Old 18th July 2008, 07:50   #2641
I have Canon OowerShot SD870 IS. I always use it in auto mode and it's working pretty good. The video is also nice.
srikat is offline   Reply With Quote
Old 18th July 2008, 09:21   #2642
Thanked: 128 Times
Why do you not try the G9. I got it from brother abroad and costs around 18-20K in UK. OK, it is not SLR, but definitely better than most of the digicams in that range. If you want, I can mail you a sample photo taken from my G9.
vasudeva is offline   Reply With Quote
Old 18th July 2008, 09:23   #2643
reignofchaos's Avatar
Thanked: 1,152 Times
G9 is one of the most capable point and shoots alongwith the fujifilm s100 series.
reignofchaos is online now   Reply With Quote
Old 18th July 2008, 12:39   #2644
Thanked: 128 Times
Eliminate all 3-5x optical zoom cameras. I bought G9 with a 6X zoom. That was lower than S5IS (10-12 x) but I thought it could be extended thru optional equipment later. The photo results on G9 are very good, and it gives even better with only a little bit of customisation. I got it as an import for 19K in 11/07 and prices may be even lower now. At 15K+10%, you would be wasting money on 3-4x zooms.
Old 18th July 2008, 12:45   #2645
kutlee's Avatar
Thanked: 194 Times
thanks Vasudeva, i am following this thread and still not able to decide. TZ5 and G9 are capable cameras. with TZ5 having a bit more features such as HD video recording (althought this can't match the proper handycam video). TZ5 is highly recommended in the dpreview. There is one more option though for those who love manual controls.
check the Pentax K100D DSLR. should be good. any idea about this camera?
Vasudeva? why don't you post the sample G9 pic here?
kutlee is offline   Reply With Quote
Old 18th July 2008, 12:48   #2646
smsrini's Avatar
Thanked: 248 Times
Zoomingbhat, Go for the powershot S5 IS ( INR 20995/- ) or SX100 IS ( Rs 15995/- ).
Price from canon.co.in.
cheers!
smsrini is online now   Reply With Quote
Old 18th July 2008, 13:01   #2647
Thanked: 1,475 Times
Originally Posted by jaibir View Post
Then the D300 comes. One look through the viewfinder and I'm hooked as I get reminded of the bright viewfinders of my old film cameras. The WA gets forgotten for the moment, as does the D200 as I spend my entire budget for the D300 (with an extra battery). I'm reasonably sure I'm going to miss the UWA, but that can be remedied at a later date.
p.s. lets see how long this one lasts before I start hankering for a full frame .....
Similar sort of process that I went through. Nearly went for a used D200 till I saw the D300. Obviously my reasons for buying it were not all that professional as I am very much a novice, but the D300 blew the D200 away.
Congrats!
Steeroid is offline   Reply With Quote
Old 18th July 2008, 16:21   #2648
anonymous's Avatar
Thanked: 15 Times
Just came across this high end camera, which will be avaliable from october 2008. 50 Mpixel 3648mm sensor, which measures, twice the physical size of the largest 35mm DSLR sensors, the H3DII-50 camera system has been specially designed to meet the most exacting demands of high-end commercial photographers who require the ultimate in both image quality and performance
H3DII-50
anonymous is offline   Reply With Quote
Old 18th July 2008, 16:51   #2649
jaibir's Avatar
Thanked: 48 Times
H3DII-50
Seems like the digital equivalent of a medium format camera. I thought there were a couple of similar (large sensor based) products already around
jaibir is offline   Reply With Quote
Old 18th July 2008, 18:02   #2650
Thanked: 128 Times
Trust me, G9 performs as claimed and then more. Of course, that came in mid-2007 and till the time I bought it in Nov 2007, it was amongst the best in its range and somewhat above (the best?). This is July 2008.
You can see a photo here (of wife's sister husband):
vasudeva - SOME G9 PHOTOS
My son:
vasudeva - IMG_0008.jpgmore g9
Each G9 photo is around 4-5MB and it may not be possible to email. More photos can be seen at other websites.
Old 19th July 2008, 07:13   #2651
The only equivalent of Medium format in Canikon range is Canon EOS 1Ds Mark III. 21.1 MPS camera with a 1.3x crop factor, Dual DIGIC-III 14 bit processor chips make it superfast and at the same time, unparrelled. And not to mention, Up to 5 fps, burst rate up to 12 consecutive RAW images or 56 full-resolution JPEGs, and compatible with newest UDMA high-speed CF cards, it is simply superb.
I am not going to compare it with D3 because there are simply enough difference to keep it at a different plain. Plus, I also wouldn't like to open a can of worms (Read Nikon vs Canon).
given2fly is offline   Reply With Quote
Old 20th July 2008, 17:54   #2652
NIP
NIP's Avatar
Thanked: 81 Times
guys i've been doing some research on superzoom DCs on the net and i've decided to buy a Panasonic FZ18. this suits my needs perfectly. can someone point me to the right place to buy this camera in bangalore and give me an appoximate price for the same. planning to buy this week. thanks in advance!
NIP is offline   Reply With Quote
Old 20th July 2008, 19:44   #2653
redrage's Avatar
Thanked: 58 Times
Please have a look at the other super zoom's too just befor you purchase, the image quality of the FZ18 somehow seems to be ages behind those having 10x/12x zooms, just compared my friends fz18 with my s3is, ofcourse other than the reach and everything anything above ISO 200 seems to be of really pathetic image quality on the fz18. Have a look at Nikon P80 & Fujifilm S8100 fd as well.
Contact R.K Photoguide or Photocircle to get good prices.
redrage is offline   Reply With Quote
Old 20th July 2008, 20:04   #2654
gopz's Avatar
From what I know, S8100fd is a good model, but FZ18 is better than the Nikon P80.
gopz is offline   Reply With Quote
Old 20th July 2008, 20:52   #2655
Thanked: 31 Times
I came to know Panasonic FZ18 picture is not great and Fuji 8100fd and few similar models in Canoon have better image quality.
I saw FotoCircle and other shop guys try to push Panasonic over Fuji and Canoon/Nikon since its slow moving in sales i guess.
I suggest Fuji s8100fd which would cost 15,000 range over FZ18 which would cost 18,000 range.
If someone has baught Fuji s100fs let me know I am ready to buy that after complete research.
Ravi.
ravibhat is offline   Reply With Quote
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
