| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #47 (permalink) | |
| BHPian Join Date: May 2007 Location: Bangalore
| Quote:
I'm going to check the modem with a BSNL connection tommorow to make sure it is not broken. I shall post a message after the check. In the meantime if anybody else has any other ideas please do post. thanks
__________________ If you don't care where you are, then you ain't lost | |
| | #48 (permalink) | ||
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
You sure you did not see a puff of bluish-white smoke when you connected the 12V adapter? Hard to imagine what that "technician" (a h**jam, most likely!) was thinking when he told you to use a 12V adapter, when the original adapter was 6V! The sticker on the Modem will tell you, as will the user manual, what voltage is needed at the PS socket.Quote:
2. Which LEDs are always ON? That happens for a short while at the start 3. The yellow and green LEDs in the Ethernet socket in your laptop should light up shortly after you connect the cable (the network connection will be detected by the laptop OS only when this happens). Do they? If not, quite likely the modem IS kaput. 4. Only when there is a successful network connection (don't bother about IP address at this moment) that you can proceed to get to the Admin screen in the browser (usually by http://192.168.1.1) 5. The manual will also describe the method to do a hard reset on the modem box 6. You need not have a successful connection to the service provider to check the modem - only the LAN connection is enough at the start
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 24th May 2008 at 12:23. | ||
| | #49 (permalink) |
| Thanks DerAlte, Interestingly the adapter provided by BSNL is 6v but the sticker in the back of the modem shows 12v. That's the reason i checked with the 12v adapter without hesitation -- no puff of smoke i saw :-) . The make of the modem is UTA starcom -- i did lot of searching on the web to get the manual but i couldn't find one. The LEDs at the back of the modem is always on -- won't go even after a while. The laptop does not detect the connection -- no LED is lighted at the ethernet port I'm just trying to find the way to hard rest the modem i haven't been successful so far.
| | #50 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| help please, not able to connect my new netgear modem router DG834C to mtnl line. my laptop and desktop are wirelessly connected but getting the same limited connectivity message on both. mtnl guys have refused support since i didnt buy their stuff. i have updated the firmware. can somebody give me line by line instructions if possible. thanks |
| | #53 (permalink) |
| BHPian Join Date: Jun 2006 Location: Bangalore
| I connected ,my Netgear Wireless router to my Airtel DSL modem. Im wireless now. I can access my net with my laptop anywhere at home. Same for my HTC touch. I can connect to the net even from the ground floor. (I stay on the 4th floor). It rocks!!!! |
| | #54 (permalink) |
| Distinguished - BHPian ![]() | Not connection problems, but it's about speed. Have a Type-4 Huawei modem on my BSNL connection. I feel the connection is slower than what I had with the old Type-1 modem. I have browsed through the config, but dont seem to find any problems. Only one desktop connected to the modem - no other connections, wire-less or wired. Any ideas ?
__________________ Life is Analog. Digital is an approximation. |
| | #55 (permalink) |
| Check if the speed increases if you disconnect and reconnect (from the Admin screen). Also, on the second link in the Admin screen menu bar on the left ('system details' or something), check the connection speed and noise figures.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #56 (permalink) |
| Distinguished - BHPian ![]() | The parameters dont look bad. Notice this problem after getting a the Type-4 Huawei. PARAMETER Down-strm Up-strm SNR Margin (dB): 22.1 * 29.5 Attenuation (dB): 18.5 * 6.1 Output Power (dBm):8.0 * -7.2 Rate (Kbps): 2045 * 255
| | #57 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Bangy Boy!
| I use a Netgear wireless router at my in-laws place ( Forget the model number ..the basic Rs1750/- model ), and a linksys WAG200 wireless modem cum router at home. Strangely I find that the signals from the Netgear is very very strong - even our cousin two houses away uses it to browse. However the Linksys at home is rather weak - Its kept in a bedroom and I get ony 2-3/5 bars in the dining room! Wonder why!
__________________ A closed mouth gathers no Feet. |
| | #58 (permalink) |
| Distinguished - BHPian ![]() | @DerAlte, the speed is better : but only on wireless mode. Got my laptop connected, and this is much better than the speed that I get on the laptop. No config changes on the modem.
| | #59 (permalink) |
| That is something I have not been able to fathom: better apparent speed (apparent response = page pull down speed in browser) on a disconnect-connect. Doesn't sound logical, unless there is some DoS-type query traffic landing up on the cloud-side of the firewalls of connections which have been on longer. I get a slightly better connection speed: Operation Mode G.Dmt.BisPlus Bandwidth Up/Down(Kbit/sec) 510/2043 SNR Up/Down 17.8 dB/36.5 dB CRC Up/Down 0/0 FEC Up/Down 0/0 HEC Up/Down 0/0 Attenuation Up/Down 11.0 dB /37.0 dBDidn't understand this part. The apparent speed would be the same whether via LAN or via wireless, no? Especially even if one assumes connection via 10Mbps LAN or 802.11b, those speeds are much higher than the connection bps.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 13th July 2008 at 19:00. |
| | #60 (permalink) |
| Distinguished - BHPian ![]() | @DerAlte, I meant that between the desktop (connected to the type-IV Huawei with a Cat-5 mounting chord) & the Laptop (connected via wire-less), the speed's better on the Laptop. No config changes on any of the systems / modem Also, speed experienced on the desktop with a Type-1 Huawei was much better than what I am getting now with the Type-4 Huawei. (Type-1 is a single UTP port on the modem, Type-4 has 4 UTP's + Wireless).
| Thread Tools | |
Similar Threads | ||||
| BSNL BroadBand Issues | rjstyles69 | Gadgets, Computers & Software | 172 | 2nd November 2009 13:19 |
| BSNL broadband 20% discount? | hrishig | Gadgets, Computers & Software | 7 | 26th July 2009 22:59 |
| How To Improve BSNL/MTNL BroadBand Output | finetuning | Gadgets, Computers & Software | 12 | 23rd December 2008 16:02 |
| A question to all BSNL Broadband Unlimited Plan users | adya33 | Shifting gears | 28 | 21st December 2008 20:25 |
| Team-BHP is extremely slow with BSNL-Broadband! | SumitB | Shifting gears | 20 | 4th June 2008 00:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
G.Dmt.BisPlus
