Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 26th May 2008, 16:26   #61 (permalink)
Ajaybiz's Avatar
I am using charger marketed by DNS Expired and Sanyo 2500 and 2700 MAH battries bought in US as well as from National Market and they all are running in their full strenght even after 3 years .
Instead of battry it depends upon the charger whether its got microprocessor controlled charging system or not as unever charge is the culprit behind spoiled battries.
Ajaybiz is offline   Reply With Quote
Old 26th June 2008, 10:40   #62 (permalink)
Rehaan's Avatar
Originally Posted by akg7091 View Post
Guys, here's a few points to consider when buying NiMh:
1 ) Look at the self discharge fugures ( most important ). Most of us don't realize that fully charged NiMh batteries get drained in a few months and need to be maintained ( i.e regularly charged )
2 ) Try to find out if you can about the actual capacity of the battery if you have a battery analyzer with you. Else, just take a tried and tested battery and compare runtimes in a flashlight
3 ) Ensure that the batteries do not drop below 1 V in storage. This usually causes irreversible damage to the batteries
4 ) Insist on a bill. Most of the popular brands available in shady markets are fakes.
5 ) If you want an always ready battery buy the LSD type which is now easily available like the Uniross Hybrio, Sanyo Eneloop, GP ReCyKo etc
Bloody fabulous info in all your posts in this thread akg7091!!! You sure to add the science factor to buying batteries. I like it.
Actually it was not me who posted that query.
Originally Posted by BaCkSeAtDrIVeR View Post
Mind explaining the "20 days" part? I have a Kodak 662 (or something like that) - not a professional cam. Put in a fully charged battery, and leave for 4 days, and the battery is drained. Dealer says it due to bad batteries.
This is the "LSD" that akg7091 keeps talking about.
LSD - Low Self Discharge.
Read through his posts again and you will see that he recommends certain batterys (eg. enelope) if you want batts that hold their charge for a very long time when unused.
And as everyone has said, your batts probably arent very good.
...it has a screw with 6 edges.
If its a perfect hexagon you will need an allen key.
If its more like a star, you will need a torx screwdriver set.
cya
R
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 5th October 2008, 23:55   #63 (permalink)
have bought uniross batteries and charger for 900 bucks from national market.
batteries:4 (2500mah) + 2(1000mah)
charger:x-press 300 compact charger.
other options available were sanyo and chamelion.
initially was looking to buy chamelion but went with uniross as my friend is also using it from 1 yr without any probs.
__________________
WagonR Sept '07
Honda Unicorn April '05
chetans is offline   Reply With Quote
Old 7th October 2008, 02:59   #64 (permalink)
9thsphinx's Avatar
EverReady rechargeable batteries are cheap and dependable. If you support Made in India brands.
__________________
_________________________
2008 Honda Civic 1.8S
2005 Hyundai Santro Xing XG
2000 Honda City Type2 1.3EXi
9thsphinx is offline   Reply With Quote
Old 7th October 2008, 09:44   #65 (permalink)
NetfreakBombay's Avatar
Originally Posted by 9thsphinx View Post
EverReady .... Made in India brands.
Bought one set of those. They are neither made in India nor good. They are cheap imports rebranded in India. These were supposed to be rated at 2100 MAH.
Old 7th October 2008, 10:22   #66 (permalink)
anujmishra's Avatar
Thumbs up Sanyo Enelop is the best...
I bought Sanyo Eneloop set of 4 batteries along with quick charger from Singapore Airport while coming back to India for my Canon S5 IS camera.
Earlier batteries were not good and loose their charge in around 40 - 50 shots.
So, I thought to give it a try. Believe me guys once charge Sanyo Enelop lasted 362 shots (to be precise) in mixed mode condition (40 - 45% flash). Charging time for set of 4 batteries is only 3 hours 30 minutes.
It is wonderful battery and I recommend it for any heavy duty operation (Camera etc). But you should get original.
Price of batteries along with charger: US$ 42 at Singapore Changi Airport.
SANYO eneloop | Ready to use Rechargeable Battery - The only battery you will ever need: Home
__________________
Anuj Mishra
Luck will do for skill, but not consistently...
anujmishra is offline   Reply With Quote
Old 7th October 2008, 13:21   #67 (permalink)
Unhappy
i am confused as to how to find out if the cells are charged.
(i am a newbie with using this charger)
i had kept the cells for charging yesterday thinking it will take roughly 9 hrs to charge them as mentioned in the instruction paper. But issue is even after 15 hrs, i am seeing green light on charger.
so what the green light suggest: is it like the charging is going on or does it indicate cells are ready?
the small instruction set/paper that i got with charger doesnt mention anything on this :(
__________________
WagonR Sept '07
Old 8th October 2008, 02:59   #68 (permalink)
Rehaan's Avatar
...i had kept the cells for charging yesterday thinking it will take roughly 9 hrs to charge them as mentioned in the instruction paper. But issue is even after 15 hrs, i am seeing green light on charger....
Chetan,
Most probably the green light means charged, and a red/orange light will indicate charging.
Its possible your batteries came pre-charged.
Use them for a while (till you are sure you have drained a significant amount of the battery) and then put them back in the charger to see if you get something other than the green light!
cya
R
__________________
Old 8th October 2008, 04:37   #69 (permalink)
Mishra ji, chill the pill sarkars.
Eneloop is truly king. 2000 mAH only but almost zero discharge in the device itself so no decay - forget recharges.
The good news is that the set of 2 costs 450 bucks in India itself. You can bargain for a bit lesser. And being eneloop, no one knows, let alone duplicates
__________________
3300km, 1 month, 20.1 kpl (80% expressway) - Livin the VDi loca!
phamilyman is online now   Reply With Quote
Old 8th October 2008, 13:14   #70 (permalink)
Chetan,
cya
R
another thing noted was that the cells were getting hot when put on for charging. so i think it came as pre-charged.
__________________
WagonR Sept '07
Old 16th October 2008, 15:06   #71 (permalink)
prabhusati's Avatar
I purchased Eveready re-chargeable 2100 mah batteries in May 2008. Last week i charged the batteries and put them in my camera. Within a few snaps, i started to get "battery Low" indication. Surprised, i charged the batteries again and put them in my camera. Just after taking a few snaps, the "battery low" indication has come again. It has never happened before and the battery would last very long.
Yesterday, i put them for charge and after the charger light turned green, i removed the batteries from the charger, put them back and switched it on, to my surprise, the charger light turned red.
Can someone throw some light on this problem.
__________________
Maruti Omni 2005
Toyota Innova 2008
prabhusati is online now   Reply With Quote
Old 16th October 2008, 16:15   #72 (permalink)
Ajaybiz's Avatar
Your battery is gone buy new one this time try Burma Bazar and there ask for Manoj Bhai Camerawala he keeps geniune Sanyo and Enelops battry. 2700 Mah battry will cost you hardly 200 bucks for a pair.
__________________
Team Fiat-Suzuki(Swift DDiS), Yamaha RD350 and Honda CBZ only Kawasaki is pending need to buy Ninja but pocket says RTZ.
Old 16th October 2008, 17:35   #73 (permalink)
prabhusati's Avatar
I had purchased them from Metro Cash & Carry. Very surprising to note that they did not last for even 6 months. Do these carry any warranty? i did not see any on the pack nor on the metrol bill. Any ideas?
__________________
Maruti Omni 2005
Toyota Innova 2008
Old 23rd October 2008, 15:09   #74 (permalink)
Ajaybiz's Avatar
No they dont carry any warranty but my battries are working fine from last 2 years.
__________________
Old 23rd October 2008, 17:38   #75 (permalink)
Tough to give a warranty: even the life of the very best batteries can probably be shortened by bad usage.
Thread Tools
Inverter Batteries Tarun Gadgets, Computers & Software 11 28th July 2008 10:14
Battery Charger & Rechargeable batteries carboy Gadgets, Computers & Software 19 24th October 2007 14:39
Nokia Recalls 46million cell phone batteries. vid6639 Gadgets, Computers & Software 17 17th August 2007 01:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
