Old 31st July 2008, 15:02   #2686
AnniHilat0R's Avatar
Thanked: 21 Times
Hey guys, needed some help. My cousin got me a Canon EOS 400D from Aussie Land. I am having some problems with the pictures.
As you can see in the pic, the black I dont know what to name it as, just keeps on coming in all the pictures. I read the entire manual also checked the online FAQ's but couldnt find anything about it. Can anyone please tell me what is it and why its happening ? And if there is a problem, where can I get it done in Mumbai.
AnniHilat0R is offline   Reply With Quote
Old 31st July 2008, 15:13   #2687
reignofchaos's Avatar
Thanked: 1,148 Times
There's something either inside the lens or on the sensor itself.
Old 31st July 2008, 15:14   #2688
tsk1979's Avatar
Thanked: 15,573 Times
Remove the lens and see if there is something stuck to it. If not, try with another lens, if its not a lens issue, you could need to canon authorized service center
Old 31st July 2008, 15:40   #2689
Thanked: 1,475 Times
If you are buying cameras from Dubai, the official distributor will be more expensive than your prices in India.
Go to Al Falak Electronics, a small shop next to Jumbo Electronics at the ground floor of City Centre, Deira. This is exactly opposite the taxi queue (at the moment - everything changes in Dubai so dont blame me if the taxi queue is elsewhere when you visit).
He will give you genuine stuff at close to Singapore prices (obviously at a slight premium for his costs / profit). Else the best place to buy Cameras is Singapore.
Originally Posted by Tarun View Post
Guys,
I am in a hunt for Digital camera. Shorlty one of my cousins is flying from Dubai, he's advised me to visit Jumbo Electronics Company Dubai UAE - the largest distributor of consumer electronics and technology products in Dubai and in all over UAE ( United Arab Emirates )
Do you think having it from Dubai will be cheaper and of better quality, if yes, is there any other site which has the best rates from Dubai ? Below are the approx price for the models that I shorlisted :
1) Fujifilm S8100 FD Price is 1599/- Dhs. Approx around 18550/- INR
2) Nikon P 80 Price is 1999/- Dhs. Approx around 23200/- INR
3) Panasonic F 18 the Price is 1899/- Dhs. Approx around 22030/- INR
What will be the approx. price for these here with decent service backup ? I am located in delhi. And do mention if there are other models of similar range.
Pls. advise
Thanks,
Tarun.
Steeroid is offline   Reply With Quote
Old 31st July 2008, 15:48   #2690
navin_bhp's Avatar
Thanked: 21 Times
Looks like a big piece of dust is stuck on the sensor or the back of the lens..Remove the lens from the mount and check the inside for any dust ... If the lens is clean then its the sensor. Enable sensor cleaning mode in the settings menu and the mirror will lockup...you can see the sensor now. Use a blower to remove the dust particle(be very careful while doing this and make sure the battery is charged)...If the dust particle is very tiny and doesnt go away then you may try this method CCD / CMOS Cleaning Photo Gallery by Nicholas R. at pbase.com or you may get your sensor cleaned at the service center.. The Sensor is very fragile and be very careful while cleaning it..Good luck.
navin_bhp is online now   Reply With Quote
Old 31st July 2008, 17:58   #2691
gopinathann's Avatar
Thanked: 20 Times
I have Sony DSC L1, when I take pictures in certain mode which it doesn't use flash, but process the image for 2-3 seconds, that time the output is very good, however the photos looks shaken. Do you guys use any freeware software to remove those shakes to a certain limit.
gopinathann is offline   Reply With Quote
Old 31st July 2008, 21:12   #2692
Thanked: 297 Times
there's no software, but a hardware called tripod which you need use while taking the snap. of course, only if the subject is static.
tifosikrishna is offline   Reply With Quote
Old 31st July 2008, 21:40   #2693
It doesn't process the image for 2-3 seconds... essentially the shutter is open for 2-3 seconds. If you are hand holding a camera, its impossible to get a proper image with a 2-3 sec shutter speed. You need to place it on a tripod and then take it. If you are taking pictures of people, they should not move for the duration the shutter is open. Not following this will lead to some interesting results .
Old 31st July 2008, 21:49   #2694
rjstyles69's Avatar
Thanked: 786 Times
Something like this eh ?
Old 1st August 2008, 10:09   #2695
navin's Avatar
Thanked: 3,784 Times
Originally Posted by navin_bhp View Post
Looks like a big piece of dust is stuck on the sensor or the back of the lens.. The Sensor is very fragile and be very careful while cleaning it..Good luck.
could it be something on the mirror? does not the 400D have a mirror instead of a prisim?
Old 1st August 2008, 10:55   #2696
tsk1979's Avatar
Navin, if something is on the mirror it will not appear in photographs, only on viewfinder.
Old 1st August 2008, 12:28   #2697
Yup anything on the mirror won't be in the optical path when the shot is taken as the mirror retracts.
Old 1st August 2008, 20:06   #2698
Thanked: 21 Times
Hey guys, thanks for all the suggestions. Will I did remove the lens and check for dust, but nothing in it. Tried another lens, same issue. I also did try the sensor cleaning, but it didnt work. Still the issue exists. Should I take it down to some Canon Service Centre ?
Old 2nd August 2008, 08:27   #2699
navin_bhp's Avatar
Thanked: 21 Times
If you read my post carefully I mentioned that the mirror will lockup when sensor cleaning mode is enabled, exposing the sensor (this shud be done with the lens removed). If the camera is not in sensor cleaning mode the mirror blocks the sensor hiding it behind..Here are some pics for you to show what I mean..
Name:  mirror unlocked Medium.jpg
Name:  sensor cleaning Medium.jpg
Name:  mirror locked Medium.jpg
Here's one of my pic taken with a dust particle stuck on my sensor...
Name:  _MG_8153 Medium.JPG
Old 2nd August 2008, 11:02   #2700
tsk1979's Avatar
Navin_bhp, i was replying to navin, not you
Annhilator, you better head to Canon service center
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
