Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 12th March 2008, 20:24   #1 (permalink)
revvedup's Avatar
Default Graphics problem
Of late my computer has been acting up showing green ,pink and balck coloured line on the screen similar to the screenshot I have attached below. After such lines appear the computer hangs for a moment and the display goes off after a beep only to return again, this keeps on reapeating untill the computer finally restarts again.
The problem occurs only when the NVIDIA drivers are installed and does not occur either in safe mode or when I run the computer normally without the NVIDIA drivers,i.e, when windows uses its own drivers. I have tried reinstalling the NVIDIA drivers but the problem still continued, even after I tried different NVIDIA driver versions ( 93.71, 94.24 ,163.71 and 169.21 ). None of these divers are working even though they are all comapritable with my Graphics Card, a NVIDIA 6200.
__________________
The journey is more important than the destination
Living life@8500 RPM
revvedup is online now   Reply With Quote
Old 12th March 2008, 20:35   #2 (permalink)
ramie2400's Avatar
I had the similar problem with my Nvidia Graphic card,i used to get lines and then used to vanish,again when i used to play NFS UG2 i used to get flickering in the screen like you get when your cell phone is near the monitor,then i could see broken graphics as if someone have crushed a paper from centre.
As it was in warranty the dealer replaced the card and now its super.
I was using Nvidia 5700LE,now i am using Radeon X1300 PCIE.
__________________
Honda ( I V I ( 1.8 M/T V
Getz Prime 1.3GLS (ICED)
Graduated from
"University of Error's"
Old 12th March 2008, 20:57   #3 (permalink)
gkrishn's Avatar
Most probably its a graphics card issue. Might have to replace...
If you have another monitor at disposal, try connecting it to see if this happens in that monitor also.
__________________
In the Indian system of education, it is only a technique of cramming, retrieving and reproducing.
gkrishn is offline   Reply With Quote
Old 12th March 2008, 21:52   #4 (permalink)
revvedup's Avatar
But if the Graphic card or monitor is at fault, then why is the computer running fine without the drivers in safe mode ? Still l have another card, will check with that. But IMHO, it appears to be a software problem rather than a hardware one. Guys, please advise.
P.S- Just noticed, the screenshot I have posted is a liltle low on sharpness, probably due to the aggresive resize from the 1440 x 900, please note the display is completely normal except those lines.
__________________
Old 12th March 2008, 22:15   #5 (permalink)
Ripper's Avatar
I used to face this prob on My old Pentium 3. This seem to be a problem with the RAM, Just remove it from the slot, clean the contacts with an eraser, blow into the slot and put it back in. This should solve the problem. Hope this helps!
Ripper is offline   Reply With Quote
Old 13th March 2008, 00:30   #6 (permalink)
gkrishn's Avatar
I felt it must be gfx card issue because, i have seen similar issue once with an ATI card. And it was the card's fault.
And since you have tried different driver versions i excluded the SW here. Next step would be to try to isolate HWs one by one. gfx card, monitor, and then as ripper said memory also... try replacing one by one.
In safe mode and when driver is not loaded, the gfx mode is default vga mode. And the card might not be stressed at all... since it is working at a much lower resolution.
__________________
Old 13th March 2008, 01:22   #7 (permalink)
greenhorn's Avatar
I'll tell you why it might be a hardware problem. when you're running in safe mode, most of the jobs which are supposed to be done by the 'card is done by the cpu , since the drivers are disabled.
when the drivers are enabled, the cpu offloads these tasks to the GPU, and thats when its hardware issues come to light.
Ripper's post is also valid. Dying/dead ram also manifests problems like these. Do you have two sticks of RAM? try using each once.otherwise, try to get a good stick of ram from elsewhere to confirm
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 13th March 2008, 04:46   #8 (permalink)
revvedup's Avatar
Thanks Gkrishn,greenhorn and ripper it was indeed a Graphics card problem. Now with my vintage NVIDIA GEforce MX 100/200 card slotted in, there are no problems. Although I forgot to mention that the power supply I am running isn't what you would call avant grade with a mentioned total load of 130W @5.5 +3.3 V and a maximum of 250 watts, moreover it had recently stopped working only to be rectified later after a capacitor change. Do you think this was the cause of the earlier problem or is there a problem with the card itself ? If yes which power supply should I buy to replace it ?
here's my computer config
Intel Pentium 4 @2.8 GHZ with hyperthreading technology with FSB bus of 800 mhz
Intel 865GBF orignal motherboard
Corsair Value select Dual channe1gb@800 Mhz ram
Nvidia Geforce 6200 @256 mb ddr graphics card
Creative audigy 2 Value Sound card
__________________
Old 13th March 2008, 07:43   #9 (permalink)
gkrishn's Avatar
Amey suggested this else where in this forum...
Corsair VX450W PSU = 4k Rs
__________________
Old 13th March 2008, 07:44   #10 (permalink)
greenhorn's Avatar
I wouldnt use a refurb PSU- they dont last long, and might kill something else
@ gkrishn= revvedup is running a rather ordinary setup. a generic 400W psu ( cost <1k) with 17+ amps on the 12V should be fine
__________________
2007 Indica DLG
Old 13th March 2008, 11:24   #11 (permalink)
low_bass_makker's Avatar
Cooler master generic power supply comes for Rs 1k I would suggest to atleast go for that.
__________________
Looks Can Be Deceiving
Old 13th March 2008, 11:24   #12 (permalink)
revvedup's Avatar
So do you think that the PSU could be the culprit or is it the card itself ? I had actually bought a 450W odessey PSU but it was not comparitable with my motherboard. Which brand's PSU would you recmmend ?
__________________
Old 13th March 2008, 12:04   #13 (permalink)
Team-BHP Moderator
tsk1979's Avatar
The only thing that changed at your end is driver. So the problem could be software, not hardware. From your post it appears everything was working fine before you upgraded the drivers.
I don't know how but I think you somehow enabled show GPU load balancing.
Go to NVIDIA control panel, and remove the "Show GPU load balancing" option.
If thats not the problem, download drivers from NVIDIA site and not from their partners
Drivers - Download NVIDIA Drivers
__________________
Old 16th March 2008, 16:05   #14 (permalink)
greenhorn's Avatar
revvedup, if by 'not compatible ' you mean that mobo has a 20 pin socket, and the psu is a 24 pin, you can still connect it
tsk, the load balancing line would look like the green lines in this pic
http://www.nvnews.net/reviews/msi_ge...cing_afr_s.jpg
but yes, it could still be a driver issue , since he doesn't have the issue in safe mode.
__________________
2007 Indica DLG
Old 16th March 2008, 16:16   #15 (permalink)
Team-BHP Moderator
tsk1979's Avatar
I spoke to him and it appears the problem first came when he hooked a 250W or lesser power supply.
Have asked him to get a 450W one and tell if the problem persists.
__________________
Thread Tools
SX4 Vinyl Graphics/ Mods gopinathann Modifications & Accessories 138 22nd June 2008 21:01
Esteem mods and graphics viky_s Modifications & Accessories 5 20th February 2008 22:31
Magnetic decals/graphics prasadee Modifications & Accessories 6 25th May 2006 00:17
Killing Graphics for SERA a4_attitude Modifications & Accessories 8 14th February 2006 17:25
Car Company Ownership Graphics.. _Crazi4Speed_ The International Automotive Scene 16 22nd September 2004 01:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
