| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #61 (permalink) |
| Senior - BHPian Join Date: Dec 2007 Location: Bengaluru
| I got a BSNL WA3002 G4 (BSNL modem / wireless router) which will be with me for some time. I have a Airtel connection at home. I was able to set up the BSNL modem so that I am now able to connect to the net using the ethernet cable; but am not able to use the wireless (which was the purpose of this whole exercise!). Am not able to ping 192.168.1.1 from the laptop and get message varying from 'Limited connectivity' to 'Local Only'. The setting on the "Wireless" menu are: . . . And I got it up and running! Yahooooo!!!! After two days and lot of trial and error - its done! I had "local access" being shown, and when i restarted, got the internet connection also! :-) Reading this post did help a lot! So, I have now successfully setup a BSNL WA3002 G4 modem to work with Airtel and also set my laptop for the wireless access. Now have to check the security part! |
| | #62 (permalink) |
| Sharing the settings that I have done for making the WA3002 G4 modem provided by BSNL DataOne to work with Airtel broadband. My seach over here and various other forums gave me information in bits and pieces and hence this attempt to have a consolidated post. And since we are well indexed by Google, a right search will bring them here. History: I have a Airtel broadband and was given a Beetel 220BX modem. I got a BSNL DataOne WA3002 G4 modem (this is a modem & wireless router combined unit) on a long term loan. Since this one has a modem, I have no use of the Beetel modem, so that got retired. And, with a desktop and a laptop, going wireless for the laptop was a hard to resist temptation. Desktop is with XP SP3 and laptop is with Vista Home Premium edition. So this is how I went about doing. First thing - make a back up of the current configuration. This can be done by going into the 'Management' menu and clicking on the 'Backup Setting' button on the right frame. Next thing to do is to reset the modem. This I did because I found that regardless of me going and deleting the existing setting, they alway found their way back (along with few more) when I rebooted the modem. The reset switch is placed below the WLAN light. When you flip and look at the downside of the mode, you can find only one circle (just behind the front right base leg). All the other holes are square in shape and placed in neat rows. This single round one is the odd one out. Keep this pressed with a blunt object (aka pen tip) for 5+ seconds (I did for 15 second!). Once done, connect the ethernet cable to the computer and type in 192.168.1.1 which is the address of the modem. You will be asked for the username and password which is usually 'admin' & 'admin' (my Beetel modem had username as 'admin' and password as 'password' so if 'admin' doesn't work, try 'password'; if this also fails call support) Once you log into the page give the setting as given below. Do note that I have changed the setting for Airtel Bangalore, but I reckon most of these setting are generic, so they should work. On the menu, select 'Advanced Setup' and click on 'WAN'. Click on the 'Add' button and give the following values as shown in the screen shots below: ![]() Picture above:The VPI and VPC are Airtel specific. So they need to be given as this. Similarly 'UBR without PCR'. No idea what it does, but it works. ![]() ![]() ![]() And finally you will get the summary screen as below: ![]() Click on the 'Save' button and you should get this screen (provided you have nothing else already present; if present, go ahead and remove them). ![]() Next click on 'LAN' under the 'Advanced Setup' option and give in the address as given below. These are standard settings, so nothing much to change here. ![]() This is my setting in 'Routing - Default Gateway' option. Did not do any change. Left it to default. ![]() I have this under 'Routing - RIP'. I did not put it there, and the available values both have 'Disabled' set, so goes no harm, either way. ![]() Under 'DNS', left the value as default, as shown below. ![]() IPv6 has not been enabled. The DSL Settings: ![]() I have this under 'Port Mapping'. I did not put it there, and the virtual post is not enables, so goes no harm, either way. ![]() These should get you up and running if accessing with ethernet cable. Do note that we do not change anything in the PC, none of the IP settings at all. All these changes are only on the modem. Now for wireless to be enabled, this is what I ended up doing. Setting in 'Wireless - Basic' menu: ![]() Under 'Security'. Maybe the guru's over here can give me some better way to set this up. But this is workable. But this one atleast asks for a passkey when a system tries to connect. ![]() This is where you set the MAC address of your wireless device to connect. With 'Disabled' any system can connect, so better to select the 'Allow' option and then click on 'Add' button and give exclusive access. I have just one device connected, as shown below. Note: For those who know MAC as I do - to find MAC address, type "IPCONFIG /ALL" in the command prompt; in the values that gets displayed, scroll down to your network card, which will be your wireless card, and note down the value under the 'Physical Address' label. This is your MAC address and this need to be entered here. And you need to space the value with a colon ( : ). I didn't know this and did spend some becuase I gave hypen ( - ) and it was getting rejected!!! ![]() Wireless Bridge values as shown below. Any other option did not let me connect. ![]() 'Advanced' settings. I did not change any of these values since I did not get any info about what they are and also I found no reason to change them. Again, request the guru's to say if any changes required here. ![]() And finally, the 'Station Info' as shown in the screen shot below. If you device is connected, you will get the MAC id shown here. ![]() And that's it! The laptop took some time to get the network detected but then when it did, all I had to do was give the passkey. It did not connect the first time but then a restart did the trick. The whole of today, I was able to just switch on and start using. So guess the setup is working fine. |
| | #63 (permalink) |
| Senior - BHPian | I have BSNL Huawai Type 2 modem with USB, Wireless and a Ethernet port. I have a Vista laptop and a XP desktop. I have managed to install VNC in Desktop and see it and use it from Laptop. But the strange thing is, I am unable to ping any of the machine from the other. I have the Tomcat installed in Vista laptop and trying to access it from desktop. It is not able to find it. Why? The IP Address for Modem - 192.168.1.1 Laptop - 192.168.1.2 [ethernet] Laptop - 192.168.1.3 [wireless] Desktop - 192.168.1.4 Gateway for laptop & desktop is 192.168.1.1 When I am able to see the machine in VNC, I should be able to ping it right? Unless I had any firewall or something to block the ping. Also, I have oracle installed in Desktop. When I use tnsping from laptop, no response from the service in desktop. Listener is running and no issues. I have no idea why this happens, any help? EDIT: Sorry guys. The inbuilt Windows firewall was the culprit. :( Just got it right. Last edited by mjothi : 13th January 2009 at 22:43. |
| | #64 (permalink) |
| Senior - BHPian | I am using "UT300-RTU" modem which has ADSL and ethernet ports for BSNL broadband. The USB is connected to modem using ADSL. Is it better to use ethernet instead of ADSL? How to use ethernet instead of ADSL? Where can i get the cable for the same? |
| Thread Tools | |
Similar Threads | ||||
| BSNL BroadBand Issues | rjstyles69 | Gadgets, Computers & Software | 172 | 2nd November 2009 13:19 |
| BSNL broadband 20% discount? | hrishig | Gadgets, Computers & Software | 7 | 26th July 2009 22:59 |
| How To Improve BSNL/MTNL BroadBand Output | finetuning | Gadgets, Computers & Software | 12 | 23rd December 2008 16:02 |
| A question to all BSNL Broadband Unlimited Plan users | adya33 | Shifting gears | 28 | 21st December 2008 20:25 |
| Team-BHP is extremely slow with BSNL-Broadband! | SumitB | Shifting gears | 20 | 4th June 2008 00:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
