Old 24th August 2010, 11:24   #4081
SPARKled's Avatar
Thanked: 283 Times
Originally Posted by Rahulk76 View Post
Guys
Facing issue with FZ35
When the still images are taken and then enlarged to 100%, there is lots of noise. This is same with any pic i am clicking no matter full daylight or what.
The video is good.. No issues at all.
Is it time to get it checked.
PS: Have tried each and every setting. To rule out handshake, even have used the tripod.
Attachment 410989
Kindly click here to download the 3 mb file of the same
Please advise for next steps
As the MPs are growing the small sensors that all the p&s cameras have will surely exhibit noise. What i see in your picture is pretty normal for a 100% crop of a high megapixel p&s camera. Also avoid auto ISO and shoot at the lowest ISO that you can.
SPARKled is online now   Reply With Quote
Old 24th August 2010, 11:37   #4082
tsk1979's Avatar
Thanked: 15,406 Times
Always use ISO 80. Even then there will be a hint of noise(as with most small sensor cams), but nothing you would really notice.
Old 25th August 2010, 09:13   #4083
Thanked: 94 Times
Default Sensor size vs Megapixel
A question to tsk and other photography experts:
What if i take a a 8MP picture in a 14MP camera? Will the noise be lesser than taking a 14MP picture on the same camera?
I feel a 6-8 MP picture is good enough for regular viewing on a PC/TV and printing purposes. Unless your want to crop off 90% or take printouts measuring in feet.
m8002? is online now   Reply With Quote
Old 25th August 2010, 09:37   #4084
Blue Thunder's Avatar
Thanked: 328 Times
Arrow
... and compare FZ40 va FZ100, every things seems to be the including the LENS system...
The LENS (the physical device) is the same in both FZ40 and FZ100, but the sensor (the device behind the lens which converts the light into electronic form) is very different in both : the FZ100 has a MOS sensor, which the FZ40 doesn't.
Blue Thunder is offline   Reply With Quote
Old 25th August 2010, 10:56   #4085
SPARKled's Avatar
Thanked: 283 Times
I guess that would depend on the camera and the way it is using the pixels to reduce resolution. Say if you are using a D700 the lower resolution at DX image circle is obtained by cropping the image which actually does not use the pixels in the area outside the DX image circle. So in this case the center DX pixels are still operating normally so there will not be any improvement in noise due to lower resolution in this case.
In normal full sensor usage but at lower resolution, fewer pixels are being utilized thus allowing greater space between sensor pixels which I think reduces sensor noise. But this also reduces image size so thus contains lesser data which even if you take a 100% crop of will be much smaller size than the original full resolution crop so making comparisons pretty much useless. But yes visible noise will be reduced in this case.
Old 25th August 2010, 11:04   #4086
tsk1979's Avatar
Many compact cameras, which offer lower resolution high ISO mode(for example max 6MP at 6400ISO for a 12MP cam), use something called pixel binning, i.e. combining output from 4 pixels into one super pixel. In reality, it gives only marginal benefit.
If you really want to use the benefit of lower resolution, you can simply take the pic at max mp possible, and then resize it in PP after doing noise reduction.
Noise reduction algorithms will rob image of detail, and when you downsize to 8MP from 14MP(scale image using one of the scaling algorithms, you will get better detail).
Think of it this way, even a high noise image(14MP) when viewed in small size on your screen(1600x1200), it appears noise free, when you look at it 100%, you see all the flaws.
Old 26th August 2010, 23:36   #4087
Ranjimso's Avatar
Thanked: 19 Times
Default Olympus SP800 UZ
Guys - I wanted to check if anyone here is using a Olympus SP800 UZ - a friend of mine is in the US and I would want to get this from there.
Would help me much if you let me know the pros and cons of the camera and approximate cost of the same here in India.
Also, tips on how to avoid customs will be helpful...
Ranjimso is offline   Reply With Quote
Old 26th August 2010, 23:41   #4088
Samurai's Avatar
Thanked: 13,487 Times
Hand carried cameras don't attract custom duties. I have carried enough cameras via customs to know that.
Old 27th August 2010, 15:10   #4089
chevelle's Avatar
Thanked: 502 Times
While i won't be able to help you regarding the camera since i haven't used it, i would like to tell you that its easy to get camera from USA.
Your friend just needs to carry it with himself/herself. Get a camera case to avoid damage and put it inside and carry it on the shoulder. I have carried two cameras and one camcorder without raising any question. So it should be peanuts for your friend.
The other accessories like the box, cd, manual can be carried inside the check-in bag. The box needs to be fold flat in order to avoid any questions.
chevelle is offline   Reply With Quote
Old 27th August 2010, 20:47   #4090
Ranjimso's Avatar
Thanked: 19 Times
Thank you guys for the suggestion!
Old 29th August 2010, 17:29   #4091
mail4ajo's Avatar
Thanked: 213 Times
Fuji HS10 price dropped to 24K, makes it a good buy now. Any specific reasons to keep away from the cam?
mail4ajo is offline   Reply With Quote
Old 29th August 2010, 17:46   #4092
alter.e.go's Avatar
Thanked: 46 Times
No specific reason ( that I know of anyway)
Remember image sensor wise - its still and P&S in a SLR body.
Buy it only if you really want the extra zoom,else there are cheaper options in the P&S world.
alter.e.go is offline   Reply With Quote
Old 29th August 2010, 17:51   #4093
ampere's Avatar
Thanked: 8,165 Times
Originally Posted by Zenster View Post
Hey Amp, Sorry to confuse you mate. What is meant was they (FZ40 and FZ100) may look similar in specs of their Lens but the lenses are actually functionally completely different. I donno if i make snese, but here are a few links if you wanna read-up. I hope some of the experts from our forum can help me explain this to you .
CCD and CMOS sensors | DigicamGuides.com
Thanks guys. Any reviews of the FZ100?
Old 29th August 2010, 18:43   #4094
lloydofcochin's Avatar
Thanked: 180 Times
Here are a couple of them - Panasonic Lumix DMC-FZ100 Review | PhotographyBLOG
Panasonic Lumix DMC-FZ100 Review | Compact Digital Cameras | CNET UK
lloydofcochin is offline   Reply With Quote
Old 30th August 2010, 16:28   #4095
I need to buy a point and shoot for my wife. We already have a DSLR, so need suggestions on a camera that is:
1. Easy to carry.
2. HD Video recording.
3. Good image quality.
4. VFM.
Thinking of a 12 MP camera. So far biased towards the Panasonic Lumix cameras:
DMC-F3 and DMC-ZR3.
I came across a deal for the DMC-F3 @ $75 (Used camera)
Website: B&H Photo Video Digital Cameras, Photography, Camcorders
Can you guys give your inputs on the same? Also, can you advice any place online where I can get good deals for cameras in the US.
Thank you!
ahwajid is offline   Reply With Quote
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
