Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 2nd April 2008, 15:47   #1 (permalink)
Default Identifying State from Mobile Numbers
Probably a dumb question, but I was wondering that if one can identify the state from where a call is made from a mobile to mobile phone ?
In KA, I believe 98 series is for Airtel and 80 stands for Bangalore.
Majority of the numbers I know follow 9880 series in Bangalore. Anyone can add the same thoughts on this and it would be easy to identify the states from mobile numbers.
lambuhere1 is online now   Reply With Quote
Old 2nd April 2008, 15:52   #2 (permalink)
rjstyles69's Avatar
If you dint know 9845 also exists in bangalore and the service provider is Airtel.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 2nd April 2008, 15:53   #3 (permalink)
It used to be easier to identify states/caller origin from cellphone number earlier (say in 2000-02). However, of late I have seen merging of series and numbers, probably because of consolidation happening in the wireless industry.
E.g. A friend of mine had 987xx series in Mumbai and nowdays, its common to see 987xx series in Delhi (Airtel). Similarly, a few years ago, I had 9819x series in Delhi and now I have the same series 9819x in Mumbai!
Earlier, it used to be something like this (broadly)
98100 - Delhi Airtel
98110 - Delhi Hutch
98200 - Mumbai Orange
98210 - Mumbai BPL Mobile
Those were the times when there were only 2+1 (incumbent) mobile operators allowed per circle. But now the equation has changed considerably.
Maybe someone from the industry could validate or correct what I have said.
__________________
If the speed of light is 3x108 m/s, what's the speed of darkness?
nishantgandhi is offline   Reply With Quote
Old 2nd April 2008, 15:53   #4 (permalink)
diabloo's Avatar
Unlike the structure in US, TRAI here has created a mess (basically to help BSNL). I don't think there is any structure. AFAIK, operator gets the series and later on he can set whatever region he wants.
Also, if you dint know 9980 also exists in bangalore and the service provider is Airtel.
__________________
NHC - City of Life !! - Symbol of Luxury
________________
diabloo is offline   Reply With Quote
Old 2nd April 2008, 16:00   #5 (permalink)
Steeroid's Avatar
Not as simple or stupid as that, diabloo. For the National Numbering plan, click here:
http://www.dot.gov.in/numbering_plan/nnp2003.pdf
For Mobile Operator codes:
COAI
A lot of work goes into setting up these plans - you shouldnt write it all off so casually.
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 2nd April 2008, 16:01   #6 (permalink)
revved_up's Avatar
Also, if you didnt know 9900 also exists in bangalore and the service provider is Airtel
@Steer: Thanks for that info.. the link is in my favorites now.
@ lambuhere1 : where are you ?
revved_up is offline   Reply With Quote
Old 2nd April 2008, 16:07   #7 (permalink)
benbsb29's Avatar
9945 : Provider is AIRTEL, and city is Bangalore.
__________________
"You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer
benbsb29 is online now   Reply With Quote
Old 2nd April 2008, 16:36   #8 (permalink)
esteem_lover's Avatar
If y'all didn't know, 9844 is also a bangalore number.
__________________
Goodbye Dada, you made us proud.
Old 2nd April 2008, 17:19   #9 (permalink)
diabloo's Avatar
Thanks for the links. They prove my point.
For mobile:
Example: There is no correlation between Airtel & Vodafone numbers for region.
For STD:
Bangalore is 2 digits, Mysore is 3 digits & Mandya is 4 digits.
Originally Posted by Steeroid View Post
Yes it is, but its Spice.
__________________
________________
Old 2nd April 2008, 17:51   #10 (permalink)
Steeroid's Avatar
Depends on when the series were released. If you see the first set of operators, they followed a sequence for each state. Eg: 9845 was JTM (now Airtel Bangalore) and 9844 was Spice. Similarly in Delhi it was 9810 for AirTel and 9811 for Essar (now Vodafone); for Bombay it was 9820 for for Orange (now Vodafone) and 9821 for BPL (now Vodafone); for Chennai it was 9840 for Skycell (now AirTel) and 9841 for RPG (now AirCel). Calcutta had 9830 and 9831.
Then the 3rd operators came in, BSNL/MTNL came in, the 4th licenses were released and now we have a whole set of numbers. The backdoor entrants Reliance also had to be accomodated so they were given 93. Since Reliance got themselves a Mobile license they had to issue the same to Tata Indicom too, so they became 95.
There is a long history to this. You also need to refer to page 107 of the first document which states:
NUMBERING FOR CELLULAR MOBILE NETWORK
ALLOTMENT OF MOBILE SWITCHING CENTRE (MSC), SIGNALLING POINT (SP) AND MOBILE NETWORK CODES (MNC) FOR CELLULAR OPERATORS
1. The cellular mobile network has been divided into 19 service areas and 4 metropolitan cities for which licenses were issued. Accordingly Numbering Plan was formulated for allotment of MSC code for each operator with spare codes for future allotment.
The format of cellular mobile service Numbering Plan is given below:
ACCESS CODE - MOBILE SWITCHING CENTRE (MSC) CODE - SUBSCRIBER NUMBER
2-digit 3-digit 5-digit
98/94 etc. ABC XXXXX
· Presently level ‘98’/’94’ have been allocated as access code for mobile networks.
· ABC=’000’ to ‘999’. However, ABC=’000’ to ‘099' have not been
allocated and are reserved.
· XXXXX= 00000 to 99999.
Initially in each service area/metro, two operators were given licence to operate. With further opening up of mobile services, two more operators are permitted to operate in each service area/metro areas.
The Signalling Point (SP) codes for mobile operators are given in
9000/10000 series. The MSC codes and SP codes allotted to the cellular mobile operators in different circles/metros are also listed in Table-1.
For STD:
Lookup the numbering plan document. There are codes allotted for Long Distance Charging Areas (LDCAs) and Short Distance Charging Areas (SDCAs) which are different classifications for areas. The total length of the number should not exceed 10 digits and therefore they reduce or increase the length of the Trunk Code according to the capacity of the exchange. Obviously Mandya does not have the same number of telephones as Bangalore has - so how do you keep the total dialling string to 10? INCREASE the SDA code.
To Quote from Page 16:
LINKED NUMBERING SCHEME FOR PSTN
1.1 INTRODUCTION
1.1.1 Indian Telecom Network is divided into number of LDCAs. Each LDCA
consists of one or more SDCAs, which are also known as local areas.
Each SDCA has one or more number of exchanges.
1.1.2 Each LDCA has a Long Distance Charging Centre (LDCC), which is a
Trunk Automatic Exchange (TAX).
1.1.3 Each SDCA has a Short Distance Charging Centre (SDCC). Normally each SDCC is an integrated local-cum-tandem or a transit switch. In certain cases SDCC itself may also be LDCC.
1.1.4 Each SDCA normally covers one or more taluka or other administrative areas. The size of SDCA generally varies between 800 sq. kms to 2000 sq. kms.
1.1.5 As per the National Fundamental Plan 1993, the N(S)N is of 9 digits
including 2 to 4-digit National Destination Code (SDCA Code) and 7 to
5-digit subscriber number. This excludes the access code ‘0’.
1.1.6 Most of the SDCA’s have 4-digit trunk code, leaving 5 digits for subscriber number. With 5-digit length, only about 50,000 subscriber numbers per SDCA can be provided. If the subscriber base increases beyond 50,000 in an SDCA, either the number length will have to be increased or another trunk code will have to be allotted. Further, there are more than 700 SDCAs (with 4-digit code), which have more than 10,000 subscribers and are expected to grow more than 50,000 in next 30 years. These would need 6 digits local numbers. This would increase the total number length to 10 digits or else SDCA code will be required to be reduced to 3 to keep N (S)N of 9 digits. Since only about 150 spare 3-digit codes are available, only alternative is to increase the number length. The scheme envisages the use of SDCA based linked numbering with 10-digit N(S)N.
1.1.7 With the migration to uniform 10 digits SDCA linked numbering scheme, N (S)N would have following variants:
SDCA code - Subscriber Number
2-digit - 8-digit
3-digit - 7-digit
4-digit - 6-digit
You do not have a point, therefore dont bother trying to prove something.
It is very easy to pass judgement on such matters based on superficial perception. It takes a lot more to understand the effort that has gone into such plans.
I would recommend that you first read the documents and then present your arguments in a logical manner based on what you have read. The national numbering plan is not without its weaknesses, primarily because it is outdated but that does not mean that the numbering plan is random or unplanned or based on whims and fancies.
__________________
Steer
Old 2nd April 2008, 17:56   #11 (permalink)
hrag's Avatar
Very useful links, Steeroid.
I thought Tata Indicom was 92?
__________________
Feb 1997 Bajaj KB125 RTZ 48K / Mar 2003 Tata Indica V2 LSi 94K / Jan 2007 Tata Safari 3.0 DiCOR EX 4x4 46K
hrag is online now   Reply With Quote
Old 2nd April 2008, 17:58   #12 (permalink)
Rotorhead's Avatar
Depends on when the series were released. If you see the first set of operators, they followed a sequence for each state. Eg: 9845 was JTM (now Airtel Bangalore) and 9844 was Spice. Similarly in Delhi it was 9810 for AirTel and 9811 for Essar (now Vodafone); for Bombay it was 9820 for for Orange (now Vodafone) and 9821 for BPL (now Vodafone); for Chennai it was 9840 for Skycell (now AirTel) and 9841 for RPG (now AirCel). Calcutta had 9830 and 9831..
Wow steer, u have covered it all. Are u into telecom in any which way ?
Rotorhead is offline   Reply With Quote
Old 2nd April 2008, 17:58   #13 (permalink)
Steeroid's Avatar
Sorry, my mistake. I've been out of the scene in India for a while now.
__________________
Steer
Old 2nd April 2008, 18:15   #14 (permalink)
svsantosh's Avatar
Steeroid, thanks for PDF, Amazing file helps me understand where a cell# is originating. Well its takes a lot of time to understand.
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 2nd April 2008, 18:23   #15 (permalink)
Wow Steeroid, amazing info. Thanks. Till about 3 years back I was able to place the numbers to their regions pretty easily, but now there are various sequences.
__________________
Thread Tools
T-Mobile G1 Android mobile phone introduced yesterday but nobody here seems to care.. srijit Gadgets, Computers & Software 33 7th October 2008 16:57
Buy car in state or out of state (Major price difference) autoenthusiast The Indian Car Scene!! 4 3rd October 2008 21:52
Where should I sell the car: State of Registration or Current State? m_upreti The Indian Car Scene!! 8 1st April 2008 17:03
Please help identifying problem in my Swift ... abhaybakshi Technical Stuff 19 27th May 2007 10:08
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
