Old 17th January 2008, 11:51   #31
kaushik_s's Avatar
Thanked: 148 Times
Originally Posted by Maibaa View Post
Great choice @Kaushik. I have a pair or Etymotic ER6i that I had purchased in the US. These are lovely sounding canal phones though lacking in bass a bit. Having said that, they produce accurate tight bass unlike other phones that produce boomy bass.
Yeah, even I've noticed that but somehow I started liking the lack of boomy bass.The sound seems pretty accurate(using VBR mp3 with max 320kbps).Listened to it for an hour yesterday and it's sounding better and better. But if I compare it with the Audio-Technica then I think Audio Technica sounds lil' better, at least to my inexperienced ears.
kaushik_s is online now   Reply With Quote
Old 17th January 2008, 13:02   #32
reignofchaos's Avatar
Thanked: 1,183 Times
The perceived lack of bass is probably because the portable device is having trouble driving the headphone. You might wanna build yourself a cheap CMoy amp.
Old 17th January 2008, 14:20   #33
Maibaa's Avatar
Thanked: 38 Times
@ ROC, I don't think that is the case with the ER6i when used with an Ipod. They are specifically designed for the Ipod and the Ipod has enough power to drive them.
The perceived lack of bass is not the absence of bass but more accurate reproduction of bass as intended by the music composer. Most other headphones enhance the bass levels to sound better.
When using the etymotics, the key is to insert the phones well inside the ear canal to get a good seal, good bass and beautiful sound.
Maibaa is offline   Reply With Quote
Old 17th January 2008, 14:35   #34
I wasn't talking about the etys. I was talking about his Audio Technica. The er6i should be perfectly okay driven off an ipod.
Old 17th January 2008, 15:52   #35
kaushik_s's Avatar
Thanked: 148 Times
Build myself ..Hmmm that would be interesting.But I'm not very good at doing DIY.
I'll be playing the headphone for watching a movie.I hope that sony mini I've have enough power to drive them.Let's see, today I'll test this.
Old 20th January 2008, 02:26   #36
quadra's Avatar
Thanked: 52 Times
I am using panasonic full size headphones. Edit: found the details : click here
Performance wise, they are very good. Even on max volume, the clarity stays there. I guess i had them for a year maybe. The only thing i noticed is a shhhh sound when i increase or decrease volume.
[when using with a laptop]
In addition to that i got these by panasonic. Extremely good voice clarity.
Voice remains clear even on max volume [when using with a laptop/ipod]
Some lessons i learnt :
Go in for headphones which have one cable and have a volume changer on it. The single cable look cool.
Headphones with warranty are certainly good. Though you may not get like 3 months or something. Who cares BTW.
If you wear specs, the over the ear type of headphones will cause strain on the ear as the pressure of the headphone design pushes the ear back.
This will only happen if worn for a long period, that period may differ.
Neck back type headphones are good till the band wraps your head from behind. You may have some problems using a head rest as the plastic band may interfere.
I saw a philips neck back type headphone which had a elastic band instead of a plastic band. the wire was coming out from the center of the elastic band, in line with the spinal cord
It was packed but i am assuming they may fit better.
quadra is offline   Reply With Quote
Old 22nd January 2008, 05:22   #37
ScarySkulls's Avatar
Thanked: 19 Times
Originally Posted by jsrakkar View Post
Going by the various reviews, I am quite inclined towards the MS-1s.
Scaryskulls, when you go over to your friend to audition the headphones, can you give the due consideration to their size?
My friend puts up in Mohali and I havent found time to go to him for the audition. It is even delaying my own purchase, but I wont plonk in money without an audition.
Yes, I will take care of the size thingie.
ScarySkulls is offline   Reply With Quote
Old 18th April 2008, 11:56   #38
rsjaurr's Avatar
Thanked: 27 Times
I'm looking for earphone/headpone for about $50-70 and have shortlisted few.So guys need your help ASAP.
V-moda
AKG K26P
Sennheiser Cx300S
--Doesn't matter if its earphone/headphone but would prefer earphone if both would offer SAME SQ.
--budget strictly under $75
--sound should not be either bass or treble heavy
--Most probably has to decide by today evening.
--any other alternative apart from listed above.
rsjaurr is offline   Reply With Quote
Old 18th April 2008, 12:11   #39
greenhorn's Avatar
Thanked: 1,414 Times
how about something from the crossroads stable
Alternately, the Creative EP 630, which is considered a clone of the CX300 is available for <1k in india
greenhorn is online now   Reply With Quote
Old 18th April 2008, 12:13   #40
V-moda
AKG K26P
Sennheiser Cx300S
If you can source an Ultimate Ears Superfi.3, it'll be significantly better than any of these. Also there's the Altec Lansing IM716 to consider as well.
Old 18th April 2008, 12:27   #41
I have two of the earphones mentioned there. The V-moda Vibe and the CX-300.
The CX-300 and EP-630 are basically similar things. They are bass heavy but enjoyable. Not really a true representation of sound.
Not used the AKG so wont comment on that. The V-moda is nice, has a good level of detail and is not too bassy.
Did someone mention crossroads?
greenhorn where did you get yours from? I have used two crossroads mylarones. A x3i and lbi. Most VFM earphone I bought to date. Not the most rugged ofc. If you are willing to take good care of it, it will serve you well. Better SQ than the other three mentioned above.
The superfi3 or the IM716 (production stopped?) may give you more accurate sound, but dont think they would fit in your budget.
Sks_Biker is offline   Reply With Quote
Old 18th April 2008, 12:33   #42
greenhorn's Avatar
i dont have one yet, but have read some good reviews, and I just entered a contest where i *might* win one
PS: you think they are bass heavy? their sound is quite light compared to my full size 'phones - a philips HP 805 and a sony XD 200 ( now THAT's bass heavy)
Old 18th April 2008, 12:45   #43
I purchased a superfi last year for a friend. Costed 78$. The IM716 can be had for 50$ now as they stopped production.
Old 18th April 2008, 12:47   #44
Contest at jaben?
Bass heavy? If you are talking about the mylarones, you have 4 types of them available to suit your choice. From bass centric to light:
XBi -> LBi -> X3i -> SVi
I wouldn't call them bass heavy (except the XBi). The philips and the sony I would say are boomy, not necessarily bassy. You have to listen to the controlled bass of the X3i to appreciate it.
Old 18th April 2008, 13:29   #45
tsk1979's Avatar
Thanked: 15,682 Times
I recently got the Sennheiser HD 437. Great sound quality.
MRP is 1600, though you should be able to bargain.
Bluetooth headphones and mic abhijitaparadh Gadgets, Computers & Software 13 26th July 2010 11:04
Which Cordless Headphones to Buy kb100 Gadgets, Computers & Software 40 8th March 2010 23:03
headphones to buy- jvc v570 or sony xd200? devarshi84 Gadgets, Computers & Software 36 9th March 2009 14:52
Sony Headphones Unrepairable !?..?.. srasania Gadgets, Computers & Software 4 5th October 2006 13:04
Headphones & Hearing Loss navin In-Car Entertainment 5 12th September 2006 11:16
