| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I have a Microtek Heritage+ 600 UPS. Whenever the electricity goes off, the generator kicks in after about 30 seconds or so. But the UPS goes into the red and continues to give beep sound. Isn't the UPS supposed to go back to the normal mode when the generator kicks in? After all, it should treat power as it is - whether it comes through the mains or the generator. What's wrong with it? I am technically so please help. |
| | #3 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| I have a question. When your generator starts running have you tried putting in a tester in that plug point where the UPS is connected and see whether the power is available on that point? Many a times the generators do not/can not supply power to the whole place. In such cases the wiring is done to keep the bare minimum things running. It is possible that the generators power never reaches that plug point. |
| | #4 (permalink) |
| BHPian Join Date: Dec 2007 Location: Pondicherry, Chennai
| Assuming your UPS is in good health there are two reasons for this: 1. The genrator electricity and normal electricity is not the same. Generated electricity is more rough with huge fluctuations than the supplied electricity. If your UPS is really a good one it senses this rough load and cuts of the input electricity. But this will not happen in latest technology gensets as they have special equipments to smoothen the output power - but only very latest and technically advanced sets have this. 2. Normally many of the electrical appliances take more load to start than during the continuous running time. So the generated load during the initial few minutes would be less than sufficient if you are running too many appliances. This could also be a reason for the UPS to cut of the inpur power. Read the following to understand better: "Electrical loads such as incandescent lamps and hot plates require the same wattage to start as is needed to maintain use. Loads such as fluorescent lamps require 2 to 2 times the indicated wattage during start-up. Loads for mercury lamps require 2 to 3 times the indicated wattage during start-up. Electrical motors require a large starting current. Power requirements depend on the type of motor and its use. Once enough "surge" is attained to start the motor, the appliance will require only 50% to 30% of the wattage to continue running. Most electrical tools require 2 to 3 times their wattage for running under load during use. (For example, a 9,000 watt generator can power a 3,200 to 7,000 watt electrical tool.) Loads such as submersible pumps, air conditioners and air compressors require a very large force to start. They need 3 to 5 times the normal running wattage in order to start. (For example, a 5,000 watt generator would only be able to drive a 1,800 to 3,100 watt pump.) " Usually it is not advisable to run sensitive electronic items especially computers in generated power - better to have a long stand by UPS.
__________________ The word IMPOSSIBLE itself says I'M POSSIBLE |
| | #6 (permalink) | |
| BHPian | Quote:
| | #7 (permalink) | |
| Senior - BHPian | Quote:
In fact, a friend of mine whose apartments have generator backup told me that power is made available only to the lights and fans, and not to any power outlets. Yours could be the same case.
__________________ "Wise are they who invested in a diesel powered automobile" - Benny | |
| Thread Tools | |
Similar Threads | ||||
| Which UPS to buy ? | adityamunshi | Gadgets, Computers & Software | 28 | 26th June 2008 19:06 |
| Maruti Suzuki ups car prices | windsurfer | The Indian Car Scene!! | 2 | 4th February 2008 17:16 |
| APC UPS: Good Service | bblost | Gadgets, Computers & Software | 9 | 19th December 2007 19:13 |
| pics: so more follow ups | gemballa | Super-Cars & Imports in India | 1 | 4th October 2005 20:56 |
| Formula 1 line ups for 2006 ?? | Badcheetah | Motor-Sports!! | 32 | 3rd October 2005 18:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
so please help.
