Old 22nd October 2012, 19:25   #736
Thanked: 16 Times
Default re: Help with Computer Config
Originally Posted by aditya.bhardwaj View Post
Thanks, surely i will. IF you have any other info on the Asrock motherboard then do let me know.
Yes, i will be getting a PSU from seasonic or cooler master. Most probably it will be a seasonic 520W or a 600 W one.
i checked a few reviews and saw nothing but praises, so i gues this mobo is good, must be some other one that had problems.
seasonic is very good, i myself have one and its doing good work.
guptavis is offline   Reply With Quote
Old 22nd October 2012, 19:30   #737
aditya.bhardwaj's Avatar
Thanked: 229 Times
Smile re: Help with Computer Config
Originally Posted by Imran.Syed View Post
I have a g41m intel supporting motherboard, running for the last
years.
The phenom costed me around 8k off flipkart. But now flipkart has hiked most of their prices. So I recommend not using flipkart.
Buy any AM3+ socket motherboard. Wont need upgrading.
Suggestion: Buy ASUS M5A97 MB, Bulldozer series Chip, and a 7750 card. A SSD drive, preferably 60Gigs, and there. You will have a entry level, gaming and mid level multi-tasking PC. Whats your total budget again?
SSD drive can range from 20-500GB, but I suggest you go for 20-60gigs only. Install the OS, your main multi-tasking apps in it, and they will work lightning fast.
Thanks, well my budget is 50k excluding the screen, UPS, mouse and keyboard. I have kept 10-15k for these. Lastly i doubt i will be going in for an SSD right now. They are expensive as hell . i may go for it in a few months time though.
Great , will go ahead with this then. Thanks
aditya.bhardwaj is offline   Reply With Quote
Old 23rd October 2012, 13:44   #738
Thanked: 229 Times
Smile Re: Help with Computer Config
Guys any idea if the AMD FX- 8350 has been launched in india ? If yes then , how much is it for ?
Old 24th October 2012, 10:17   #739
d3mon's Avatar
Thanked: 623 Times
Default Re: Help with Computer Config
^^ Once you've used an SSD, you'll be blown away by their responsiveness. Even if you buy a small one for your OS and apps, it will be totally worth it. For almost anything other than gaming, I'd rather take a a Core2 duo with an SSD over an i7 with a mechanical HDD any day!
d3mon is offline   Reply With Quote
Old 24th October 2012, 18:00   #740
Imran.Syed's Avatar
Thanked: 27 Times
Excellent point.
the normal applications we use daily dont require those shiny and expensive specs. people fail to understand that and buy them for the heck of it. I know many people who do the same.
SSD is a luxury really.
Imran.Syed is offline   Reply With Quote
Old 25th October 2012, 18:31   #741
Thanked: 229 Times
Excellent point.
I got it. I will go for it if i am left with vitamin M .
Rest i went to get a quotation today. Will post all the prices in a while
Old 29th October 2012, 22:35   #742
Thanked: 229 Times
sorry for the delay guys, the prices are as follows ( all taxes inclusive )
1. AMD FX 8150 bulldozer - 11,200
2. ASRock 990FX Extreme 4 - 10,750
3. Corsair vengeance 1600 Mhz 4 GB - 1375
4. Seasonic 620 W PSU - 4990
5. Corsair 300R cabinet - 3850
6. Graphic card - ATI 7770 - 8900
7. WD black deition 64 mb cache 7200 rpm HDD - around 6000 ( i cant recollect )
So how does it look ? I will be buying all of these on 3rd of nov ( saturday ). Please let me know if there is anything else.
Old 30th October 2012, 05:32   #743
Thanked: 102 Times
Looking at the prices of your other components, why don't you add another 4 GB of RAM to the list?
And do invest in single sticks of 4 GB, to give you a choice of adding more later.
All the best for your build.
LithiumSunset is offline   Reply With Quote
Old 30th October 2012, 10:22   #744
Thanked: 229 Times
Yes , i am going in with 8 GB RAM. The previous post was just for the pricing information
Old 31st October 2012, 11:01   #745
Thanked: 229 Times
Need some urgent help. I am buying my system ( configuration is posted above ) on saturday. I am confused on what cooler to get. Can you guys please help me ?
My CPU is the AMD 8150 ( I am not getting an intel , so please dont start the war here ). I might overclock it so i was thinking of getting an Antec Kuhler 920/620 or the cooler master evo 212 +. Will it be a big difference in performance as i dont know if i should pay 4k more for the antec.
Lastly, for the disk drives, i am getting a corsair SSD 120 GB ( Rs 6k ) and a WD Black 1TB HDD ( 6.3k ). The WD is a 7200 rpm drive. I was thinking for the same money i will get the WD blue/green 2TB 5400 rpm drive. Which one should i go for, as for the OS the SSD would work just fine but for normal data / games, do i need a 7200 rpm drive ?
Please help
Old 31st October 2012, 17:43   #746
Thanked: 16 Times
i think the 212+ would be good, unless you are going to render for large continuous periods. if you're putting the OS on SSD you can use the blue edition without any problem. i have heard the greens are much slower and suited only for data storage eg. movies etc. high failure rates for continuos read/write operations.
BTW which brand is the 7770?
Old 31st October 2012, 20:57   #747
Thanked: 229 Times
Alright. How is sapphire ? i may have more options though ! At home i have a sapphire HD 5450 and it works fine.
Latest update : I just got a call from the seller and he says that the corsair 300R cabinet is not available. Please suggest me some good options under 4k. urgent !
Old 2nd November 2012, 00:05   #748
Thanked: 16 Times
Sapphire is the best for amd cards. im also running a sapphire. i think 8900 is a great price for a saphire 7770.
Old 2nd November 2012, 00:10   #749
Thanked: 229 Times
Alright, thanks a lot. And can you please help me with the cabinet. I chose the corsair 300R but it is unavailable now . The other option i have is the corsair 400R / cooler master CM690 or the Antec 300. Any idea which is the best out of these and how is the antec ? For the cooler master and the corsair 400R i will have to stretch my budget which frankly i dont want to do !
Old 2nd November 2012, 00:18   #750
Thanked: 16 Times
sorry dude, dont have much idea about cabinets, use a cheap local one myself.
Help me config a new system for Music sequencing and Mixing bheem Gadgets, Computers & Software 10 20th October 2008 13:35
ICE config for Palio amitverma In-Car Entertainment 6 10th May 2006 12:42
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
