Old 4th April 2008, 07:17   #61
SunnyBoi's Avatar
Thanked: 2,794 Times
Why do you have to get it from the states? These are locally available.
I had a Maxtor 500GB external. it was the best of the lot, HDD not too big and it had a tiny power adapter. Had only a USB2 interface.
My friend bought a WD one, with USB firewire eSATA interfaces. It had a huuuge powersupply, easily the size of a normal laptop power supply.
Performances, almost all are the same. Just choose the one you like to have
You can get these for a tad under 5K for the 500GB drives.
SunnyBoi is offline   Reply With Quote
Old 4th April 2008, 07:48   #62
clevermax's Avatar
Thanked: 419 Times
I bought a MaXtor 160Gb Ext. Hard drive very recently. The size is so small that you can easily put it in the pocket. The only problem is that, it requires 2 USB ports at the computer's end (One for data + power, and the other for Power only) It sometimes works even if only connect the data + power usb cable alone.
Recently there are flash drives comin up. Why don't you buy that instead of an ext. HDD? Data is more secure, and it can withstand more shocks than an HDD. I don't know about the cost factor though. In US it must be cheaper. Heard that sony's new viao laptops are having flash drives instead of HDD.
clevermax is offline   Reply With Quote
Old 4th April 2008, 09:20   #63
condor's Avatar
Thanked: 4,413 Times
I bought a MaXtor 160Gb Ext. Hard drive very recently. ... The only problem is that, it requires 2 USB ports at the computer's end (One for data + power, and the other for Power only) It sometimes works even if only connect the data + power usb cable alone..
@clevermax, check the doc's message reproduced here, which he had posted in this thread earlier. You'll get the answer to your question.
Originally Posted by rsjaurr View Post
Some of WD passport drives need more power to run smoothly thats why power from an extra USB is needed.160GB has so many bad reviews on newegg pro'ly only coz of this power issue.Not all laptop/pc can supply the power from one USB( I suppose its around 650mA for WD drives),then u need this Y USB power cable for that extra bit of power.
Now how to check if your laptop/pc's USB has how much power to supply to USB device.
Go to device manager>USB controllers>Rt click USB root hub>Properties>Power.
My laptop has 500mA so if i buy WD passport,especially 160GB one,i need this Y power cable.
Old 4th April 2008, 11:13   #64
harry15's Avatar
thanks condor. hey clevermax flash drives are at least 10 times more expensive than normal drives and as of now i think the maximum flash drive available is 128gb . hey sunny its cheaper in the states thats why. but are the 500gb available in India for around 5 grand ? and does anyone know which company`s warranty is better ?? oh ya and does the WD drive really have a huge power supply ? wat about the seagate ?? and how are the lacie drives ????? thanks guys for your help
harry15 is offline   Reply With Quote
Old 4th April 2008, 16:25   #65
Xehaust's Avatar
Thanked: 74 Times
Am mulling over buying an external HDD for backing up purposes.
Around 250 GB should easily more than suffice.
It has to be mac compatible.
I dont need any software bundled along with it as Time Machine in Leopard will take care of the backing up part.
All i need is the hardware.
Will be using it mostly with a laptop.
What price am i looking at and which drive?
Xehaust is offline   Reply With Quote
Old 7th April 2008, 20:54   #66
clevermax's Avatar
Thanked: 419 Times
Thanks for the info mate. I know about this power issue regarding external HDDs, but somehow, mine works fine with one USB (data + Power) connected in the lappy. I had trouble to getting it working in my home pc though. I had to connect both the ends of the V cable in the PC to get the discs in the External HDD spinning.
Old 7th April 2008, 20:58   #67
nitroxx's Avatar
Thanked: 26 Times
try the Wd scorpio WD3200 320 gb drive for 8840/- Sata 5400 rpm that I've used for my Ps3 upgrade..its phenomenally quiet.
nitroxx is offline   Reply With Quote
Old 7th April 2008, 21:56   #68
condor's Avatar
@clevermax, did you check the power at your USB ports - on the laptop & the home pc ? How do they measure up ?
Old 12th April 2008, 16:38   #69
condor's Avatar
Picked up the LaCie 160gb today. 4250/-
Apparantly a 5% drop in prices of these external drives.
Old 12th April 2008, 18:10   #70
rsjaurr's Avatar
Thanked: 27 Times
So finally my wait is going to end..... i'm getting WD passport 320GB drive after few days.
rsjaurr is offline   Reply With Quote
Old 13th April 2008, 15:56   #71
condor's Avatar
Guys, need help with the drive. It's not connecting on a Win2K, though it works fine on XP.
Connected to the laptop running XP, have formatted the drive to NTFS & able to use it. Single partition of 150gb.
But no luck with Win2K. Any ideas ?
TIA !
Old 11th May 2008, 16:11   #72
rsjaurr's Avatar
Thanked: 27 Times
My one year came to happy end i received this WD 320GB drive for $135.
I wanted to buy another passport [portable but that was not in stock so bought this one.Now i see that it is retailing at about $170.
Right now formatting it from Fat32 to NTFS,is just over 55% and it has already taken 80-90min.
It seems that there is no power issue with my NB's USB.
TIA !
I dont think win98 and w2k are compatible with NTFS,only winxp and vista are.
Old 11th May 2008, 19:51   #73
merve_extreme's Avatar
Thanked: 12 Times
W2K is definitely compatible with NTFS.
merve_extreme is offline   Reply With Quote
Old 6th July 2008, 12:38   #74
DirtyDan's Avatar
Thanked: 747 Times
I am about to buy a 80gb Lacie external hard drive unless you guys stop me. Price is 3200 rupees and the shop guy says it has a "lifetime" guarantee. The size is all I need. It is the only one that I have found in this remote area also.
Your opinions?
Old 6th July 2008, 12:46   #75
Vid6639's Avatar
Thanked: 19,576 Times
I picked up a 160GB Maxtor Seagate 2.5" portable HDD from Singapore for SGD $100 approx Rs.3200.
details here: The Maxtor Online Store USA - Product Info
160GB Maxtor 2.5 External & Portable Hard Drive Hard Disk - 160 GB With Transcend 4 GB Pen Drive V30 gifts in india at rediff shopping.
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Kenwood 6043 not reading off portable hard disks. Help! kumargandharva In-Car Entertainment 13 2nd July 2009 15:46
Mobile Backup Restoration help viper Shifting gears 2 18th February 2006 22:17
Help with scratched disks needed imandeep Shifting gears 3 29th January 2006 18:44
