Old 14th May 2007, 14:24   #541
Thanked: 13 Times
Originally Posted by vid6639 View Post
aaargh vid why did you have to do that!! Even though Im buying it in s'pore the s5 would stretch the budget... I was hoping on a fat discount for the s3 now that the upgrade is out !
Old 14th May 2007, 15:57   #542
mobike008's Avatar
Thanked: 8,249 Times
How does the S5 and S3 costs?
Old 14th May 2007, 20:37   #543
Thanked: 13 Times
Originally Posted by Zappo View Post
Entry level D-SLRs like Nikon D40 and Canon's Rebel XTi are now available at very lucrative prices, and they come with kit lenses. The kit lenses are very good for regular amatuer usage.
Btw... S3 IS or any other such super zooms can not beat an SLR when push comes to shove. So think about it.
This sounds tempting.
Old 14th May 2007, 20:46   #544
Samurai's Avatar
Thanked: 15,704 Times
Originally Posted by Surprise View Post
I did went through the above link before deciding on the purchase. There both min and max shutter timing was mentioned as "unknown"
Shutter timing is shutter speed. The shutter lag is not part of specification, it is just a trait. The reviewers may mention it, the manufacturer won't.
Yeah, dSLRs are tempting, but dSLRs won't take videos or let you frame using LCD. If you are considering VFM dSLRs, do consider Olympus, it is much more bang for the money. If on the hand you are planning to buy pro-level equipment in future, then Canon/Nikon is a good idea.
Old 15th May 2007, 14:14   #545
tsk1979's Avatar
Thanked: 16,016 Times
Thanks Samurai.
Issues with my camera
1. Blurred image (90% of shots taken)
2. Shutter timing
Any samples?
Post with exif file (Info about shutter speed, aperture etc.,).
You can get exif data displayed in any image viewer like faststone etc.,
Old 15th May 2007, 17:35   #546
HellwratH's Avatar
Thanked: 57 Times
Any samples?
Well,
You can get the exif data without any software if you are using Windows Xp. Save the image on your computer, right click on the image, properties, summary, advanced. And you have all the EXIF data you need and also the camera used and other things.
HellwratH is offline   Reply With Quote
Old 15th May 2007, 17:40   #547
tsk1979's Avatar
Nope, you can't if the user has used "Save for web". You don't need windows XP to see exif, you can see on any system
The problem is many image editing software strip out the metadata.
Old 15th May 2007, 20:05   #548
Surprise's Avatar
Thanked: 269 Times
Any samples?
[img=http://img49.imageshack.us/img49/6881/sample1hz8.th.jpg]
[img=http://img443.imageshack.us/img443/3401/sample2eg0.th.jpg]
Downloaded exif, opened the image with exif & uploading the same. Not sure whether this is wat u want.
EDIT: When these images were opened from my system, it diplays lots of info's on image and camera. But upon uploading those details were not seen, pls help
Max aperture value is shows is F2.83
Surprise is offline   Reply With Quote
Old 15th May 2007, 20:13   #549
tsk1979's Avatar
Surprise, the shutter speeds are 1/4 of a sec and 1/6 of a second.
for such focal lengths you need atleast 1/50 of a second to get a stable shot.
So try using the flash, or use a tripod so that the camera is steady while taking the photograph.
I suspect your camera is in some Progam mode where low speeds are being selected irrespective of flash used, i.e. camera is doing metering based on no flash. Switch to complete auto mode and try?
Old 15th May 2007, 20:28   #550
navdeep's Avatar
Try at f8, evaluative metering, ISO400/800, shutter reciprocal of ISO
navdeep is offline   Reply With Quote
Old 15th May 2007, 20:54   #551
tsk1979's Avatar
F8! Its a P&S, shutter of F4 is normal, you will start getting diffraction on such a small sensor if you go to F8. F8 is the minimum aperture possible on most compacts I think.
Old 15th May 2007, 21:25   #552
navdeep's Avatar
okay .. I thought he is trying to get a shot from slr . For P&S go for auto mode and auto flash, usually camera takes care in full auto mode
Old 16th May 2007, 10:20   #553
Surprise's Avatar
Thanked: 269 Times
Default Thanks TSK
Thanks a lot tsk 1979. I did reset the entire settings & now the problem is resolved. After struggling with those poor quality images from my new camera, the results of reset photographs made me the happiest person.
Old 16th May 2007, 11:44   #554
HellwratH's Avatar
Thanked: 57 Times
Yes, you can read exif data on any system, but you would require an image viewer to do so or an exif reader. For ex, I use Win 2000 at office and I cant see the exif data directly with the properties-> summary.
Old 16th May 2007, 14:18   #555
tsk1979's Avatar
Why, even on my machine here(its not XP/2000 etc.,) I do a "right click-> Properties and see the exif info.
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
