Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 20th November 2007, 12:54   #1441 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
I'm going mad!
After a point in time (read age) too much thinking doesn't really help.
With your choice of 24-105/4 and 100-400/4.5-5.6 thinking is over.
You'll get to know about damage before 4pm today.
Old 20th November 2007, 12:56   #1442 (permalink)
Team-BHP Moderator
tsk1979's Avatar
RAW takes forever? I think most cams can do 3-5fps in raw, atleast for short intervals. Canon performance is not bad. Out of box jpeg in canon is good too.
The 16-35F2.8L costs 640$ and is really and amazing lens. What it lacks is IS.
40D + 16-35 F2.8L is a great lens for you. Push the ISO to 800 and you can manage without IS.
The 40D will touch ISO 1600 and yet give you large prints.
that said the Pentax K10D + the 16-45mm lens will cost you around 1150$.
But right now both pentax and Oly have limited lens space in the digital space.
I suggest you first find out what shutter speeds you will be doing at ISO 800.
what do you want to shoot? Is it a studio. Can you use a tripod?
__________________
Reclaiming.....!
Old 20th November 2007, 14:46   #1443 (permalink)
Team-BHP Moderator
navin's Avatar
I will use an SLR for the following applications:
1. birthday parties, family birthdays/anniversaries, etc where lighting can be varied (from candle light like when a cake is being blown out) but lighting is never as good as the outdoors. hence the need for a FF equivalent of 24-70/2.8 IS. Ths IS so I can use wider apatures and slower shutter speeds and still hand hold. Photos will be at night, indoors and subject might be moving.
2. school sports and plays (theater). school sports will be daylight and out doors most of the time, plays are indoors but alteast the subject is resonably well lit. I need a light telephoto zoom from my past experience 300mm is not tall enough but the 70-300/4-5.6 IS on a 1.5/1.6 crop should do it. I mgiht be able to use a tripod as well (it depends).
for most other purposes (travel) I would prefer a mini digicam like the canon 860 IXUS (28mm, IS and under 200gms) or a video cam.
On a 40D 24mm is about 38mm on a FF. I was playing around with the Nikon D80 and Canon 20D and found that with kids I was shooting a lot of stuff at 28-35mm and i would have gone wider but the lenses I had did not let me.
Kids at a birthday party dont sit still (actually I should say Kids dont sit still). Indoors in small apartments 38mm does not give me enough room to catch 3-4 of them in action and one does not have time to change lenses. If I put a 16-35/2.8 on the camera I will be covering 26-55mm it could work indoors (I would have to crop some photos) but it'd be tough and I'd still get a 3 lens (16-35, 24-70 and 70-300) solution which pushes the budget ($1300 for the body, lens for $640, $1060 and $530 respectively).
So far the long end does not seem to be the problem, the wide-normal fast telephoto is the issue.
option 1. wait for Canon FF bodies to drop in price (y which time canon would have an IS version of the 24-70/2.8 lens)
option 2. get a system that allows me the full frame equivalent of 24mm (12mm on the Olympus's 4:3, 15mm on Canon's 1.6 crop, 16mm on Nikon's 1.5 crop).
Any solution from Canon's stable? Below are the lenses I have investigated without luck.
Canon Europe - Image Stabilization Lenses
__________________
Scixelsyd Etinu
navin is online now   Reply With Quote
Old 20th November 2007, 15:07   #1444 (permalink)
Team-BHP Moderator
tsk1979's Avatar
You need a shutter speed of around 1/30. I can get that shutter speed easily at F2.8. Infact even if you have IS, moving subjects will be blurred. So For that all you need is F2.8 and bump to ISO 800.
I suggest you pay a visit to a canon owner(350D/400D etc.,). Open the kit lens at its widest(F3.5) and bump to ISO 800. you will see that in indoor lighting you will get speeds of 1/30 or faster.
2. school sports and plays (theater). school sports will be daylight and out doors most of the time, plays are indoors but alteast the subject is resonable well lit. need a light telephoto zoom from my past experience 300mm is not tall enough but the 70-300/4-5.6 IS on a 1.5/1.6 crop should do it. I mgiht be able to use a tripod as well (it depends).
In the zoom space the 70-300mm IS will do, but I would recommend a 70-200L-IS, or the 100-400L IS.
This will push your total budget of lenses+body to 3000$ but you can cover almost everything.
[/quote]
Kids at a birthday party dont sit still (actually I should say Kids dont sit still). Indoors in small apartments 38mm does not give me enough room to catch 3-4 of them in action and one does not have time to change lenses. If I put a 16-35/2.8 on the camera I will be covering 26-55mm it could work indoors (I would have to crop some photos).
For wide angle even the 10-22mm is a great lens, and then there is the sigma 12-24mm too, but you don't need to go that wide, the 16-35L is an amazing lens and with F2.8 as the aperture you can get shutter speeds of 1/30 or faster already.
I do not have a F2.8 16mm lens but I have a F3.5. I can light up a subject(lets say the table) by a tubelight from 6 feet away, and meter on that and tell you my shutter speed at ISO800
You are assuming that you need IS for wide angle. If you were going to do nightclub photography, I would say you did need IS, but since you are not I suggest the 16-35L
From your current needs I would suggest the following
Canon 40D body = 1300$
Canon 16-35L F2.8 = 640$
Canon 70-200L F4 IS = 550$
If you want to go to 100-400L IS then the cost of the lens is 1300$
If you are missing an all time zoom then get the sigma 17-70 for around 360$
Total cost
2900$ for 40D+16-35L+70-200L+Sigma
3600$ if you take the 100-400L instead of the 70-200L. But I think 1.4x extender+ 70-200L will make a better deal.
__________________
Reclaiming.....!
Old 20th November 2007, 15:12   #1445 (permalink)
Team-BHP Moderator
Samurai's Avatar
Nikon D80 with their 17-55 and 70-300 ($800 body mated to $1800 of lenses) or Oly E3 with their 12-60 and 70-300 ($1700 body mated to $1200 of lenses)!
You are comparing D80 with E3? That's like comparing Swift with Skoda RS. Anyway, the reason I am considering E3 is exactly same as yours, I need lowlight handheld shooting ability. E3 can focus instantly at lowlight, provide noise-free high ISOs and provide 4-5 stop IS advantage. Since I have many Zuiko lenses, it is no brainer for me. But I don't envy your position.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 20th November 2007, 15:18   #1446 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Actually for a fresh start the Oly E-3 covers Focal length of 24mm-600mm in just 2900$. I guess for Navin, its a good idea if the 40D idea does not appeal to you.
__________________
Reclaiming.....!
Old 20th November 2007, 16:09   #1447 (permalink)
Team-BHP Moderator
navin's Avatar
You need a shutter speed of around 1/30...So For that all you need is F2.8 and bump to ISO 800.
In the zoom space the 70-300mm IS will do, but I would recommend a 70-200L-IS, or the 100-400L IS... the 16-35L is an amazing lens and with F2.8
Total cost
1. i did use a nikon d80 and canon 20D with IS/VR lenses. what I realised that with IS I could hand hold till 1/15 and hence keep the apature wider and shoot in lower light
2. the 70-200/4 IS is $1000 not $550. For $550 you get the non-IS version and then the 70-300 makes more sense. IS+100mm more range.
3. I prefer Canon becuase they have more service centers in India.
4. If I get the 16-35 and 70-300 what do I do between 35 and 70mm? 3rd party lenses do not interest me. I dont mind a small gap say 55-70 or 60-70mm but 35-70mm is big.
Only part of this that does not appeal to me is that I spend 60% on the body and 40% on 2 lenses.
Anyway, the reason I am considering E3 is exactly same as yours, I need lowlight handheld shooting ability. E3 can focus instantly at lowlight, provide noise-free high ISOs and provide 4-5 stop IS advantage. Since I have many Zuiko lenses....
I am comparing systems.
D80 with 17-55 and 70-300 with E3 with 12-60 and 70-300 with 40D with 17-55 and 70-300. All 3 come in under $3K. Why? the Sony A-700 with their 16-80 and 75-300 lenses (total of 2.2K) was also an option but i'm told the 75-300 is a dog.
Nikon: The D80 is an older machine.
Canon: The 17mm on 1.6 crop is too tall (28mm)
Oly: waiting for E3 prices to fall 20% and make the lens/body price ratio "more level" also what about service?
Samu, which Zuiko lenses do you have? Have you tried their 70-300 vs it's "NikCan" counterparts?
__________________
Scixelsyd Etinu
Old 20th November 2007, 16:17   #1448 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Olympus may be new in the arena of DSLR in India, but I doubt they will fall short on service. I think waiting for E-3 prices to fall is a good idea.
As for spending so much on body, its a great body. With the 12-60mm you don't need a point and shoot any more, make this your primary cam.
As for third party lenses, the 17-70 is actually a good lens and has got rave reviews.
you can go the other route also.
1. Canon 10-22mm
2. Canon 17-85
3. Canon 70-200F4 L IS
But you will not get IS at wide angle.
Since you are really hooked to IS, in body IS makes more sense in the long term.
__________________
Reclaiming.....!
Old 20th November 2007, 16:34   #1449 (permalink)
Team-BHP Moderator
Samurai's Avatar
That is because with Olympus you are buying a superb body (60%), one high grade lens and one standard lens.
The E-510 prices have really crashed since E3 was introduced. But I don't know when E3 prices will drop 20%, going by history of Olympus bodies, it usually takes 6 months, is the wait worth the 20% reduction?
I have the following:
Olympus 14-54mm F/2.8-3.5 Zuiko ED
Olympus 50-200mm F/2.8-3.5 Zuiko Digital Zoon Lens
Olympus 40-150mm F/3.5-4.5 Zuiko Digital Zoom Lens (retired)
Olympus Zuiko 50mm f/2.0 E-ED Digital Macro Lens
Olympus Zuiko EC-14, 1.4x E-ED Digital Tele Converter
Olympus EX-25, 1:1 Macro Extension Tube
__________________
Samurai
Old 20th November 2007, 16:41   #1450 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Why does the E-3 do only 30 minutes in bulb mode?
Noise issues? Or battery life issue?
__________________
Reclaiming.....!
Old 20th November 2007, 16:51   #1451 (permalink)
Team-BHP Moderator
Samurai's Avatar
Dpreview says 4 hours: Olympus E-3: Digital Photography Review
__________________
Samurai
Old 20th November 2007, 16:54   #1452 (permalink)
gkrishn's Avatar
If you go for canon, suggestion would be
1. 1x-2x (10-22canon, 10-20sigma, 12-24 tokina) price ranging from 500 to 680$
2. 50/1.8 (80$)
3. 70-300IS/70-200f4L (550$)
Any reason why you are not looking at 400d(570$)? With 400d, this kit should cost approx around 2000$. You can even get a external flash(430ex - 240$) in this budget.
__________________
In the Indian system of education, it is only a technique of cramming, retrieving and reproducing.
gkrishn is offline   Reply With Quote
Old 20th November 2007, 17:00   #1453 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Cant find link to oly stats. Some sites say 30 minutes!
__________________
Reclaiming.....!
Old 20th November 2007, 17:05   #1454 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Ok did some googling. there is a 8 minute default bulb mode, and a 4 hour bulb mode in E-3
__________________
Reclaiming.....!
Old 20th November 2007, 17:08   #1455 (permalink)
Team-BHP Moderator
Samurai's Avatar
I have the E3 manual in PDF, it confirms.
BULB TIMER
This enables you to select the maximum time (in minutes) for bulb shooting (A) from 1 to 240.
__________________
Samurai
Thread Tools
The Mobile Phone Thread - Queries, decisions, discussions all here. ravi_28_8 Gadgets, Computers & Software 3678 21st August 2008 12:34
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Digital Camera Reviews (around Rs. 20,000/-) naveendhyani Gadgets, Computers & Software 107 10th July 2006 12:32
Powered by vBulletin
