Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 21st December 2007, 19:30   #1 (permalink)
BUSA's Avatar
Default How to pair Printer?
I connect my laptop to my PC using Lan. However how do i print documents on the Laptop through the PC?
__________________
Got Bhp? Team-Bhp.com
Old 21st December 2007, 19:52   #2 (permalink)
Sam Kapasi's Avatar
If the printer is installed on your PC, then simply to go printers>properties and sharing and enable. Once this is done, go to add new printer on your laptop and look for a network printer.
This will work quite easily since you already have connected your laptop and PC in a LAN.
__________________
“I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart
Old 21st December 2007, 20:45   #3 (permalink)
BUSA's Avatar
Thanks Sam, will i have to install the software of the printer on the laptop?
__________________
Old 21st December 2007, 20:50   #4 (permalink)
anonymous's Avatar
A Normal printer won't need any software. You just need to goto Control Panel->Printers & Faxes->click on add a printer
anonymous is offline   Reply With Quote
Old 21st December 2007, 22:19   #5 (permalink)
usually the printer drivers are installed automatically (by taking the best fit). it usually works well.
but if you have the printer CD then use it.
HappyWheels is offline   Reply With Quote
Old 21st December 2007, 23:17   #6 (permalink)
Clarification please?
Do you mean your printer is connected (eg by USB cable) to another PC on your LAN, or do you mean it is a standing alone, with its own LAN card or connection to a print server box?
I think people are, probably safely, assuming the former --- but the latter is possible too.
Old 21st December 2007, 23:17   #7 (permalink)
abhibh's Avatar
BUSA if the drivers are installed on PC then u wont have to install drivers on LAPTOP. Just follow the steps SAM told. I am using 2 printers like this.
__________________
Tyres will screech & Engines will roar - WOM
Old 21st December 2007, 23:42   #8 (permalink)
BUSA's Avatar
Ok guys, just tried its not working as of yet. I have enabled sharing of the printer, but on the laptop its still not detecting.
__________________
Old 21st December 2007, 23:48   #9 (permalink)
BUSA's Avatar
My computer has a printer, and i have my Laptop connected by Lan(as i can use internet on the laptop by logging on the PC) However i want the ability of giving a command on the Laptop and print the document on the printer installed on the PC.
__________________
Old 21st December 2007, 23:53   #10 (permalink)
abhibh's Avatar
BUSA go to Printers and Faxes there on left side click on Add a Printer.
Add a printer wizard will open there click on the radio button Add network printer, or a printer attached to another computer. Click next and Browse for a printer.
It will search for network printer. If it is unable to find then follow the following steps.
Instead of selecting Browse for a printer Select Connect to this printer. There type this "\\IPADRESS of PC\Printername" Eg. \\192.168.1.4\BUSAPrinter and click next. This method works 90% of the time.
Note: "\\" (without"") is necessary before ip address
__________________
Old 22nd December 2007, 00:25   #11 (permalink)
JPL
This should help;
Setting up Printer Sharing on a Windows Network*
You can use the HP Deskjet 550c drivers, they are universal drivers and can be used to install any printer for basic printing. If your printer is too old use the 500 driver.
JPL is offline   Reply With Quote
Old 22nd December 2007, 11:28   #12 (permalink)
Did anybody mention making sure that File and Print Sharing for Microsoft Networks is ticked in Network Places ---> LAN?
If you are already able to share files between the two machines, then adding the printer should be easy.
Support for many printers is included in Windows already and, I have an idea that, when you install the printer on the remote machine, that it gets the drivers from the machine with the printer attached.
Thread Tools
Where to Install a New Pair of Tyres? Front or rear? Nikhilb2008 Tyre & Alloy wheel Section 22 19th November 2009 00:32
5 in 1 Printer - Please suggest a good buy ! zakaaaaasss Gadgets, Computers & Software 54 14th October 2009 00:43
Basic printer - which one? DCEite Gadgets, Computers & Software 37 4th September 2009 19:46
Printer Cartridge Problem vinaydas Gadgets, Computers & Software 3 10th April 2009 09:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
