Old 1st August 2011, 17:05   #3466
Thanked: 13 Times
Default Proximity Sensor Issue
I started using my iPhone 4 since this morning; a while ago I was on a call and suddenly the speakerphone turned on; I investigated and to my utter shock I figured out that the proximity sensor wasn't working and the screen remained ON during the call.
I have had 5 calls since morning and the screen didn't turn off on any of them. This is a serious issue. I googled and found it to be a very common problem.
Has anyone experienced it? Any solution/workaround?
sheetumanu is offline   Reply With Quote
Old 1st August 2011, 17:31   #3467
Thanked: 41 Times
Yes, yours truly experienced it. No option but to change the phone.
Am on my 4th iPhone and would have to change this one in a couple of weeks.
Don't think AAPL is making money (from iPhone) from me
rtandon is offline   Reply With Quote
Old 1st August 2011, 17:39   #3468
mayankk's Avatar
Thanked: 3,514 Times
Default Re: Proximity Sensor Issue
did you try cutting out a hole over the sensor?
EDIT : provided you have a screen guard....
mayankk is offline   Reply With Quote
Old 1st August 2011, 17:41   #3469
wildon's Avatar
Thanked: 1,059 Times
This happened with my colleagues iPhone too and later we found out that the screen protective film causing the problem.
wildon is offline   Reply With Quote
Old 1st August 2011, 18:09   #3470
Thanked: 13 Times
Default Re: The iPhone Thread: Update iOS 5 announced!
I did install a screenguard on it last night; could it be the culprit? Where is the sensor located and how do I cut a hole on an applied screenguard?
Old 1st August 2011, 22:07   #3471
mail4ajo's Avatar
Thanked: 248 Times
Of late, I have this strange issue. Sometimes, when I get a call, the answer swipe just hangs. I am unable to slide the screen to answer. I can silence the phone, but cant answer. Is this a common issue?
mail4ajo is offline   Reply With Quote
Old 1st August 2011, 22:20   #3472
Jaggu's Avatar
Thanked: 7,890 Times
Hold the phone against light and look for sensors on top part of the screen.
Have you tried restoring the software? And is the phone updated to latest firmware ie if its a legal version/unlockers ignore this reply.
Old 1st August 2011, 22:23   #3473
akshay4587's Avatar
Thanked: 1,639 Times
I face this issue too at times.
and its pretty frustrating
Mine is a 3GS running on IOS3
Old 1st August 2011, 23:24   #3474
rg_chn's Avatar
I have had this issue when I was using the 3g. Try answering after you silence the phone or press hard on the green tab and then swipe, worked for me. If nothing works, try a restore.
rg_chn is offline   Reply With Quote
Old 2nd August 2011, 07:54   #3475
Orko's Avatar
When this happens, I try one of a number of things. Usually one or the other works to free up the swipe button.
1. I click the power switch at the top and then try.
2. If that doesn't work, I press the home button once and then try.
3. I then tap some other part of the screen and then try the swipe again.
Hope this helps.
Orko is offline   Reply With Quote
Old 2nd August 2011, 10:57   #3476
Thanked: 13 Times
Cut a hole in the screen protector over proximity sensor, no luck
Any other ideas/suggestions?
Old 2nd August 2011, 11:25   #3477
mayankk's Avatar
do a restore then.
if that dont work, do a restore at the vendor
although i dont think that is a possibility in your case.
Old 2nd August 2011, 11:26   #3478
dre@ms's Avatar
Thanked: 178 Times
@sheetumanu
Why do you need a screen protector first of all..I own a 3GS with no protector and its now a year old, not a single scratch on it. Its the Gorilla glass with is scratch resistant. Initially, I did use a protector on my iPod Touch, but for some reason, I missed the smoothness of the UI.
Can you remove it and check? If still the same, you can call up Apple.
dre@ms is offline   Reply With Quote
Old 2nd August 2011, 11:58   #3479
aks_karthik's Avatar
Thanked: 215 Times
Yes, Gorilla Glass is very much scratch proof.
After some 6 months of harrasment by my Son, still My iPhone4 doesn't have a single scratch.
One day he just rubbed my phone in the floor. I was like .
But seeing the phone there's not a single scratch. God Saves Me that day.
It's very strong enough to handle the daily chaos and mishandling some what.
Great going iPhone4 and Awaiting iPhone5
aks_karthik is offline   Reply With Quote
Old 2nd August 2011, 12:05   #3480
Thanked: 13 Times
do a restore then.
I'll try a restore else I'll get it replaced (have spoken to the vendor and he is ready)
Originally Posted by dre@ms View Post
@sheetumanu
I decided to use it primarily to avoid finger prints on the screen and moreover it came free with the phone
Iphone - now $100 since Iphone 3G S (speed) launched D-Man Gadgets, Computers & Software 32 14th February 2010 18:11
Apple iPhone Launched!!! OMG, OMG!!! (EDIT: Feb 5th - New memory sizes) hydrashok Gadgets, Computers & Software 107 21st August 2008 14:33
this is completely insane - Guy waiting in line for iPhone for 5 days in NYC whatcanthisbe Shifting gears 20 1st July 2007 21:04
