Old 6th August 2009, 10:13   #511
I got your reply little late. What i bought is
Intel core i7 920
Mobo : MSI X58 Pro
RAM : DDR3, 3 X 1GB crosair
Cabinet : Iball Net-X, Rs. 1500
HDD : Seagate 500GB
Logitech Combo
Sony DVD writer
Palit 6800 1GB DDR2 GSO with HDMI port
SMPS cross air VX550
APC UPS 650 W
Benq Monitor Benq E2220
Altec lensing Speakers
All inclusive 65000 approax
I did not buy the printer for now.
amitbjha is offline   Reply With Quote
Old 6th August 2009, 10:17   #512
lohithrao's Avatar
Thanked: 163 Times
amit, how much did this config cost you?
lohithrao is offline   Reply With Quote
Old 6th August 2009, 10:18   #513
As mentioned above 64-65 K approax
Old 6th August 2009, 10:21   #514
As mentione above 65K approax.
I have some issue with UPS,it failed to start. Any body has some idea.Already lodged a complain with APC
Old 30th August 2009, 23:52   #515
raj_5004's Avatar
Thanked: 2,064 Times
hey guys, one doubt here-
i am not too much into computer hardware, so please pardon my ignorance.
i am about to buy a new PC & budget is 40,000 max.
i am confused between these-
* graphic card-
- MSI 1 GB (Is MSI & nvidia the same?)
- Raedon 512 MB
* processor-
- AMD phenom 9650
- intel quad core Q8200
are the prices of both approximately same?
* monitor (19")-
- LG
- Samsung
motherboard is asus.
Old 31st August 2009, 00:41   #516
aaggoswami's Avatar
Thanked: 1,542 Times
1) * graphic card-
-Raedon 512 MB
2) * processor-
- AMD phenom 9650
3) * monitor (19")-
- LG
- Samsung
4) motherboard is asus.
1) MSI and Nvidia are not the same.
In short, nvidia is GPU ( Graphic Processor Unit ) and chipset manufacturer and MSI is computer hardware manufacturer.
Go for Raedon 4770, it is quite good if budget permits.
2) Intel Q8200 has problems regarding overheating. Had one for project completetion. Later on upgraded to Q8400, but same problem. If you wan too stick to socket 775, go for Q9XXX. But not Q8200 Q8400. I am speaking this from my personal experience. Q6600 is good quad and see if its still avialable or not. If its available, go for it rather than Q8200/Q8400.
AMD Phenom is not a bad option, but go for Black edition. They are better than 9650.
Try to get 9950. It will cost rs. 1500 more approx, but its worth it as it performs better than 9650.
You can also try to get Phenom II but they are slightly on expensive side.
3) Try Benq and dell too. Avoid Viewsonic at any cost.
4) Avoid Asus for RMA issues. Its not having good RMA. MSI and gigabyte have good RMA. If you can lay hands on Biostar, they are quite good too.
Try theitwares.com for getting the approximate prices. This will help a lot.
aaggoswami is offline   Reply With Quote
Old 31st August 2009, 07:03   #517
mithun's Avatar
Thanked: 59 Times
raj_5004 :
Monitor :
Go for ASUS/AOC. Dell sources the monitors from AOC/NEC and re-badges it.
Old 31st August 2009, 07:26   #518
raj_5004's Avatar
My reply in BOLD:
ok i had this doubt since i saw both MSI & nvidia written on the pack!
my budget for graphics card is around 8000-9000.
thanks. i'll check out the Q6600.
will try to get the black edition if possible. also, i heard that the 9650 is not good, so lets see.
no viewsonic here! i think benq is more expensive.
ok, i will keep that in mind.
Originally Posted by mithun View Post
raj_5004 :
Monitor :
is asus better than LG/samsung? at the same time, will it fit in my budget?
i would like to add here that i am more into gaming & that is my priority for my new PC.
Old 31st August 2009, 07:31   #519
mithun's Avatar
Thanked: 59 Times
ASUS MBs are not having any RMA problem.Atleast here in Cochin. But MSI & Gigabyte are equally good.
Asus/AOC is more VFM and is in the same league of LG/Samsung. But make sure that you compare the specs before purchasing.
Old 31st August 2009, 07:47   #520
raj_5004's Avatar
thanks mithun, regarding motherboards, i prefer ASUS as its plant is here in maharashtra & hence servicing becomes easy & quick.
my biggest confusion about the graphic card still remains! i have a budget of 8000-9000 & i am confused between MSI 1 GB & raedon 512 MB.
since i am more into gaming, i heard AMD processors are better than intel.
Old 31st August 2009, 07:51   #521
mithun's Avatar
Thanked: 59 Times
I'm not an expert in GFX cards. So no advice !
But I would recommend AMD processor when it comes to gaming.
Old 31st August 2009, 07:56   #522
raj_5004's Avatar
thanks, so this is what i intend to buy today, until further advice:
Phenom 9650/9950 + Asus (processor + motherboard) = Rs. 8400/-
Keyboard + mouse = Rs. 650/-
Speakers = Rs. 1200/-
Side transparent Cabinet - Rs. 2500/-
500 GB HD = Rs. 2650/-
DVD writer = Rs. 1100/-
4 GB RAM = Rs. 3700/-
19" LCD LG/samsung/asus = Rs. 7200/-
graphics card MSI/raedon/nvidia = Rs. 8500
SMPS = Rs. 4900/-
Total = Rs. 40,800/-
Note- in case of multiple options, the prices refer to the product marked in bold.
Old 31st August 2009, 08:48   #523
aaggoswami's Avatar
As you are decided onto graphics card, I would recommned you Raedon HD 4770. This will cost you around Rs. 8k.
One thing I want to bring in is type of memory they utilize for graphics. Is it DDR2 for 1GB ? I think the 512 MB will be GDDR3 which is faster than th e1 GB version. Here you must also look into which memory.
Raedon HD4870 offers GDDR5, the reason why it is a very fast. Raedon HD48XX has one of the most efficient designs in graphics ( to the best of my knowledge ).
You can also have a look at 9800GT from Nvidia. It is no different from 8800GT. But this car is now VFM below Rs. 8.5k. You can get one with GDDR3 memory for Rs. 7.5-8K. Just inquire about it.
Finally for graphics card :
1) Radeon HD 4770.
2) nVidia 9800GT.
Old 31st August 2009, 10:47   #524
raj_5004-
At this point of time i would recomend Sapphire HD 4850 512mb ddr3 card which u"ll get for around Rs.9000-9300.Its the best VFM card at the moment and futuristic too.Why work fine for next 2.5 yrs or so.
As nvidia is coming out with new cards in september with direct x-11,their is no point in buying 200 series now.
partizan88 is offline   Reply With Quote
Old 31st August 2009, 11:06   #525
greenhorn's Avatar
Thanked: 1,519 Times
If you want a 4850, buy the 4770. same performance, about the same cost, and lesser power consumption = no expensive PSU required
Help me config a new system for Music sequencing and Mixing bheem Gadgets, Computers & Software 10 20th October 2008 13:35
ICE config for Palio amitverma In-Car Entertainment 6 10th May 2006 12:42
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
