Old 25th September 2015, 09:00   #7996
diyguy's Avatar
Thanked: 138 Times
Originally Posted by shasha View Post
I am not seeing personal hot spot option in the setting. ?
This is controlled by the network typically. If you swap your sim with a friends you may find it to work for you. Try to get a newer sim too.
diyguy is online now   Reply With Quote
Old 26th September 2015, 08:43   #7997
planet_rocker's Avatar
Thanked: 368 Times
This is crazy. iPhone 5S with iOS9 with wifi at home and 3G while at work
Nokia 3310 jokes will soon fade away. Hehe
I still hate the dedicated search window, which is back again.
planet_rocker is offline   Reply With Quote
Old 26th September 2015, 09:08   #7998
diyguy's Avatar
Thanked: 138 Times
iOS 9.0.1 update has been released. Speaks poorly about their QA process, so soon after a major OS upgrade
Old 27th September 2015, 02:22   #7999
ashis89's Avatar
Thanked: 1,116 Times
Default Re: The iPhone Thread
Attachment 1419678
I can explain these absurd numbers. What I observed with my 5 with iOS9 & now 9.0.1 is that the stand-by hours figure is not reset until the phone is charged till 100%. So if you keep using the phone with partial charges during the day (never till 100%), then this number will keep increasing. I'm sure if you did partial charging, but I observed the above with my phone.
ashis89 is offline   Reply With Quote
Old 27th September 2015, 09:16   #8000
bhp_maniac's Avatar
Thanked: 97 Times
Attachment 1419678
Lucky you. Mine holds up for a max of one day.
bhp_maniac is offline   Reply With Quote
Old 27th September 2015, 12:03   #8001
Thanked: 368 Times
One single charge. No partial charges.
These are just stupid numbers. I didn't use whatsapp in the iPhone while I was testing the standby with minimal usage. I bet with whatsapp, the battery won't have last this long.
Chill and regards
Old 27th September 2015, 12:06   #8002
Thanked: 90 Times
Morning.
My iPhone 6 has iOS ver 9.0.1.
I have discovered that the screen transitions are abrupt.
If I click on gmail it is abrupt and the gmail screen is seen.
When I click on the What's App icon, the screen immediately becomes black, and then the screen with the chats is seen.
Also as I proceed to General> Software Update, it tries checking for an update but a pop up shows up saying 'Unable to Check for Update'; 'An error occurred while checking for a software update'.
What should I do?
issigonis is offline   Reply With Quote
Old 27th September 2015, 12:19   #8003
Thanked: 3,458 Times
I am not seeing personal hot spot option in the setting. I am using iOS 9 in iPhone 6. Don't know exactly when the problem started, as there was no need for wi fi hot spot till now and I didn't notice. Tried resetting and all without result. Is your phone showing "personal wi fi hot spot " under setting?
You will need to fill APN settings depending on your service provider , I have personally done on my iPad with Voda Sim
http://www.omgmac.com/enable-missing...ature-in-ios-8
My ip 6 plus is from the US and work fine with Airtel LTE
You are lucky - perhaps something to do with Artel frequencies they use in south , mine bought from Canada does not work here in North , there is difference in model numbers that we see on back
some information
http://www.fullstopindia.com/iphone-...nd-what-works/
Turbanator is offline   Reply With Quote
Old 27th September 2015, 12:20   #8004
Happysmiles's Avatar
Thanked: 88 Times
I did the latest software update on my iPhone 6, and something very funny happened.
I could clear all notifications except one whatsapp message and one Fb message. Tried clearing these 2 notifications for 3 days. No luck.
Finally, switched off the phone and restarted after a minute. Everything is back to normal.
Did anyone experience this?
Happysmiles is offline   Reply With Quote
Old 27th September 2015, 14:58   #8005
Thanked: 143 Times
@happysmiles - I had similar problem on my 5s. I couldn't clear any notifications. They were persisting even after switching off and turning on again. With iOS 9.0.1, it was solved.
printh is offline   Reply With Quote
Old 28th September 2015, 14:51   #8006
csnanjappa's Avatar
Thanked: 54 Times
Snapdeal is selling iphone 6 for 39k plus 10% cashback on SBI cards....good time to but an iPhone 6
csnanjappa is offline   Reply With Quote
Old 28th September 2015, 17:59   #8007
Dodge_Viper's Avatar
Thanked: 470 Times
Apart from online offers, what is the latest pricing for iphone 6 (64GB) in normal shops? Say Reliance, Croma etc. Somehow not willing to buy it online!
Dodge_Viper is offline   Reply With Quote
Old 28th September 2015, 18:08   #8008
kkkkkaran's Avatar
Thanked: 126 Times
Reliance and Croma are both pricing it at approx 56k INR. Id suggest going to local brick n mortar stores and picking up the phone. Warranty is valid as long as you have a proper bill, so no concerns
kkkkkaran is offline   Reply With Quote
Old 28th September 2015, 18:08   #8009
SwiftSD's Avatar
Thanked: 49 Times
The 10% translates to 1500 INR, that the maximum discount applicable on one card as I understood from the T&C's. Never the less a good deal I would say.
SwiftSD is offline   Reply With Quote
Old 28th September 2015, 19:06   #8010
superbhikari's Avatar
Thanked: 143 Times
My iPhone 5s after updating with ios9 and running fine for couple of days, started to restart again and again showing a blue screen. Restoring through itunes too failed giving error 9. Warranty was just got over week ago. Apple service center asked for 21k to replace the phone citing some hardcore fault. Local service guy is asking 12k for motherboard replacement but touch id function won't work. Istore refused to repair it. Stuck since remake value for an year old iPhone 5s is 15 to 20k.
. . Can anybody here help to get it back to life?
superbhikari is offline   Reply With Quote
Iphone - now $100 since Iphone 3G S (speed) launched D-Man Gadgets, Computers & Software 32 14th February 2010 18:11
Apple iPhone Launched!!! OMG, OMG!!! (EDIT: Feb 5th - New memory sizes) hydrashok Gadgets, Computers & Software 107 21st August 2008 14:33
this is completely insane - Guy waiting in line for iPhone for 5 days in NYC whatcanthisbe Shifting gears 20 1st July 2007 21:04
