Old 19th September 2014, 09:55   #7126
amanomics's Avatar
Thanked: 80 Times
Default Re: The iPhone Thread
I believe in model prior to 5S , there was an option for 3G ( no LTE ) whereas after 5S its only LTE
Yes, 5S and 5C. I've never seen '3G' option of my Airtel 5C, be it on a 3G network or E.
amanomics is offline   Reply With Quote
Old 19th September 2014, 11:41   #7127
sourav9385's Avatar
Thanked: 742 Times
Originally Posted by jaaz View Post
Truly hilarious - Is the Internet speed so bad even in Chennai? And all the rest of the Cities are also business hubs. In that case, Bangalore is blessed. We do have our own issues and barring some areas, 3G has picked up and we are getting true 3 to 6 mbps speed.
Well, lucky you
In Chennai, over the past year or so, 3G speeds on Airtel's network is just pathetic. Absolutely disgusting!
Not just that, but nearly every 2 minutes the 3G connection drops and reverts to Edge. Then there's no other option but to restart the phone, or fiddle with the toggle and restart the 3G connection. I've heard from close friends & reliable sources that the Vodafone network fares better on 3G. So am seriously considering porting to Vodafone to check it out. It can't possibly be worse than it is on Airtel at this time.
sourav9385 is online now   Reply With Quote
Old 19th September 2014, 13:54   #7128
Chetan_Rao's Avatar
Thanked: 3,891 Times
3G sucks in Bangalore (and other cities) too. I've never seen my phones hold onto the H/H+ sign more than a few mins at a stretch, no matter where I am in Bangalore. It can't be device-specific either because I've noticed it with at least THREE different brands of phones, and several models.
Telecom services may be cheap in India, but the service lives up to the price.
Chetan_Rao is offline   Reply With Quote
Old 19th September 2014, 14:19   #7129
IronH4WK's Avatar
Thanked: 3,679 Times
in my apartment, in the guest room, if i turn left i get GPRS and if i turn to my right i get 3G; there seems to be a invisible LoC.
go figure
IronH4WK is offline   Reply With Quote
Old 19th September 2014, 16:35   #7130
jaaz's Avatar
Thanked: 143 Times
go figure
It happens only in India.....
The problem is not with the technology. It's the Titanic issue here. There were about 1,500 passengers and Life boats only for few Hundreds. These guys install towers and transponders for 10 lac subscribers and service to 1 crore.
Yes, consistency is an issue with all Service Providers. 2G, 3G, 4G etc., With my 4G Connection, it's either 26 to 28 mbps or it'll be less than 1 mbps. Most of the time the latter part (1 mbps). But I've adjusted, just like we all used to do with Bajaj Scooters - Tilt and then Kick start. If I have any important work, and it's on 2G Network, just switch off and then switch on.
In US, even 512K (Broadband) is much better than our 10 mbps, maybe because of consistency.
I'm still laughing at your left side and right side LOC. May be an old guest (Ghost) is camping on the Left side and using the bandwidth to communicate with other ghosts.
jaaz is offline   Reply With Quote
Old 19th September 2014, 17:56   #7131
IronH4WK's Avatar
that's one tech-savvy ghost mate! freaking idiot is no doubt downloading ghost movies using torrent and killing me bandwidth.
mamma mia!
Old 19th September 2014, 18:26   #7132
AkMar's Avatar
Thanked: 1,326 Times
I have been experiencing the same. However, I have a different opinion about whether device affects this switching. On my iPhone 4S, I have observed umpteen times that on the first toggle of 3G-2g_3G, I still get an edge network. But on 2nd toggle cycle I get 3G with at least 3 bars of signal at the exact same location. I am flummoxed.
Moreover, the xperia which I owned before this iPhone had a very useful feature - it used to let me select "Only 3G" as my network mode. This was a real boon, and I used to get fairly uninterrupted coverage throughout my commute. But now with the iphone it constantly keeps on toggling to Edge on the very same commute where I used to get almost continuous 3G on my Xperia. That is really puzzling for me. Along with "Enable 3G", a "Disable 2G" option too is needed in my opinion.
AkMar is offline   Reply With Quote
Old 19th September 2014, 19:36   #7133
embee's Avatar
Thanked: 193 Times
Default The iPhone Thread
Recently upgraded my iPhone 5 to iOS 8 but does anybody have any idea how to get back the 3G on/off toggle switch in iOS 8. I am currently on Airtel network.
Thanks for your help.
embee is offline   Reply With Quote
Old 19th September 2014, 20:05   #7134
ckranjan's Avatar
Thanked: 108 Times
You can't get that without jailbreaking on airtel as they have LTE network as well.
ckranjan is offline   Reply With Quote
Old 19th September 2014, 20:13   #7135
Thanked: 1,528 Times
Absolutely true. You get what you pay for.
Steeroid is offline   Reply With Quote
Old 19th September 2014, 20:59   #7136
embee's Avatar
Thanked: 193 Times
Has anybody reverted their iPhone to iOS 7 after upgrading to iOS 8??
Old 19th September 2014, 22:57   #7137
treadmark's Avatar
Thanked: 210 Times
Well, lucky you
"Grass is always greener on the other side" Believe me when our office service provider was changed from Airtel to Vodafone last year as a part of one global service provider; for some reason I retained my Airtel number. All my other colleagues who switched to Vodafone faced severe issues then mine that too quite often at all locations. Hence I would suggest to enquire deeply and do more research before you switch to Vodafone.
PS: I can't remember how many times my network toggled between 3G ~2G ~ 3G within this short time of typing this post.
treadmark is offline   Reply With Quote
Old 20th September 2014, 07:51   #7138
manas27587's Avatar
Thanked: 56 Times
It is not possible unless you have an iPad 2 with saved SHSH blobs for iOS 5
Guys getting the 3G/Lte option depends on the carrier.
Dont you guys get the message of the new carrier update when plugged into iTunes?
That decides whether it should be 3g or LTE.
manas27587 is offline   Reply With Quote
Old 20th September 2014, 09:03   #7139
dre@ms's Avatar
Thanked: 178 Times
Running my iPad 2 and iPhone 5c with iOS8. Its pretty slick and smooth on both. Yes, initially most of the apps closed with no notice but eventually when updated to the latest version, all works fine. I love the Swype keyboard and feel its one of the greatest keyboard or addition to iPhone till date. Major plus which I like is the volume of speaker and earphone are mightily increased in iOS 8. Overall, I am satisfied.
dre@ms is offline   Reply With Quote
Old 21st September 2014, 04:25   #7140
manas27587's Avatar
Thanked: 56 Times
@Embee
My Bad !I meant to say that if you downgrade a jailbroken broken you will lose the jailbreak.
Else you can downgrade easily .
Iphone - now $100 since Iphone 3G S (speed) launched D-Man Gadgets, Computers & Software 32 14th February 2010 18:11
Apple iPhone Launched!!! OMG, OMG!!! (EDIT: Feb 5th - New memory sizes) hydrashok Gadgets, Computers & Software 107 21st August 2008 14:33
this is completely insane - Guy waiting in line for iPhone for 5 days in NYC whatcanthisbe Shifting gears 20 1st July 2007 21:04
