| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian | @hyper_vtec, try Polk Audio Monitor 50. Check out the profx site. Some Wharfedale floorstanders should cost within 20K, though going by what @RoC mentioned, I think their sensitivity levels are pretty low - mid 80s. @Blue Thunder, how are the Sonodyne Sonus 2605s? I think they cost around the 21-22K mark for a pair. IIRC, they've also launched a new version of the 2605s.
__________________ PIGZILNKILJB |
| | #17 (permalink) |
| BHPian | Thanks bluethunder and shuvc... I know that the multi-speakers are good. But somehow i feel listening to music on them is not a good experience. Anyways i would make a good buy. If not now, i would wait, accumulate ca$h and then buy.
__________________ ______________________________ WagonR LXi 2004 (clean no mods) Swift VXi w/ABS 2007 (Llumar tints, Pioneer and JBL ICE) |
| | #18 (permalink) | |
| BHPian | Quote:
Onkyo HT-S570 - 5.1-Channel Home Theater System | Model Information | Onkyo USA Home Theater Products The specs are: Power Output (8 ohm, 1 kHz, FTC) 100 W/Ch Dynamic Power* - THD (Rated Power) 0.08 % (all channels) Doesn't say how many channels driven, doesn't mention whether that THD is for 1 channel driven or all 6 channels driven. Doesn't mention the 20Hz-20kHz power rating. Seems highly suspicious to me. Anyway here are Sound and Vision magazine's measured ratings of quite a few amps. Pay close attention to the Onkyo power ratings for the newer amps.... TX-SR501 and TX-NR901. Plus those power ratings are when the amp clips, which is way way higher than 10%. The distortion at 1W is roughly around 0.1%. ratevsac Anyway all these debates of power are basically meaningless. For an amp to sound twice as loud, it needs to be 4 times as powerful. So once can distinguish between a 25watter and a 100 watter in terms of loudness but one would be hard pressed to distinguish between a 50 watter and a 100 watter. @shuvc: The sonus 2605 is quite a good speaker. However build quality is suspect. I utterly hate the Polk monitor series as they are really bright and are just uncomfortable to listen to. The higher end LSi series is quite decent though. The wharfedale diamonds are not an easy load and will struggle with this amp. Last edited by reignofchaos : 15th January 2008 at 20:26. | |
| | #19 (permalink) |
| BHPian Join Date: Jul 2007 Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
Infractions: 0/1 (7) | I have no idea about the current Sonodyne speakers, shuvc. I have listened to only the SX 606 and SX 909 towers : pretty good, both of them. |
| | #20 (permalink) | |
| Senior - BHPian | Quote:
How does build quality have an effect in general? Does it start to rattle some years later? Or do they develop leaks? Or is it just that the dimensions are not that accurate and consistent between different pieces? How does one check build quality?
__________________ PIGZILNKILJB | |
| | #21 (permalink) | |
| BHPian Join Date: Apr 2006 Location: bangalore
| Quote:
"Output at clipping (1 kHz into 8/4 ohms) 1 channel driven: 144/217 W (21.6/23.4 dBW) 5 channels driven (8 ohms): 85 W* (19.3 dBW)* 7 channels driven (8 ohms): 80 W* (19 dBW)* Distortion at 1 watt (THD+N, 1 kHz) 8/4 ohms: 0.02/0.03% Noise level (A-wtd): �77.9 dB Excess noise (with sine tone) 16-bit (EN16): 1 dB Frequency response: 20 Hz to 20 kHz +0, �0.0 dB Reference level is �20 dBFS; all level trims at zero. Volume setting for reference level was 78. Stereo performance Output at clipping (1 kHz, 8/4 ohms, both channels driven): 124/175 W (20.9/22.4 dBW) Distortion at reference level: 0.02% Linearity error (at �90 dBFS): 0.0 dB Noise level (A-wtd): �75.9 dB with 96-kHz/24-bit signals: �87.7 dB Excess noise (with/without sine tone) 16-bit (EN16): 0.8/0.8 dB quasi-20-bit (EN20): 10.7/11.5 dB TX-SR605 showed just how technically accomplished mass-produced electronics can be today, with perfectly flat frequency response and perfect D/A linearity to -90 dB (and beyond). Both are as good results as I�ve measured, and while my memory isn�t infallible, I believe this to be the first time these two particular aces have been drawn by the same unit. The Onkyo�s S/N results on our dithered-silence tests were slightly "better-than-perfect" in theoretical terms (-75.6 being the pure-dither result), which suggests a slight shortfall of its LSB (lowest significant bit) magnitude; probably not meaningful in any audible sense." Sound and Vision Magazine - Test Bench: Onkyo TX-SR605 A/V Receiver Costs Just Rs,35,000 in bangalore. ( sold out everywhere and available against orders ) 10% THD in an onkyo ? come on.Even a decade old onkyo will not have that number.
__________________ What , Me Worry ? Last edited by w 12 : 16th January 2008 at 11:01. | |
| | #22 (permalink) | |
And having a amp with 8 ohms and 1% thd will not cost a lac. One can get a STEG K-series it is rated at .3 % thd at 90 % rated power.
__________________ “First they ignore you. Then they laugh at you. Then they fight you. Then you win” | |
| | #23 (permalink) |
| BHPian | @w12: I do not doubt the fact that they are good amplifiers. I only cast a doubt on the way they are rated. This particular amp states 175W/ch @6ohm, 1 channel driven at typical FTC specs (1kHz, <1% distortion). However if you see the results you posted, the clipping power is 144W @8ohm and just 80W @8ohm when all channels are driven. Also clipping means way way way more distortion than just 10%. If an amp clips with a speaker connected to it, the tweeter will blow. When an amp states a certain power and the measured results are something way off, its ridiculous. As you see from the tests, if a pair of channels are driven, the clipping power would be roughly around 120W and hence the usable power won't be more than 80W. So effectively a 175W claimed power by the maker is only 80W in real world. @low_bass_maker: Dude I'm talking about 100 watt @8ohm, serious stereo home amplifiers and not some car boom box amps. Car amps are all rated at 4 ohm or lower and hence can't be compared to home amp power specs which are rated at 8ohms. @shuvc: It just doesn't give the appearance of a solidly built speaker. Whether this matters or not is personal. But nothing really will happen to it when playing music. Its only if its say moved from one point to another later in its life that it might fall apart. One never knows. Last edited by reignofchaos : 16th January 2008 at 11:38. |
| | #24 (permalink) | |
Amp will have to work less hard at 8 ohms when compared to 4 ohms. ![]()
| | #25 (permalink) |
| BHPian | ^^Yes but the power delivered at 8 ohm will also be halved. My home amplifier that I use now delivers 225W @8ohm but a whopping 400W @4ohm, both channels driven at <1% distortion, across the entire frequency spectrum. When I mean 100W, i mean something that measures the same way. Anyway we are going off topic here. |
| | #26 (permalink) | |||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
150 W @ 8 ohms, 20Hz - 20 kHZ, 0.02% THD, INR 48k, IIRC. I have PMed you the shipping address. ![]()
__________________ Operator! Give me the number for 911! | |||
| | #27 (permalink) |
| BHPian | Heheheh I knew someone or the other would bring up the NAD C272/C372. Frankly speaking, the NADs are kinda sad amps. Having heard the C272/C162 combo and lived with a C320 for more than a year and having moved to better quality stuff, all I can say are that the NADs are uninvolving, boring and have the typical British house sound. Its not something I'd call HiFi. There's a reason why this thing costs 60-70k. The design has a hell lotta compromises. Push-Pull, global negative feedback to keep distortion down and all of the standard tricks of the trade. Anything better than that costs a lot more money. |
| | #29 (permalink) | |
| | #30 (permalink) | |
Ya new term for me also. But I do not find any driver (speaker) in a amp which will complete the boom box.
« SQ MP3 Players
Dual SIM »
| Thread Tools | |
Similar Threads | ||||
| Using a GPS Receiver in the Car | sharathjeppu | Technical Stuff | 503 | 11th May 2008 09:13 |
| Help With Speakers & Amplifier/ AV Receiver | nura | Gadgets, Computers & Software | 41 | 12th December 2007 22:24 |
| Partially stolen onkyo system - need speaker suggestions | jassi | Gadgets, Computers & Software | 17 | 28th November 2007 14:19 |
| Speakers for JVC KD G320 in-dash receiver | aithal303 | Ask the Gurus | 25 | 17th January 2007 23:26 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
, that is ludicruous.
