Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 16th January 2008, 19:56   #46 (permalink)
w 12's Avatar
Originally Posted by reignofchaos View Post
@This particular amp states 175W/ch @6ohm, 1 channel driven at typical FTC specs (1kHz, <1% distortion). However if you see the results you posted, the clipping power is 144W @8ohm and just 80W @8ohm when all channels are driven.
When an amp states a certain power and the measured results are something way off, its ridiculous. As you see from the tests, if a pair of channels are driven, the clipping power would be roughly around 120W and hence the usable power won't be more than 80W. So effectively a 175W claimed power by the maker is only 80W in real world.
You got your numbers mixed up here. The test bench report says " STEREO PERFORMANCE, DIGITAL INPUT
Reference level is �20 dBFS; all level trims at zero. Volume setting for reference level was 78.
Output at clipping (1 kHz, 8/4 ohms, both channels driven): 124/175 W (20.9/22.4 dBW) "
175 W is at 6 ohms and 124 W is at 8 ohms., at typical FTC specs , with a THD of 0.02%.
This is what Onkyo claims in theri website "105 W + 105 W (8 ohms, 1 kHz, 0.7%,
2 channels driven, FTC) Onkyo TX-SR605 - 7.1-Channel Home Theater Receiver | Model Information | Onkyo USA Home Theater Products
So what this onkyo actually delivers in the test bench is much MORE than what is claimed in the specifications , similar to your Mccormack , if I may say so. I am yet to come across one single specifications of Onkyo , with 10% THD .
Onkyos amplifiers are certainly not cheaply built or specced. They compare favourably with products , priced many times more.
__________________
What , Me Worry ?
w 12 is offline   Reply With Quote
Old 16th January 2008, 20:20   #47 (permalink)
vikram_d's Avatar
Man this is what I call making a moutain out of a mole-hill. This thread has so totally gone OT.
__________________
Been there. Done that.
Old 16th January 2008, 21:00   #48 (permalink)
Fillmore's Avatar
Default Tower Speakers for Onkyo receiver
Originally Posted by vikram_d View Post
No you are not. But in Hyper-Vtec's case I have assumed that he already has an existing set of 5.1 channel speakers that came with the receiver. And as he has mentioned he is not happy with the way they sound on stereo mode.
Well this may be a dumb suggestion .. but anyways here it goes
before you jump to changing your speakers, did you ensure the settings on your Amp are correctly set ?
Tone button > set the Bass and Treble appropriately depending on your preference. Default setting is Zero, and Stereo sounds crap with the default setting. But you will not notice this when watching movies.
Ensure under the Hardware config you have set the right speaker size, and impedance, same with speaker sound level, and distance. cheers:
Fillmore is offline   Reply With Quote
Old 16th January 2008, 21:12   #49 (permalink)
reignofchaos's Avatar
Apologies for not checking that page. I based my comments on this page
A/V Recivers : TX-SR605 | ONKYO Asia and Oceania Website
175 W/Ch Continuous 6 ohms, 1 kHz, 1 Channel Driven, JEITA
Frequency Response: 5 Hz–100 kHz (+1 dB, -3 dB)
WHD: 435 x 174 x 377 mm
Weight: 11.5 kg
This particular amp seems to be rated conservatively. However I can't say the same about every other onkyo amp, especially the el cheapo ones.
Old 17th January 2008, 11:41   #50 (permalink)
I would definitely check all the settings first and give my existing 5.1 a try again. The problem is, thess things are so confusing and with IT industry office timings, things get worse...
__________________
______________________________
WagonR LXi 2004 (clean no mods)
Swift VXi w/ABS 2007 (Llumar tints, Pioneer and JBL ICE)
hyper-VTEC is offline   Reply With Quote
Old 17th January 2008, 12:18   #51 (permalink)
I think ROC had a bad experience with onkyo. Maybe you can tell you about it.
Old 17th January 2008, 12:31   #52 (permalink)
Yes I did. Had a friend who had an onkyo TX SR601 with semi decent KEF Eggs speakers. The speakers are not great but not ridiculously bad either (~90k for a 5.1 set). I was surprised by the lack of bass slam, dynamics and body in the audio - sounded really really thin.
He finally ended up replacing the receiver with a Marantz SR5600 which costed much less than the original onkyo. The difference in the sound was stupendous. The difference in audio quality was so much, it wasn't even funny.
Old 17th January 2008, 17:14   #53 (permalink)
Default Discussion going off-topic, I guess
Guys, I think we are way off-topic. It would be better to focus on suggesting a good pair of tower loudspeakers for hyper-VTEC to buy rather than trying to parade our individual knowledge/expertise on which receiver/amplifier is better. He already has the receiver, and he needs info about the loudspeakers .
Blue Thunder is offline   Reply With Quote
Old 14th March 2008, 15:12   #54 (permalink)
manziee_crusier's Avatar
Actually I was thinking if Navin or Sam or any one can help on DIY on Floor standing.In India speakers are very highly priced.Almost 3 times then US.But DIY for FSS will be a herculian task
or if you have option bring it from US.
Regarding suggesting a speaker what I would say is trust your ears.Coz when you go for tower standing all are good for some reasons.The Floor standing should deliver all freq (most of the) ,so take some CD which you listen frequently(A solo and music of your taste(I prefer soft rock)) and listen that in spekers you want to buy and watch for extra sounds they are producing.Itz all your taste.So question will be similar to "Is BMW or Merc the best !
__________________
Everyone seems to have a clear idea of how other people should lead their lives, but none about his or her own
manziee_crusier is offline   Reply With Quote
Old 14th March 2008, 15:29   #55 (permalink)
Also for the amp power confudion I have a good link
The Truth About Power Ratings - Articles - Education - Polk Audio
__________________
Old 14th March 2008, 15:48   #56 (permalink)
redfire's Avatar
Hey hyper,
I would always suggest to go for a 2 channel stereo setup for audio, than a 5.1 home theater. If you have the budget, go for it. Check sites like hifidemoroom : Discover Quality. As fellow members suggested do audition Polk, Klipsch, Monitor, Warfedale etc and decide. It's better to take your favorite CD with you when you go for audition.
__________________
jay
It’s really quite a simple choice: Life, death or Los Angeles
redfire is offline   Reply With Quote
Old 9th May 2008, 13:36   #57 (permalink)
smsrini's Avatar
hyper-vtec,
1) If your Onkyo receiver comes with a Audessy tuning mic, use that to ensure your setup is correct.
2) check the specs on your speakers and make sure that the receiver is setup to match the same.
3) Goto any e-zone or a multi-product store and ask them to play a onkyo 5.1 receiver with similar specs as yours with a Jamo tower speaker setup. You should be able to tell what is the difference.
Take a couple of your favourite CDs along and ask them to play them in the pure direct mode ( switch off all sound processing ), and then with DTS, DolbyDigital etc., modes.
Towers will definitely give you better resolution and sound Quality for music.
buy towers which have a rating of a min 100w. Ensure your amp can switch between 6 and 8 ohms.
In the sub 30k price range for towers my suggestion would be Wharfedale Diamond 9.5, Jamo, KEF IQ5, Acoustic Energy, Sonodyne in no particular order.
With speakers and music, each individual's perception is different, as we have very distinct musical tastes and ear for a kind of music. Some like it bright, some with more bass, some neutral, some want the mids playing louder and so on....
Now a question for the gurus:
A wharfedale 9.5 comes with large say 8 inch woofer, and 8" mid and a 25mm tweeter. Jamo in the same range gives a 6" woofer, 4" mid and a 25mm tweeter.
How does the size of the driver relate to the sound quality of the speaker or output wattage ?
__________________
"Horn Please OK Tata"
Landrover.....ka bhai, aur ek tall boy!
smsrini is offline   Reply With Quote
Old 9th May 2008, 15:29   #58 (permalink)
jp1
Hyper-vtech
If you are in Bangalore, you may try ProFx showroom at MG road, Barton centre, Ground floor. They deal with Polk Audio and KEF speakers. You can listen to it and decide yourself as they have professional set uop there, but they play on DENON amps
jp1 is offline   Reply With Quote
Thread Tools
WANTED, upper/front strut (tower) bar for an Alto VX (F10D Engine) TDR Shifting gears 3 31st January 2008 21:42
Help With Speakers & Amplifier/ AV Receiver nura Gadgets, Computers & Software 41 12th December 2007 23:24
Partially stolen onkyo system - need speaker suggestions jassi Gadgets, Computers & Software 17 28th November 2007 15:19
Speakers for JVC KD G320 in-dash receiver aithal303 Ask the Gurus 25 18th January 2007 00:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
