Old 8th February 2010, 13:19   #586
IronH4WK's Avatar
Thanked: 3,526 Times
Originally Posted by sj_koova View Post
I plan to stretch my budget a bit to grab the "AMD Phenom II 3.4 Ghz. 965 X4 Black Edition" itself. It has got excellent reviews all over the web.
Since I am already stretching my budget for processor, I will keep the graphics card for the next upgrade. Anyways I do not play much game. I guess the on-board graphics will share the system memory and my plan for 4gig will suffice my kind of requirement.
For movies and music, I use my Panasonic home theater system. So the PC will be purely for applications and photo editing.
I am placing the order today through Binary World. Here is how the pricing looks like,
MB 4AMD GigaByte ATI 785G Chipset MA785GM-UD2H - Rs.7,108
CPU AMD Phenom II 3.4 Ghz. 965 X4 Black Edition - Rs.9,300
Cabinet Cooler Master Elite 335 with CM 500W SMPS - Rs.4,593
Memory DDR II Transcend 2 Gb 800 mhz - Rs.4,032
HDD Seagate SATA 1 TB 32 MB Cache - Rs.4,108
DVD Writer Samsung OEM SATA Black 22X - Rs.1,014
Wi Fi USB Adapter D Link 54mbps - Rs.1,024
Subtotal: Rs.31,179 + 4%VAT = Rs.32,427
Anyone know if I can get it cheaper in SP road, Bangalore?
there's a place called Computer Bazaar in SP road. you might wanna call them up and find out if they'll give better prices. i'll PM you their number.
your config looks good, but i've a few pointers:
1. why are you getting a black edition. the advantage the black edition is that it is a better candidate for overclocking. if you're not going to overclock, you can consider something not black edition and maybe save some money. (for e.g., AMD Phenom X4 945 3.0GHz - you could save upto 2k). also some black editions don't come with CPU fans. if indeed you're getting a BE, make sure it's a PIB (Processor-in-a-Box).
2. you're putting in a quad-core running at 3.4Ghz. it will heat up (specially when gaming photo/video editing) and the 335 looks kinda cramped with just two fans (1x80mm, 1x120mm). you'll see that after putting in all the stuff (PSU, MB, HDD etc.) you'll seriously run out of space to breathe. (attached is the picture i took when i was building my PC. the cabinet is a Antec 900 and is already running out of space after i recently replaced the HD3870 with a HD4870. it has 5 case fans - 3x120mm intake; 1x120mm and 1x200mm exhaust)
3. 500W should be ok for now, but if you intend to put in a graphics card later (or other devices), the SMPS may not take the load. also, the "with the cabinet" SMSPs may not have all connectivity required to upgrade - for example a ATI HD 4870 1GB requires a 6-pin power to be connected to it.
IronH4WK is offline   Reply With Quote
Old 8th February 2010, 13:59   #587
sj_koova's Avatar
Thanked: 143 Times
Thanks IronH4WK. Very valuable inputs.
I will call the SP road guy as well.
sj_koova is offline   Reply With Quote
Old 8th February 2010, 18:22   #588
Sahil's Avatar
Thanked: 1,936 Times
Anyone used/using this one?: HP TouchSmart 300-1000 Desktop PC series specifications - HP Home & Home Office products
Old 8th February 2010, 19:24   #589
IronH4WK's Avatar
Originally Posted by Sahil View Post
not using/used, but looks like a pretty good setup. if you're not gonna be touch-screening too much - avoid this one. upgradability value is zilch.
Old 12th February 2010, 12:09   #590
sj_koova's Avatar
Thanked: 143 Times
It is all done finally. Made slight change from the initial plan on Motherboard to match DDR3 RAM and also considered non-black-edition AMD CPU as suggested by IronH4WK.
Here is the spec.
1x - DVD Writer Samsung OEM SATA Black 22X - Rs.1,014
1x - HDD Seagate SATA 1 TB 32 MB Cache - Rs.4,108
1x - MB 4AMD GigaByte ATI 785G Chipset MA785GMT-UD2H - Rs.6,735
1x - UPS Luminous 600VA Prima - Rs.1,693
1x - Cabinet Cooler Master Elite 335 with CM 500W SMPS - Rs.4,593
1x - Wi Fi USB Adapter D Link 54mbps - Rs.1,024
1x - Windows 7 Home Premium Boxed 32 n 64 bit - Rs.6,056
1x - CPU AMD Phenom II 3.0 Ghz. 945 X4 - Rs.7,676
2x - Memory DDR III Transcend 2 Gb 1333 mhz. - Rs.5,524
Subtotal: Rs.38,423
Assembled everything myself. Took almost an hour for me to fix everything in place. Loaded Windows 7 64bit, and that was another 1 hour for me to put the OS and some of the necessary drivers.
Only one thing is clue less. Even Windows 64bit tells me only 3.5gig is usable out of 4gig. Is it because of display card allocation?
Old 12th February 2010, 13:06   #591
IronH4WK's Avatar
congratulations on your buy!
to answer your question - if you're using on-board graphics then yes, the memory reported available will be lesser than installed as the memory will be shared for the VGA. however, it should report the installed amount of memory correctly (availability vs installed).
go to Start > Computer (right click) > Properties and check how much is Win7 reporting. also, are you sure the copy of Windows 7 that you've acquired is actually a x64? if it is, it will show in the properties, like the attached. also, did you check if the mobo has any memory limitations? does it show 4GB in the BIOS? some mobos don't kinda support x64 without a BIOS upgrade.
you might also want to read up on this article.
Old 12th February 2010, 13:28   #592
sj_koova's Avatar
Thanked: 143 Times
Thank You.
It shows me 4gig installed and 3.5gig usable.
I purchased original Widows 7 box (with 32bit and 64bit DVDs) and installed 64bit.
Motherboard supports upto16gig.
So it should be shared for VGA as I am using on-board graphics.
Old 12th February 2010, 13:34   #593
IronH4WK's Avatar
Thank You.
yes. should you choose to install a graphics card in the future, you can disable the on-board graphics option and that half a GB should be available to the system.
EDIT: you should monitor the temperature of both your CPU as well as the mobo. if its going too high, you might want to consider putting in additional case fans to ensure proper airflow.
Old 12th February 2010, 17:01   #594
aaggoswami's Avatar
Thanked: 1,361 Times
Thank You.
Full memory must be reported. It does so in my C2Q setup.
My setup also has Onboard graphics, but full memory is reported when Windows 7 is installed.
My board is DG41TY.
aaggoswami is offline   Reply With Quote
Old 13th February 2010, 11:14   #595
IronH4WK's Avatar
My board is DG41TY.
are you referring to memory available or memory installed?
try this:
Start > Run > CMD > type systeminfo | find "Memory"
this will let you know how much memory is available out of the installed memory.
Old 23rd February 2010, 15:22   #596
Thanked: 128 Times
I have 5 gb ddr3 ram on my pc, running windows 7 64 bit for the last week, and it shows 1st fig at 5 gb, 2nd fig at 4.99 gb. The third fig is perhaps usable and that usually is 3-4 gb.Have a 256 mb ancient nvidia ddr2 card though. This can be seen in system info.
vasudeva is offline   Reply With Quote
Old 25th April 2010, 18:17   #597
prateekm's Avatar
Thanked: 307 Times
Hi guys! I am planning to buy a desktop since my Sony laptop is in it's last stages (More of that later). My budget is ~37k and I have made the following rig. If you guys have any suggestions, please please and please share that with me
The pc will be used for normal gaming like NFS series, GTA series, Flight Simulator, etc. I would also do some photoshopping on it!
Monitor : Dell S2009W - 6500 rs
Procy : AMD Phenom II X4 945 - 7500 rs
Motherboard : Gigabyte GA-MA78GM-S2H MB - 4200 rs
Graphics : Sapphire HD 4670 1GB DDR3 - 4445 rs
PSU : Corsair vx450 - 3700 rs
HDD : Seagate Barracuda 7200 RPM 500Gigs - 2200 rs
RAM : Kingston DDR2 1*2GB 1*1GB - 2900 rs
DVD : LG OEM SATA Black 22X - 1100 rs
Cabinet : Coolermaster Elite 310 - 1550 rs
Keyboard/Mouse : Logitech Wireless Combo - 1300 rs
Others : Luminous UPS + Fans - 2500 rs
Total : Rs 38000
prateekm is offline   Reply With Quote
Old 25th April 2010, 18:57   #598
Chipz's Avatar
Hi prateek; why dont you check out
Theitdepot - Gigabyte GA-MA785GM-US2H 16GB DDR2
Please refer this thread too
http://www.team-bhp.com/forum/gadget...ration-85.html
With this configuration, why dont you find a mobo which support DDR3.
Chipz is offline   Reply With Quote
Old 25th April 2010, 20:09   #599
prateekm's Avatar
Thanked: 307 Times
Seems like a good mobo, thanks
Err, the main reason is I had a 35k budget for myself and now I am overshooting it. So I don't want more expenses. I had originally planned for a 1TB HDD and 4GB DDR3 RAM. But I heard that the only difference between DDR2 and DDR3 would be transfer speeds, which doesn't matter much to me. So 4GB DDR2 does the trick for me. Also, a DDR3 supporting mobo is more expensive and hence .. :(
Old 25th April 2010, 21:54   #600
greenhorn's Avatar
Thanked: 1,156 Times
those of you thinking about getting a Phenom quad. Nowadays most Phenom Dual cores have 4 fully functional cores, and some mobos let you unlock them
Gigabyte GA-785GMT-USB3 sucessfully unlocked Phenom II X2 555BE - CPU/Mobo Corner | TechEnclave
Unlocked AMD Phenom 555 be - CPU/Mobo Corner | TechEnclave
greenhorn is online now   Reply With Quote
Help me config a new system for Music sequencing and Mixing bheem Gadgets, Computers & Software 10 20th October 2008 13:35
ICE config for Palio amitverma In-Car Entertainment 6 10th May 2006 12:42
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
