Old 7th August 2015, 15:35   #241
sbala's Avatar
Thanked: 157 Times
Default Re: All about external (backup) hard disks
Originally Posted by naveenroy View Post
I've been very unlucky with Seagate though. Very bad failures. But WD has been great - have had an external for more than 5 years now - 1TB without any issues. And internal - 2 2TB drives. Touch wood.
Hehehe, then I need to check it out. Oh I am sure the NSA is in there too
WD replaced my faulty external 1 TB disk last week. I was able to recover few data. Hope this one lasts long.
sbala is offline   Reply With Quote
Old 26th August 2016, 10:23   #242
deathwalkr's Avatar
Thanked: 484 Times
Planning to buy an external 4TB hard drive. Seeing two models of seagate available online. Can't seem to understand the difference between the two other than the looks of course :P
Help?
Seagate Expansion STEB4000300 4TB
And
Seagate Backup plus STDT4000300 4TB
deathwalkr is online now   Reply With Quote
Old 26th August 2016, 14:57   #243
techiecal's Avatar
Thanked: 62 Times
Backup plus is having seagate automatic back up plus software included. The expansion is marketed as an external hard disk only. You will have to do manual back ups. Other than that the warranty and price is different for each model. The back up plus has longer warranty as I am told. This has to be verified.
techiecal is offline   Reply With Quote
Old 26th August 2016, 14:58   #244
deathwalkr's Avatar
Thanked: 484 Times
Ah OK. Thanks for clarifying things for me. Shall pick up the backup plus then seeing as there's not much price difference between the two.
Old 27th August 2016, 09:37   #245
Thanked: 1,011 Times
Help?
And
Expansion uses external power supply, while Backup is powered by USB.
Aroy is online now   Reply With Quote
Old 27th August 2016, 15:12   #246
techiecal's Avatar
Thanked: 62 Times
Actually STDT4000300 Backup Plus also uses an external PS just like the STEB4000300 Expansion Desktop.
Old 27th August 2016, 20:29   #247
Sorry missed than while inspecting the specs. In that case 2TB drives which require only USB for power/data are better option. The prices are also similar for 2x2TB.
Old 4th October 2016, 13:07   #248
condor's Avatar
Thanked: 4,419 Times
Any idea how is the Lenovo 2 TB ?
Flipkart has it for 5500 today
Old 5th October 2016, 10:13   #249
No idea of Lenovo disks. At one time IBM manufactured its own HDD, but I doubt that Lenovo does it. Any way I find that Seagate and WD are much better in after sales service (and replacement of bad disks). Here is what I use
http://www.amazon.in/WD-Passport-Ult...rnal+hard+disk
Old 5th October 2016, 11:22   #250
haria's Avatar
Thanked: 291 Times
Yep. WD is quite good in replacement - I have had multiple runs with disks going bad (which is alarming), but the replacement process is quite smooth. Only catch is mostly they give you only a refurbished disk (sealed/packed unit).
Also I found WD elements to be more rugged than WD ultra. The latter is more faster, but since I keep the ext HDD primarily for backups, I am willing to sacrifice a little bit on the performance rather than on the ruggedity.
haria is offline   Reply With Quote
Old 5th October 2016, 17:55   #251
For backup, use lower RPM disks. They last longer and in most cases designed for extended life when switched off. Most of my hard disks are still operational after 6-7 years.
For long term ( > 20 years) there are very few options and CD ROMS (not DVD) last longer.
Old 7th October 2016, 15:38   #252
kbk_75's Avatar
Thanked: 343 Times
I recently had a 4TB WD My Book external drive give trouble. I had bought the drive in the USA. WD replaced it for free here and, because they goofed up and took over three weeks to replace it, they sent me a 6TB as a replacement instead of the 4TB. Way to make amends for sub-par service!
kbk_75 is offline   Reply With Quote
Old 14th February 2017, 20:02   #253
arsudarsan's Avatar
Thanked: 13 Times
Do any one know a place in Chennai that can help service a WD 2 TB My Book Essentials? I think the drive may be good. Either the motherboard or power supply is gone. There is not much data on it but I would like to get it working. The drive is out of warranty.
arsudarsan is offline   Reply With Quote
Old 15th February 2017, 11:35   #254
raghu.t.k's Avatar
Thanked: 161 Times
You can check out the IT depot - Thiruvanmiyur. Its on the ECR. You could give them a call and they could get things for you. The other option is Mercy electronics who could also get it for you
raghu.t.k is offline   Reply With Quote
Old 27th February 2017, 12:22   #255
arsudarsan's Avatar
Thanked: 13 Times
Thank you, I tried both and they said they wouldn't be able to service. There was some Cell tech numbers available off Internet who were listed as service for WD disks. I called them up, one of them gave me a number and asked to try. He did add that the shop was doing it earlier but may not be the case now. When I called up and asked, they said they were not doing it. So I opened up the casing and took out the hard disk and attached it as an internal 2 TB SATA disk. Now I have additional 2 TB on my desktop. The data on it was lost as I had to reformat the disk. Looks like the USB controller was culprit.
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Kenwood 6043 not reading off portable hard disks. Help! kumargandharva In-Car Entertainment 13 2nd July 2009 15:46
Mobile Backup Restoration help viper Shifting gears 2 18th February 2006 22:17
Help with scratched disks needed imandeep Shifting gears 3 29th January 2006 18:44
