by varying the apature so a DSLR can have the DOF as a P&S if the user wants it so. DSLRs (even those with APS-C sized sensors) cant be compared with P&Ss. Most P&S sensors are 1/10 the area of a APS-C sensor. Depth of Field: Optical: Glossary: Learn: Digital Photography Review
__________________ Scixelsyd Etinu Last edited by navin : 28th April 2008 at 00:24. | |
| | #2089 (permalink) | |
| BHPian Join Date: Sep 2006 Location: Bangalore
| Quote:
and KB,if you want to pick up a SLR but want to shoot as fast as possible using the automatic modes then there is no point of going for a DSLR. You'll end up getting the same results only.All I could say is that you need to be very patient and wait for the moment to get a better shot from the good ones.And if you want to take quick shots without bothering about settings then better to go for something like prosumer cameras(with longer reach) A DSLR may be a overkill here.Another good point about P&S is that most of the P&S cameras will do a kind of post processing on the shots so that colors will look vivid but in DSLR most of the time one has to do his own post processing. I always suggest this to people as I've seen quite a few people who buy the most expensive DSLR but use it as a P&S and get frustrated with the results.Some of them learn and some just throws the camera aways blaming it for the not so good shots. The initial stage of photography has a steep learning curve(albeit a easy one if one is interested) and go for a DSLR only if you think you really want to.I'm not trying to dishearten you by saying this, please don't get me wrong.I'm also a learner in this field but have experienced these things along the journey. Regards Kaushik | |
| | #2090 (permalink) | |
| BHPian Join Date: Aug 2007 Location: Bangalore
| Quote:
-- Torqy | |
| | #2092 (permalink) |
| BHPian Join Date: Nov 2007 Location: Noida/Delhi
| IMHO, white balance may have played a small part but it cannot account for the difference in the shots. Wrong WB can add a different color cast and can even make a picture look washed out. But in the two pictures Redrage posted - the one from the D40 has sun and the other not. |
| | #2093 (permalink) | |
| Quote:
In my mind there is a direct correlation between an SLR and better pictures. I actually find digital P&S cameras, fidgety to use. My suggestion for a DSLR is the Nikon D40x with the 18-200VR lens (the closest you can get to a do it all lens). Together they should cost $1,300. You can get the same lens range for less if you opt to go for two lenses instead of one - the 18-55mm and 55-200 VR. Those two with the D40x should cost about $850. There is an inadvertent advertisement here for the D40x in Redrage's post! | |
| | #2094 (permalink) |
| BHPian | Guys, The Times of India ran an advert for new Canon cameras yesterday. One of the launches is the EOS 450D Kit (EF S18-55IS) which is priced at INR 47995.00!!!! . (Source: Canon India)450D Body only is available at 42995.00. Is it already available in grey markets? |
| | #2095 (permalink) | |
| BHPian | Hi You might want to try and set the exposure on 400 ASA plus select the spot autofocus option which usually increases the camera's ability to take superb photos both outdoors and indoors. I use a SONY DSC T9 6Megapixel with 3X Optical Zoom - Carl Zeiss Vario Tessar Lens. It is very small, easily hooked onto your belt, and takes brilliant photos both outdoors and indoors. I can assure you of this because I ve covered a lot of ground with this camera and indeed, since I write Golf Travelogues for a magazine called Golfline as a freelancer, I ve given them high quality print ready photos of many golf courses around the world which were taken with this little camera of mine. All these photos have come out very well in print, in the magazine. For your ref, I am attaching a few photos of cars taken with this camera, but which have been re-sized to a much smaller size to fit onto this website. The two photos of Alvis Cars have been taken indoors at a museum, without flash, but with Spot AF on and with the 400 ASA setting. The photo of the Black Jag with the Spitfire in the background was taken with the same setting but on a moderately bright summer morning around 11am, and the photo of the Red Jag was taken around 630am in the morning when the sun hadn't yet come out and on the same camera setting. There are some even better recent options than mine which are available from SONY and I would recommend that you view them. Notwithstanding what anyone else may say, I am convinced that these are frankly amongst the best, most user friendly and technologically advanced digital cameras available for "non-professional" photographers like us and importantly, at reasonably manageable prices too. Cheers Quote:
| | #2096 (permalink) | |
| BHPian | Quote:
I too am not able to decide between a D-SLR or a Prosumer camera. Though I want to have control in my had I can frankly say that what I have been doing till now is P&S. Actually that is what I am using now. My first cam was a Sony Cybershot DSC-P9 (4 MP) I bought it in 2001. Though I occasionally borrow the DSC-W7 (7.2 MP) (cousin owns it) and this is the one that I am currently using. Now i am not able to decide whether to go in for a Canon PowerShot S5-IS or a D-SLR EOS 450D. What I have been doing in the past is only Point and shoot. Though I wanted to seriously pursue photography as a serious hobby but never done it in the past 7 years. So what photography I generally do is on holidays and on family functions. I am totally confused here so any help or tips would be useful.
__________________ "It is better to do nothing at all than to do something stupid" Warren E Buffett | |
| | #2097 (permalink) |
| Team-BHP Moderator ![]() | Go for a prosumer like S5 IS. Unless you are really going into the type of photography which pushes equipment to the limits(Very long exposures, high ISOs, extreme zoom etc.,) a P&S will keep you happier.
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #2098 (permalink) | |
| Quote:
Well you said that you are interested in learning photography but haven't done for 7 years, that means that you are not very sure about it. So I would suggest as TSK said that go for a prosumer which will give you enough control(oh yes these cameras also have creative exposure control) to learn the nitty-gritties of photography. Now say after using it for a year or something if you feel like outgrowing the camera[that means say you want more control to try different things, you know something that can be done but the camera limits you etc.] then you'll know that you are ready for a DSLR.And then only go for one.Otherwise if you are happy with that camera then you can continue with that, those prosumers are also very very good cameras for many purposes.During this period use the net to fullest of use to learn photography, it's a treasure trove of information.Learn,experiment,shoot and then decide.I've said one year just as an example but you may outgrow your camera even in 2-3 months itself if you are keen on it. wish you all the best. Kaushik | |
| | #2099 (permalink) | |
Talking about non-professionals, we have lots of dSLR totting non-professionals in the forum including yours truely. Therefore the term non-professional is moot. You should rather use terms like photography-aware and photography-unaware people. The T9 would be a good choice for the latter group.Edit: The real legend among ultra compact was Fujifilm F30/F31fd.
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. Last edited by Samurai : 28th April 2008 at 19:42. | |
| | #2100 (permalink) | |
| BHPian Join Date: Oct 2007 Location: Bangalore
| Quote:
one thing i have felt, one can enjoy a good dslr only while alone or with other enthusiasts, normally people would complain that you are taking too much time to just click the shot and soon enough you'd get bored of the complaints and convert your costly high end slr to a point and shoot ![]()
__________________ Safari 2.2 VTT LX 2007, Mahindra Bolero 2005, Bullet Machismo 2000, Fiat Premier Padmini 1987, Lambretta 1956 | |
| Thread Tools | |
Similar Threads | ||||
| The Mobile Phone Thread - Queries, decisions, discussions all here. | ravi_28_8 | Gadgets, Computers & Software | 3542 | 24th July 2008 00:58 |
| New Digital camera | v1p3r | Gadgets, Computers & Software | 117 | 3rd September 2006 13:22 |
| Digital Camera Reviews (around Rs. 20,000/-) | naveendhyani | Gadgets, Computers & Software | 107 | 10th July 2006 12:32 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341
. (Source:
