Old 19th August 2008, 14:32   #196
Thanked: 67 Times
Originally Posted by revvedup View Post
finally got everything home
AMD Athlon X2 5000
Gigabyte 780 G chipset mobo
OCZ 800 MHZ 1 GB* 2 DDR 2 RAM
Cooler Master E- LITE Cabinet with Cooler Master 390 W Power Supply
Cooler Master - Ultimate provider of Computer Chassis | Cooler | Power Supply
WD Caviar Blue 160 GB SATA Hard Drives ( WD1600AABS )
(I am a little unhappy about this as it only has 2MB Cache)
But overall a VFM setup @ 15.5 K
Thanks to LBM for helping me and answering all my queries on the phone(as well as talking to the vendor himself to clear things out) and Greenhorn for providing online support.
Thats a good deal man!
I spent the same amt on a X2 4000+,2GB 667, Asus 690G HDMI, 250GB HDD,Liton dvd-r, iball micro-atx last december.
780G drooool.cheers:
Blue_V is offline   Reply With Quote
Old 19th August 2008, 15:57   #197
NetfreakBombay's Avatar
Thanked: 352 Times
Originally Posted by Blue_V View Post
Asus 690G HDMI
I am looking at the same motherboard.
Have a query. Did it come with a raiser card for TV Out?
Like this one:
Old 19th August 2008, 16:53   #198
navin's Avatar
Thanked: 3,922 Times
Originally Posted by greenhorn View Post
thats a minimum system requirement
But those requirements are (again).
this thread was interesting
you mean to say I should get Nero 8 Ultra over Pinaccle Studio Plus 12?
Old 19th August 2008, 17:04   #199
greenhorn's Avatar
Thanked: 1,413 Times
I would not say get, but just to say there was another alternative.
I'm not sure if the trial versions of either allow this functionality, If it were me , I would just try the full versions out both before buying either
Old 20th August 2008, 12:06   #200
navin's Avatar
why the link? any comparision of Nero 8 vs Pinaccle Plus 12?
Old 20th August 2008, 13:33   #201
greenhorn's Avatar
Well, if the wink wasn't hint enough, Some things you don't say outright in a public forum
The trial versions of the mentioned programs arent fully functional, and the only way for most people to try out the full full functionality before purchasing one would be .......
I googled a bit , and came up with this post Panasonic 3CCD User - View Single Post - Editing AVCHD footage in NLE
this is a comparison with studio 11 though
Old 20th August 2008, 14:25   #202
Thanked: 67 Times
Like this one:
Attachment 40074
yes, it has.
But i suggest you skip the board if you plan to use HDMI. Switching to HDMI to be done in BIOS
I think the 780G runs directly HDMI from Windows. Find out.
Old 20th August 2008, 16:17   #203
Thanked: 352 Times
^^^ Thanks for the info. TV that I have in 12 years old 29 inch CRT. It does not have any digital port so non-HDMI is fine.
Ont more question, does TV Out work in parallel with VGA / DVI? I.e. in Like dual monitor setup?
Old 20th August 2008, 20:39   #204
navin's Avatar
Ok this is what has happened so far.
1. I got hold of a Trial version of Nero 8 (my computer hardware supplier tells me that some DVD writers come with Nero 8 so he has given me a CD)
2. MY PC supplier quoted me 69K for the hardware.
3. Pinacle 12 is not available (officially in Mumbai) so I emailed Pinacle saying that I want to use ver 12 but only ver 11 is available locally and if they dont reply or tell me where to get a official copy of ver 12 I will be forced to use a bootleg version as ver 11 (to the best of my knowledge) is not AVCHD compatible. I hope that gets their attention.
Old 20th August 2008, 20:52   #205
Rotorhead's Avatar
Thanked: 21 Times
anyone have any info on computer service guys who could come home for servicing my comp which suddenly refused to boot up, the monitor just keeps blinking even after the cpu is switched on. Think somethings wrong with the motherboard. I stay close to NGN at koramangla. Any help is highly appreciated. If you can let me know of a good servicing place close to NGN even that should suffice.
Rotorhead is offline   Reply With Quote
Old 20th August 2008, 22:28   #206
greenhorn's Avatar
What is usually given out as OEM is Nero 8 essentials. What you need is Nero 8 ultra. I think it has a 15 day trial
can we have a split of the quote , I'm interested in how much he's asking for the 8800.
the current bang for buck champion is the Ati Radeon 4850, @ 10~11k
Old 20th August 2008, 22:52   #207
Thanked: 352 Times
That seems to be on higher side (Unless price includes OS as well). Breakup of costs:
Name:  High End PC Price.PNG
Old 21st August 2008, 09:18   #208
Amey's Avatar
Thanked: 189 Times
Attachment 40632
Not a very well configured setup i must say :(
1) Q9550 paired with G33 based mobo ???
2) Q9550 is supposed to run off a unbranded 400W PSU that comes with the cabinet and is capable of delivering max 200W in reality ?
My personal observations,
Its stupidity to buy the Q9550 as of now, the price is not justified.Also it will drop later on drastically.
It makes much more sense to go with Q9450 which is cheaper by almost 12k and the only difference between the 2 is clock speed,everything else is the same.
If one is buying a Quad Core CPU and a dedicated graphics card, i would say going for a X38/X48 chipset based motherboard makes more sense as the quote mentions that there will be 8GB of RAM in the system.
If X38/X48 is out of budget, P35/P45 is also worth considering.
Amey is offline   Reply With Quote
Old 21st August 2008, 09:42   #209
Saiyan's Avatar
Thanked: 20 Times
^Lord, The Q9550 is now around 14.9k only. Lord Nemesis getting one at this price.
Saiyan is offline   Reply With Quote
Old 21st August 2008, 10:13   #210
Saiyan's Avatar
Thanked: 20 Times
Sorry, not able to edit the above post.
These Computer System builders are really disgusting. A cheapo 400w smps as Amey said to power a ssytem Q9550 and 8800GT :S. Do they have any brain for god sake :@. Minimum i would spend for a power supply will be 6k for a Corsair HX620/TX650 or Tagan BZ600. Also a decent cabinet to cool all these components. When will they know the importance of these, suggesting a lame components for people with a sound budget.
Help me config a new system for Music sequencing and Mixing bheem Gadgets, Computers & Software 10 20th October 2008 13:35
ICE config for Palio amitverma In-Car Entertainment 6 10th May 2006 12:42
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
