| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2006 Location: Chennai
| Hi guys, I have a bunch of good AVI movies that I need to convert into a format playable by my DVD player. Any ideas\pointers? Any software available for that? I have a DVD writer on my comp so I just need a player and the method to follow. Thanks in advance.
__________________ Proxima 2004 Safari LX 2008 Pulsar 180 |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Do you want 1 movie per DVD (like movie DVDs) or more? 1. First check what all formats your DVD player supports (DIVX, mpeg4, etc.) 2. The 'roadside' DVD method (multiple DVD movies, highly compressed, low-to-moderate quality, DVD menu) requires software such as Nero, SuperDVD or such. You supply the content and the menu, the software burns the DVD 3. Based on what your player supports, use a video format converter to compress the files based on your requirements. Some players support file playback, in which case you just need to compress retaining AVI format 4. There are many such software available as freeware / shareware. Your DVD writer would / should have Nero or similar writer software. If not, browse the net and you will find many
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #3 (permalink) |
| Newbie Join Date: Jun 2007 Location: delhi
| @Proxima, Generally you cannot convert the avi movies into some other format by keeping it of the same size, which is about 700 MB per movie appx. So if you want to convert 1 movie onto the DVD and then watch it on your DVD player, there are softwares for that. But if you want to burn 5 or 6 avi movies onto a DVD and then play it on to the dvd player, that cannot be done, because in this situation, you will have to burn the 5-6 movies onto 1 DVD in data format and the DVD players don't play data DVD's. So please tell us what exactly are your requirements and then we can help you out further. Regards. Racingmachine. |
| | #4 (permalink) | ||
| Quote:
Thanks for the reply guys. I want to burn only 1 movie per DVD. Menus are not required. Can you guide me to some freeware that you know\ have used? My DVD player is old and it cannot play mpeg4 and DIVX.
__________________ Proxima 2004 Safari LX 2008 Pulsar 180 | ||
| | #5 (permalink) |
| Guys, I have a problem. A AVI movie which is 700 MB, when I try and burn it using Power Producer from Cyberlink, becomes more than 4.7GB, which I cannot burn on my 4.7 GB DVD. How do I go about doing it?
| | #8 (permalink) |
| Senior - BHPian | You can also try mediacoder MediaCoder - more than a universal audio/video transcoder. Its free too and have more options than SUPER You should also try AVI to DVD Video Converter Software VSO ConvertXtoDVD one of the best softwares but paid!
__________________ tinypic.com/player.php?v=35mo01l&s=4 |
| | #9 (permalink) |
| BHPian Join Date: Nov 2007 Location: Bangalore
| Use DVD Flick to convert other formats to .dvd format. (DVD Flick) Once converted you can use any burning software to burn the DVD files. Its open source free ware , Very simple to use. You can burn either 1 movie per DVD or multiple movies per DVD, it supports both options. However the size of the movies will determine how many you can burn. Ps: On the Piracy front, Usage of DVD Flick is not what determines it, rather whether you have legally purchased the content that you are burning or not. |
| | #10 (permalink) |
| Thanks everyone for the help. I am using CyberLink DVD suite which is very easy friendly. Had it on my comp. A couple of questions: What is the difference between 4:3 and 16:9? I tried burning "The Sting" which is an AVI file which plays on my PC as a widescreen movie. I have a ViewSonic 19 inch screen. I tried burning it on 16:9 format but when I play it on the DVD player, it seems to be a 4:3. (No black gap on top and below, also the screen seems to be cut to fit the screen) I tried 2 times with 2 blank DVDs. Same result. Also, it takes a loooooooooong time to burn a DVD. Is this normal? I have a dual core, decent config comp.
| | #11 (permalink) |
| BHPian | Guys, I have another problem. My DVD Player supports DivX and XVid Compression. When I burn an DivX or XVid format AVI file onto a Data CD it plays the movie without any problem. But when I burn multiple such AVI files on a Data DVD, the player is not able to play them. Can you suggest some solution? I don't want to convert all those files into DVD format.
__________________ Kishore |
| | #13 (permalink) | |
| Senior - BHPian | Quote:
__________________ Goodbye Dada, you made us proud. | |
| | #14 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| DVD Player with FM | invincible7 | Gadgets, Computers & Software | 0 | 16th April 2008 15:04 |
| Converting VHS into DVD. Worth it? | n_aditya | Shifting gears | 2 | 4th July 2007 21:18 |
| Service centre required for LG CD-player/writer cum DVD player | benbsb29 | Gadgets, Computers & Software | 0 | 18th January 2007 11:58 |
| DVD Player for Indigo SX | shankaranand | Technical Stuff | 0 | 26th April 2006 15:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
