Old 20th February 2008, 13:04   #31
condor's Avatar
Thanked: 4,904 Times
Guys, what's the take on Seagate 120GB / 160GB ?
Prices (approx) I got in BLR are 160 GB - 5K, 120 GB - 3.6K, 80GB - 2.5K.
Old 20th February 2008, 13:07   #32
Xehaust's Avatar
Thanked: 74 Times
Have the same query, Am in Mumbai. They are said to have a 5 yr warranty as well.
Xehaust is offline   Reply With Quote
Old 21st February 2008, 20:50   #33
rsjaurr's Avatar
Thanked: 27 Times
Any idea about 250GB internal and 160/250 ext. HDD?
rsjaurr is offline   Reply With Quote
Old 21st February 2008, 21:15   #34
Thanked: 11 Times
250Gb Internal Sata - Approx 2.6K
160Gb WD Passport Sata - Approx 4.4K
Mugen_Power is offline   Reply With Quote
Old 21st February 2008, 22:08   #35
rsjaurr's Avatar
Thanked: 27 Times
I am talking about notebook HDD.
BTW i was also quoted 4.4k for WD 160GB SATA HDD but for internal one.
Old 21st February 2008, 22:11   #36
condor's Avatar
Mugen, who's the seller ? Amdavad / Rajkot / ?.
Is WD better than Seagate ?
Old 24th February 2008, 00:25   #37
praveen_v's Avatar
Thanked: 120 Times
Hey the WD Passport is a cool and sleek drive. I HAD one. I said Had because I dropped it once and it has gone to the grave now.
But it was a great drive while it was working. The only thing is the black cover is very shiny and will get scratched pretty soon. Otherwise a great drive. I really miss it!!
praveen_v is offline   Reply With Quote
Old 26th February 2008, 00:00   #38
Thanked: 11 Times
Ahmedabad..
I dont know if seagate has passport sized usb harddisk.
Old 26th February 2008, 09:01   #39
condor's Avatar
Mugen, thanks. Checked in Reliance y'day. Seagate 160s are 6k+. 120 touches 5k.
They didnt have WD. Will check that out.
Old 28th February 2008, 15:46   #40
Srini76's Avatar
Thanked: 70 Times
A WD drive is a super choice , i use the 160 GB model and the backup application included does a neat job. In fact if utilized fully you can work on your files on another PC directly on the WD drive and "Sync" the changes to your PC/Laptop once you are back ! The only problem is for some machines you may need a USB which draws power from 2 USB sources and the WD cost of the cable is rather high. I am sure any little shop in India will have this cable. Why the Drive needs additional power on some machines i do not have a idea.
Srini76 is offline   Reply With Quote
Old 28th February 2008, 22:20   #41
rsjaurr's Avatar
Thanked: 27 Times
Some of WD passport drives need more power to run smoothly thats why power from an extra USB is needed.160GB has so many bad reviews on newegg pro'ly only coz of this power issue.Not all laptop/pc can supply the power from one USB( I suppose its around 650mA for WD drives),then u need this Y USB power cable for that extra bit of power.
Now how to check if your laptop/pc's USB has how much power to supply to USB device.
Go to device manager>USB controllers>Rt click USB root hub>Properties>Power.
My laptop has 500mA so if i buy WD passport,especially 160GB one,i need this Y power cable.
Old 29th February 2008, 12:37   #42
RufRoc's Avatar
Thanked: 9 Times
Sounds rather steep. Last week, picked up a 160 GB WD for 3800 (inclusive of tax)
RufRoc is offline   Reply With Quote
Old 29th February 2008, 16:35   #43
rsjaurr's Avatar
Thanked: 27 Times
That must be internal one.
Anyway lot less that what i was quoted here.I was quoted 4400rs for 160GB.
Old 29th February 2008, 17:00   #44
manziee_crusier's Avatar
Indian way of doing it will be buying a Internal Hard Disk,buy external casing and enjoy.It will be very cheap.It will not have any quality problems
And it will be as handy as a harddisk
manziee_crusier is offline   Reply With Quote
Old 21st March 2008, 23:23   #45
condor's Avatar
Default LaCie, anyone ?
Has anyone tried LaCie 120gb external drives ?
No extnl power supply, runs off the USB port, no software reqd - plug & play. USB 2.0
I got a quote of LaCie 120gb - 3750, 160gb - 4250 in BLR
Seagate is about 4250 for the 120gb, and 4800 for the 160gb.
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Kenwood 6043 not reading off portable hard disks. Help! kumargandharva In-Car Entertainment 13 2nd July 2009 15:46
Mobile Backup Restoration help viper Shifting gears 2 18th February 2006 22:17
Help with scratched disks needed imandeep Shifting gears 3 29th January 2006 18:44
