Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 19th March 2008, 03:29   #1 (permalink)
ScarySkulls's Avatar
Red face Windows reinstalled and few problems
Hi guys.
Well, this was my first re-install of an OS.
Laptop is a june 2007 make Dell Vostro 1000. Was running XP professional when I got it from brother in US.
Original CD that came from it and the product key sticker on the underside of the laptop, both indicated that XP home was infact the operating system to be used in this case.
Anyways, as things have it, dont know what stuck me, but I decided to re-install the OS myself.
C: of 40gb. D: of 60gb. Total = 100GB.
During installation, I prompted the installer to install in C: only and delete the previous windows.
After installation was completed sucessfully, I inserted the drivers CD and installed whatever drivers it contained i.e. pretty much ALL of them.
Problems being faced now:-
  • Display looks pretty bland. 1024x768 resolution is selected @ 32bit colours.
  • NO quick launch area. I miss the "Show Desktop" button a LOT now.
  • Windows update site indicates 85mb or so to be downloaded to complete updates. So, this much files we will need to download? Or excessive/bloatware?
  • The power indicator LED used to light up everytime I plugged in the power cable. It does NOT light up now
__________________
Punjabi for Life.
ScarySkulls is offline   Reply With Quote
Old 19th March 2008, 06:50   #2 (permalink)
Team-BHP Moderator
Rehaan's Avatar
1. Right click on a blank part of the desktop > properties > settings > and then slide the "screen resolution" slider to the maximum you can. Click OK.
2. Right click on the taskbar > toolbars > quicklaunch
3. Yes, those are all the changes that have been made by MS since the time your installation CD was made. If 85mb is too much, try downloading/installing only the critical updates, and then others which sound important / like they make a difference.
4. Might be a driver(specific to your laptop model) issue ?
cya
R
__________________
The memory of you will ride by our side forever.
Old 19th March 2008, 09:27   #3 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Rehaan is spot on, try re installing the power management driver and restart, things should be fine regarding point 4.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 19th March 2008, 13:47   #4 (permalink)
You must install the MS patches. It will not take much time if you have a broadband as most of the MS sites are mirrored across the globe. Even if you have an AV product, you should do it.
Do a custom install for the patches. IE 7 would be one of the items if I remember correctly. You can install that for later, so remove it. The others are needed.
__________________
Everyone is born right-handed, only the gifted overcome it.
This is my car and I have my wife's permission to say so.
csentil is online now   Reply With Quote
Old 19th March 2008, 14:00   #5 (permalink)
spadival's Avatar
This means the Dell specific display drivers (for the grafix card etc) are missing. Go to the Dell support site - it will pick up your Device serial number or whatever, and then show you list of updated drivers available for your laptop.
Alternately, the display drivers is probably included in the 85 MB odd updates that MS is trying to download on your laptop. I think you can verify this by checking the list of updates that its trying to download. Microsoft works in strange ways.. you know
Right Click on the Task Bar (i.e the blue bar which has the Start Button on the left) and then select Properties. You should see an option to "Show Quick Launch"
spadival is offline   Reply With Quote
Old 19th March 2008, 14:03   #6 (permalink)
Just to be sure can you also right-click the "My computer" -> click properties and see which version of Service pack is applied, 1 or 2 ??
Also do not use the "Automatic Updates" service, go directly to "update.microsoft.com" and select only critical updates to be installed. That will reduce the load.
__________________
Remember, its a machine
Old 21st March 2008, 17:39   #7 (permalink)
Much thanks to everyone
System is up and running fine.
Appreciate the help guys. Thank you all. :-)
__________________
Punjabi for Life.
Old 21st March 2008, 17:43   #8 (permalink)
RAC
Just moved to this thread from the windshield thread and saw this and thought - what, another window
RAC is offline   Reply With Quote
Old 22nd March 2008, 06:22   #9 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Forgot to mention, the same thing can be done with one of my most used keystrokes : WindowsKey + d
cya
R
__________________
Thread Tools
Help with Windows XP x64 gendarmee Gadgets, Computers & Software 4 19th March 2008 19:29
Windows Automotive sfilinto Technical Stuff 3 20th January 2008 11:15
Windows ----> Linux pratheesh Shifting gears 59 29th November 2007 22:19
2 Problems - is it Windows Vista ? normally_crazy Gadgets, Computers & Software 26 17th June 2007 09:59
help with windows XP viper Shifting gears 5 26th November 2005 21:39
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
