Old 20th October 2013, 09:22   #6466
iamswift's Avatar
Thanked: 65 Times
Talking Re: The iPhone Thread
Originally Posted by RajeshK View Post
My iPhone5 with 7.0.2 is not able to switch off. The battery charge is always showing at 54%.
Wow. I would like my phone battery ever stuck in 54%. No need to re-charge
iamswift is offline   Reply With Quote
Old 20th October 2013, 21:18   #6467
Thanked: 246 Times
Originally Posted by Gokrish View Post
Hi! What you have done (power+home+volume up) is safe boot. This is generally done to uninstall tweaks and apps causing issue in a jailbroken iphone.
Thanks dear...!! Mine is not a jail broken one..!
I never know that such a combination exists..!!
RajeshK is offline   Reply With Quote
Old 20th October 2013, 21:32   #6468
IronH4WK's Avatar
Thanked: 3,724 Times
Default Re: The iPhone Thread
iOS 7 completely ruined my iPhone 4 and Apple has blocked all means to legally revert to 6.1.3. i mean, if they would have obviously known in their testing that iOS 7 would not work on iP4 seamlessly, then why allow that upgrade on that device in the first place!?! also, after knowingly allowing iP4 users to upgrade to iOS 7 (and figuring out themselves that it don't work), why let them now revert to a OS that freaking works!
i think Tim Cook has a great plan to take the company to its grave! all the best!
Apple just lost a customer! that's it! i'm done with Apple!
IronH4WK is offline   Reply With Quote
Old 20th October 2013, 21:45   #6469
Thanked: 104 Times
Planned obsolescence is your answer. You shouldn't have rushed to update to iOS 7. I had faced a similar situation with the 3G and iOS 4.
By your anger I can tell you weren't jailbroken on iOS 6 and therefore dont have the SHSH blobs?
Recompose is offline   Reply With Quote
Old 20th October 2013, 22:38   #6470
IronH4WK's Avatar
You assume correct. I've upgraded/ downgraded iOS before, however in this case Apple has stopped signing older iOS versions!
If they think this will force people to upgrade to newer iDevices, they've another thing coming for them
Old 21st October 2013, 07:24   #6471
benbsb29's Avatar
Thanked: 4,276 Times
Hawk, what sort of troubles are you having with the phone post the update?
Old 21st October 2013, 10:01   #6472
IronH4WK's Avatar
Well, to make a long story short, everything that used to work perfectly in iOS 6.1.3 now works 5-10 times slower. When using the virtual keyboard, I can type a whole sentence and go have tea before the words show up! And apps, don't get me started on them!
Old 21st October 2013, 10:47   #6473
sa_kiran's Avatar
Thanked: 161 Times
Force close apps that you don't need. Use BatterySaver to allocate memory. I upgraded my wife's iPhone 4 to iOS7, though it is a bit slower than on iOS 6, it is not as bad as what you are describing.
Check if you have too much of "Others", I don't don't know if that contributes to the phone's performance (my wife's phone has about 10 GB I restored the phone and now it is around 700 MB).
sa_kiran is offline   Reply With Quote
Old 21st October 2013, 11:03   #6474
IronH4WK's Avatar
been there, done that mate. in fact, i've completely reset the phone twice, but there is no difference. i switch of wifi and bluetooth when i'm not using them; close apps after i'm done with them, cleared all pictures and videos (and unwanted apps; have about 10GB free on my 16GB phone) - shutdown, rebooted - everything expect smashing it against the wall
edit: installed Battery Saver; let's see if it makes any difference.
Old 21st October 2013, 14:49   #6475
Gokrish's Avatar
Thanked: 165 Times
Please disable documents and data under iCloud in settings and reboot. This speeds up iPhone to some extent.
Gokrish is offline   Reply With Quote
Old 21st October 2013, 14:52   #6476
IronH4WK's Avatar
done that too; no noticeable change to report.
Old 21st October 2013, 17:47   #6477
I have a Iphone 4s. I have not yet updated to iOS 7. Reading some of the posts here makes my mind debate whether I should do it or not. Any 4s users who upgraded to iOS7 and feeling issues like lags, apps getting crashed etc ., ?
electraboy is offline   Reply With Quote
Old 21st October 2013, 19:01   #6478
Thanked: 21 Times
http://news.cnet.com/8301-13579_3-57...tall-download/
If this goes through, we should be able to downgrade
Diamond_dawg is offline   Reply With Quote
Old 21st October 2013, 19:26   #6479
IronH4WK's Avatar
On devices with A5 processor onwards one cannot downgrade even if they've the SSH and blobs. Currently it's only possible on iPhone 4, which has the A4 processor.
So really think before you take the leap.
Old 22nd October 2013, 18:11   #6480
benbsb29's Avatar
Hawk, have you tried the restore as new phone, and then the restore backup?
Also, you can try this option :
Backup data to itunes, then go to Settings -> General -> Reset -> Erase all content and settings. Then setup as new iPhone, connect to iTunes and do a restore from backup.
Have been told this should help improve the performance, Do try and let me know.
Iphone - now $100 since Iphone 3G S (speed) launched D-Man Gadgets, Computers & Software 32 14th February 2010 18:11
Apple iPhone Launched!!! OMG, OMG!!! (EDIT: Feb 5th - New memory sizes) hydrashok Gadgets, Computers & Software 107 21st August 2008 14:33
this is completely insane - Guy waiting in line for iPhone for 5 days in NYC whatcanthisbe Shifting gears 20 1st July 2007 21:04
