Old 8th February 2011, 21:45   #4471
lohithrao's Avatar
Thanked: 163 Times
Default Re: The Digital Camera Thread: Questions, discussions, etc.
tOn, yes am not in hurry at the same time want to pic a cam which i will stick on for a while.
with Dslr the cost of lenses am not sure how many lenses i will be able to buy, so with these confusions i better wait
Originally Posted by typeOnegative View Post
@lohith:
If you are not in a hurry it is always better to wait.
If I have to own one camera it would have to be a DSLR. I am happy with the D90 but do not have the finances to have all the lenses. Therefore the HS10 stays on. However, I have decided to keep all my cameras including my Canon film SLR. One never knows what one would like to try.
lohithrao is offline   Reply With Quote
Old 8th February 2011, 22:40   #4472
vivekiny2k's Avatar
Thanked: 184 Times
Originally Posted by lohithrao View Post
if you are to own just 1 camera what will you prefer?
This is going to be your only camera (you have none right now) and still you are not in a hurry?
ok, you can argue that it was a hypothetical question.
vivekiny2k is offline   Reply With Quote
Old 8th February 2011, 23:08   #4473
typeOnegative's Avatar
Thanked: 20 Times
@lohith:
Kind of agree with vivek here. If lenses are your concern, then stick to a superzoom. As you have mentioned earlier that you like to be mobile, look at models that you can carry in a bit jacket pocket atleast. If you are travelling around a bit, I envy you as travelling is what gives you a lot of images to capture. Do not worry too much about the camera as there a number of competent cameras in the market and whichever one you choose should keep you happy. Upgrade when and if you feel like.
typeOnegative is offline   Reply With Quote
Old 8th February 2011, 23:18   #4474
gopinathann's Avatar
Thanked: 20 Times
Great pics.
FZ100 has manual mode, the reason to use this setting is to increase the level of detail of the subject.
I tried the following shot but the picture is not sharp and doesn't have much detail.
The Digital Camera Thread: Questions, discussions, etc.-p1020170_filtered_filtered.jpg
The following pic was taken with FZ100 but has lot of detail.
The Digital Camera Thread: Questions, discussions, etc.-dragonfly.jpg
Why do you have to do so much? The FZ100 has a full manual mode correct? You can manually set Aperture and Shutter speed, focus manually and then take the shot. The following shots were taken by me with a FujiFilm HS10 in full manual. Whatever PJBiju and kkr have said is correct. A bit of shuffling around will get you your shot. Nothing beats manual for close up shots. The only downside is that your subject has to be cooperative. With a flower you will not have any problems except the shaking due to breeze.
Dragon Fly by I want my screen name, on Flickr
Flower (Macro) by I want my screen name, on Flickr
gopinathann is offline   Reply With Quote
Old 9th February 2011, 00:07   #4475
Thanked: 20 Times
@gopi,
even manual can give you the same amount of detail. I shoot in RAW and then adjust contrast and saturation. The FZ100 is capable of the same if I am not mistaken.
The second picture is awesome. Did you take that?
Old 9th February 2011, 01:28   #4476
dhanushs's Avatar
Thanked: 4,473 Times
@ gopinathann , what is the aperture setting in the 2nd pic?
Old 9th February 2011, 09:24   #4477
lohithrao's Avatar
Thanked: 163 Times
Vivek & tOn, i do have a camera now(KodalDX6490) presently but it seems to have some issues.'
Issue is these equipments cost peanuts if you want to dispose it in the future so wanted to be sure what i pick... just waiting for the HS20 once i have a look at couple of reviews then am all set
Old 9th February 2011, 17:20   #4478
Thanked: 20 Times
@gopi,
Both pics are from FZ100, but the second pic I took it from dpreview forum. Inspired by the pic I tried the same and ended up in the first pic, which I want to improve on it by changing the setting.
Old 9th February 2011, 18:47   #4479
Thanked: 20 Times
Trust me, try manual. You can practice focusing on household stuff and then move onto the bugs. With auto settings you are at the mercy of the camera which can get fooled in tricky light settings. tsk1979 was raving about the manual controls on the FZ. You can ask him.
Old 10th February 2011, 20:45   #4480
Thanked: 20 Times
Got some improvement after using spot focus and some other settings, yet to try manual focus.
The Digital Camera Thread: Questions, discussions, etc.-p1020255_filtered.jpg
Old 10th February 2011, 21:00   #4481
Thanked: 20 Times
@gopinathann,
You have got the depth of field right. Only, what was your subject? You would see one more disadvantage of trusting the fully auto mode -> the overexposure on the knob. In comparison part of the black surface is well focused and clear. It is a bit difficult at first, but play with the following variables:
1. ISO - keep this as low as possible as the sensor size is small
2. Aperture - keep this as wide as possible if the subject is not well lit
3. Shutter speed
The camera should indicate to you when all three parameters are in harmony. In the HS10 the numbers showed on the EVF go to a shade of green/blue if things are fine else they are red. Focus carefully till you are satisfied. If you have a tripod it is even better.
Old 10th February 2011, 22:13   #4482
tsk1979's Avatar
Thanked: 16,016 Times
For macro its best to use manual focus. The MF assist is brilliant on the FZ
Old 10th February 2011, 22:38   #4483
Thanked: 20 Times
Thanks for you suggestions. I wanted to focus on the knob and I notice that it is overexposed in some area. Next time I will use the Exposure lock and manual focus.
@gopinathann,
3. Shutter speed
Old 10th February 2011, 22:40   #4484
W.A.G.7's Avatar
Thanked: 792 Times
Exclamation EOS600D and EOS1100D
Well, I just read on dpreview, that Canon has announced EOS600D and EOS1100D. Preview links are Canon EOS 600D Hands-on Preview: 1. Introduction: Digital Photography Review and Canon EOS 1100D Quick Preview Preview: 1. Introduction: Digital Photography Review.
Any idea when they will be available in India? Would it be better to get one of these abroad itself?
W.A.G.7 is offline   Reply With Quote
Old 12th February 2011, 01:19   #4485
ExtremeTorque's Avatar
Thanked: 20 Times
A well known camera dealer in Hyderabad, Chimalgi, tells me that it will take a month for the 600d and 1100d to hit the Indian market. If buying abroad you might want to consider buying the India/International warrenty, additionally.
ExtremeTorque is offline   Reply With Quote
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
