Old 12th October 2008, 19:14   #2911
married2speed's Avatar
No, this is not normal. None of my cameras (I have 4) have this problem. Either water or some dust has seeped into your camera.
Thanks Samurai. Of course, I know it's not normal, my DSLR doesn't exhibit such character. Hence, the repeating the question & trying to figure out possible reasons
This will happen if you shoot in foggy/rainy weather and especially in low light. Assuming lens is fogged or coated with fine water droplets. Happens when camera is pulled out from it's case and used immediately
Thanks Rudra Sir. This picture was taken on dussehra evening. Was taken out of the case, clicked, the pox appeared. At first I thought it's the external screen. Anyways, I still cleaned the lense, clicked again. This time, more pox. Then changed mode to night potrait, fireworks, and the pox disappears on some while stays on some. It's important to note that if the object is a close object and the range of the flash light covers the object, then the pox is not visibile. However, on objects at infinity, the pox is there. This can happen even after 15-20 minutes of the camera being taken out of the case. For day light shooting, haven't come across this situation, so like it's mentioned, to be a case of low light shooting, again, just my camera or others too?
Pictures attached for reference. At a wide aperture, the pox is there, while at a narrow aperture, there's no pox.
The Digital Camera Thread: Questions, discussions, etc.-d1.jpg
The Digital Camera Thread: Questions, discussions, etc.-d2.jpg
The Digital Camera Thread: Questions, discussions, etc.-d4.jpg
The Digital Camera Thread: Questions, discussions, etc.-d3.jpg
Also, wanted to check if it's possible to clean the shutter of a P&S like in that of a DSLR. I think it's more or less moisture. However, Would be taking it to the canon service camp on the 16th.
Apprecaite your help everyone.
married2speed is offline   Reply With Quote
Old 13th October 2008, 00:48   #2912
Samurai's Avatar
Thanked: 13,488 Times
I just got my 12-60mm lens. The auto-focus on this lens, when coupled with E3, is touted as the fastest in the world. So I tried focusing on a few objects, it was instantaneous, it didn't care about light. Even dark corners were AFed faster than the blink of an eye. Just outstanding AF.
I think most of you are not familiar with Olympus lenses, therefore see what DPReview had to say about this lens, despite their wellknown bias against Olympus.
Originally Posted by Dpreview on Olympus 12-60mm
Olympus appear mainly to have taken advantage of the Four Thirds sensor to deliver lenses which, for any given size, weight and cost, simply perform to a higher and more consistent standard than those optimized for larger formats, with the 12-60mm being a prime example.
Indeed the Olympus Zuiko Digital ED 12-60mm F2.8-4.0 SWD is quite simply a superb lens, which can lay claim to being one of the very best standard zooms currently available. This is a design which would have been almost unimaginable even five years ago; a 5x wideangle to telephoto zoom which, though the use of some exotic optics, manages to perform almost flawlessly across its entire range, and throws in some impressive macro performance too. The relatively fast maximum aperture (a half to a full stop faster than APS-C equivalents such as the Sony Carl Zeiss 16-80mm F3.5-4.5 or Nikon 16-85mm F:3.5-5.6 VR), coupled with the excellent wide-open performance, also allows the use of lower ISOs at equivalent light levels for maximum image quality.
Originally Posted by DPreview on Olympus 50mm
The greatest strength of the Four Thirds system undoubtedly lies in the optics, and the 50mm F2.0 macro ranks alongside the likes of the Zuiko Digital ED 12-60mm F2.8-4.0 SWD as one of the finest lenses of its type currently available from any manufacturer.
Now I own both these lenses.
Old 13th October 2008, 10:42   #2913
Thanked: 160 Times
@Samurai, CONGRATS!
Where did you buy it from? What was the price?
Torqy is offline   Reply With Quote
Old 13th October 2008, 12:00   #2914
navin's Avatar
Thanked: 3,642 Times
Originally Posted by married2speed View Post
Also, wanted to check if it's possible to clean the shutter of a P&S like in that of a DSLR. I think it's more or less moisture. However, Would be taking it to the canon service camp on the 16th. .
That was in 2007 right?
http://www.canon.co.in/images/e_mail...on_Mumbai_.jpg
navin is online now   Reply With Quote
Old 13th October 2008, 13:03   #2915
Hi Navin
Canon is holding a service camp this year too. Got this in the mail
Old 13th October 2008, 14:59   #2916
StarScream's Avatar
Thanked: 627 Times
Originally Posted by Steeroid View Post
Got rid of the 18-200 anyway - got a good exchange with a 70-300 VR which should help with situations where I need the zoom, will use the 10-20 Sigma and the 50mm Nikkor for other purposes.
congratulations on the new lens - hope you are happier with it than the 18-200. Nikon did make some 18-200 lemons, perhaps you got a bad piece. BTW, just curious, did you try that shot with the correct settings? Im wondering if you were still unhappy with the results?
StarScream is offline   Reply With Quote
Old 13th October 2008, 15:17   #2917
yogisays0909's Avatar
Thanked: 156 Times
Default Help me guys
Originally Posted by yogisays0909 View Post
Confused between two models the Canon G9 and Panasonic Lumix TZ15.
Has any of you used these cams.
Cost G9 : 25500 INR (Appx 2000 SAR)
PanaSonic : 18500 INR (Appz 1500 SAR)
Which One to go for, Will buy in Saudi Arabia.
No reply ! Come on guys i have just 1 week in hand!
yogisays0909 is offline   Reply With Quote
Old 13th October 2008, 23:02   #2918
Samurai's Avatar
Originally Posted by Torqy View Post
@Samurai, CONGRATS!
From Amazon.com, I paid about US$788 I think, it is already couple of months since I bought, it came to India only this week.
Old 13th October 2008, 23:13   #2919
Thanked: 1,439 Times
I did, still unhappy. Got a few shots with the 50mm which were sharp and nice, but now I need to wait for that shot all over again.
Steeroid is offline   Reply With Quote
Old 13th October 2008, 23:28   #2920
absynthguzzler's Avatar
Thanked: 223 Times
Name:  2135213646_0a17f56436_b Small.jpg
just noticed this photo on this thread , Whats the settings apart from shutter speed and a shaky hand to an extent, that's used to capture night lights in this form?
ISO,Aperture,shutter speed.. is there a difference in settings again when it comes to capturing moving lights or stationary lights.I'm always confused with the balance between ISO and aperture settings.
PS: Just bought myself a FZ18 and its my first camera with manual options. It aint a DSLR but its got what I'd like to start off with learning.
absynthguzzler is offline   Reply With Quote
Old 14th October 2008, 10:39   #2921
kb100's Avatar
Go for the Canon G9 - Its an excellent camera according to most reviews.
kb100 is offline   Reply With Quote
Old 14th October 2008, 10:43   #2922
Thanked: 156 Times
Bought it finaly.Yes the G9 as the G10 is expected to come in December
Old 17th October 2008, 17:16   #2923
Thanked: 22 Times
Default Need guidence
hi everyone
There is a Nikon F65D kit for sale. Which includes the following:
1) Nikon F65 D body
2) 28-80 Nikkor lens
3) 70-300 Nikkor telephoto lens
4) UV & Polaroid filters for both the lenses
All the above for 8.5K negotiable. Its a five year old set. The owner claims to have used it for 60 - 70 rolls in total.
Though I am not interested in the SLR, I would like to buy a used DSLR(I think I should buy Nikon only)
So is it worth buying the above set and which Nikon DSLR(used) should I look at. Note that I am just a beginner in Photography. I have been using a Fuji S5100 for some time.
I have not fixed my budget(I am a bit tight on budget). What model Nikon(body only) I should look for and how much?
Also, how much can I get for my Fuji S5100. It was bought in May 2005 for $320 and the last image reads as DSCF6532. It was bundled with a 16MB XD card but bought a 256MB XD card(they were a bit expensive back then - $60 for 256MB). Also bought a camera bag (paid $15). We got an 55mm adapter ring along with the camera, which according to the manual can be used to fix converters.
PS: I would like to keep this one (if bought) for around a year or so and later upgrade.
kkr2k2 is offline   Reply With Quote
Old 17th October 2008, 18:06   #2924
Thanked: 22 Times
Originally Posted by kkr2k2 View Post
Also, how much can I get for my Fuji S5100. It was bought in May 2005 for $320 and the last image reads as DSCF6532. ....
this is a pic I have taken on 14th of this month with the above mentioned camera:
The Digital Camera Thread: Questions, discussions, etc.-moon.jpg
Thanks to the 10x optical zoom it offers i could take the pic. The image has been cropped to show only the Moon. The pic was taken with out a Tripod with the support of railing.
Old 17th October 2008, 18:20   #2925
gopz's Avatar
hi everyone
1) Nikon F65 D body
All these for just Rs.8.5K ???
Seems to be a super duper deal (or the owner doesnt know the value of the items)
gopz is offline   Reply With Quote
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
