| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #17 (permalink) |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| try deleting the entry that you are aware of and calling again. hopefully it will show the entry that you are not aware of, i.e. if it's just 2 and not more than two entries conflicting.
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. |
| | #18 (permalink) | |
| Newbie Join Date: Jan 2007 Location: Bengaluru
| Quote:
If this does not work, it means you have saved it more than 2 times, other than manual scan, Mobiledit / Nokia PC suite are good options. | |
| | #19 (permalink) |
| BHPian | exactly!! do the following! 1. delete the numbers that you saved yourself 2. dial that number>note the name that pops up> edit that number, simple do the same for the other home number. PS: why do you people use pc suite to backup numbers. After n series, there is an option to backup your contacts in external memory cards.
__________________ Living Life a quarter mile at a time... |
| | #20 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Same number under 2 names = software confused = it takes safe route and display the number, tell user go figure ![]() 1) delete your entry. Call the number, the name tag will show up. Problem identified solve move on 2) Inspite deleting your entry, number shows up, You might have more than 2 names already entered?? Since you use sync, the entries are there in your outlook or similar contact manager application. Use search func and figure which all contacts the number is saved. Fix the issue and sync. I use outlook and its very convenient to sort phone book, putting names in right format and numbers under right headers etc.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #21 (permalink) |
| BHPian | Yes as many ones stated here, its the result of same number stored in two or more names. I had this problem in my N95 and spent almost 4-5 hours to figure it out. It has happened later too, but then I knew the trick . In your case, among the 500 entries, the home number would have stored in another name too, or as a second or third number in a contact. Or the same contact would have replicated (identical contacts just like a copy/paste with same names and numbers). This has also happened to me with my N95 last week. When my close friend called me, it was just the number. I was sure that his number is not saved with in any other contact name. But to my surprise his contact was replicated (it was like the phone did a copy/paste job itself). I deleted one and it worked fine.
__________________ jay Most automobiles problems are caused by the loose nut that connects the steering to the saddle |
| | #22 (permalink) | |
| BHPian Join Date: Jan 2008 Location: Chennai
| Quote:
This is true and this should be the problem in your case. I just double checked it now on my friend's nokia phone. (Mobiles other than nokia picks the first name on the list if there are duplicates)
__________________ If the world was fair, God would've been here | |
| | #23 (permalink) |
| BHPian | @nishantgandhi - this happens with my E90 too. But later i found out that same number was stored under 2 separate names, so it showed up just the no. when a call was made. BTW, there's one more glitch in Nokia and Motorola phones. If you have 2 similar numbers : as in 9823012345 and 9823112345 : the only difference being one of the digits, the phone tends to show same Name of the contact ( mostly the one that comes first alphabetically ) for both, when a call is made. In phonebook, it'll showup absolutely normal. I wonder how these companies missed out on such a small glitch. Its not present in SE phones.
__________________ एक सात पाच पाच Last edited by hkanitkar : 17th April 2008 at 22:18. |
| | #24 (permalink) | |
| BHPian | Quote:
As suggested by jaggu, sam and others, i browsed through my entire phone book to ensure that there are no two names with the same number and to my dismay did not find any till the last name, but after that a number popped up, but was unnamed, voila its the same number, deleter that one and now my problem is gone. check for some unnamed ones, it is in the end of the list. regards tifosi.
__________________ Drive carefully. It's not only cars that can be recalled by their maker. | |
| | #25 (permalink) |
| BHPian Join Date: Jan 2007 Location: Shillong
| This problem will only happen if you save the same number twice on two different entries. So do what others have suggested. Also, if you can search your phonebook for a number, then do a search and I am sure you will be presented with two individual entries. Then all you got to do is to delete one entry and you'll be good to go ;-) |
| | #26 (permalink) |
| BHPian | I have faced this problem in my 9300i, The problem was with home land line (MTNL). No matter what name I gave, it just displayes the number. Finally deleted from Phone book and added the number in the SIM and now looks like the problem has got resolved. It is really wierd to see this. Even if you have same number stored with 2 different names. The algorith picks up the earlier one and displayes. I have tried that.
__________________ Firebird _________________ Matiz SG - 2000 Sold Palio 1.6 Sport-2006 TEAM-BHP LEAGUE OF ORDINARY PEOPLE WITH EXTRAORDINARY RIDES |
| | #27 (permalink) | |||
| BHPian Join Date: Jan 2008 Location: Mumbai
| Quote:
![]() Quote:
Thanks guys!
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? | |||
| Thread Tools | |
Similar Threads | ||||
| The latest fashion from Nokia - new Nokia 8800 | khanak | Gadgets, Computers & Software | 29 | 26th March 2008 00:56 |
| nokia 7610 v/s nokia 6600 | normally_crazy | Shifting gears | 2 | 21st August 2004 18:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
