| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #16 (permalink) |
| BHPian | Shuv, Some good news for you. The 65nm Q series price has been revised. Esp the q6700 is almost halved. Its now only about 40$ more than q6600. check the price list here... intel price drop - [H]ard|Forum
__________________ In the Indian system of education, it is only a technique of cramming, retrieving and reproducing. |
| | #18 (permalink) | |
| BHPian | Quote:
Shuvd you can buy an E8xx series CPU without any issues and run it with DDR2. Last edited by reignofchaos : 24th April 2008 at 12:47. | |
| | #19 (permalink) |
| BHPian Join Date: Nov 2006 Location: Chennai
| assuming shuvd is going to stick with this new system of his for the next 3 years at least i would suggest he go in for DDR3 ram. his budget has to go up but as far as i can see DDR2 will be on its way out by the end of the year. then it would be back to the story of DDR1 vs. DDR2 where DDR1 costs almost double of an equivalent DDR2. as far as the video cards are concerned i hear the 8600GTS Alphadog edition with 512MB gddr3 memory and 650mhz clock speed is the way to go. good luck shopping!!
__________________ An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright |
| | #20 (permalink) |
| BHPian Join Date: Feb 2007 Location: Delhi
Infractions: 0/1 (7) | AMD X2 4800+ = 3500 Gigabyte AMD 780G chipset mobo = 5400 2 GB Transcend JetRam DDR2 6400 = 2100 Total - 11000 Left over 19000, Suggestion 1 - get a dell 24" ultrasharp lcd Suggestion 2 (preffered) - Start scotching pete for another remap ![]() Suggestion 3 - Stock Optra ORVMs, will help other fellow bhpians ![]() Last edited by ashthedivx : 24th April 2008 at 15:25. Reason: Adding text |
| | #21 (permalink) | |
| BHPian | @ Flipsyde - Any idea about DDR3 and the graphics card prices? How much RAM would I need? @ Reignofchaos - The E 8xxx costs between 9k-12.5k. The Q 6600 is around 10k. More cores = better performance? @ Drpullockaran - I'll try to match the frequencies, budget permitting. Now, which mobo will have both DDR2 and DDR3 support? As of now E 8xxx or Q6600 Mobo? 3GB Corsair DDR2 or 2GB DDR3 Will retain the 8500GT (512mb DDR2) for the time being. Sorry for troubling you guys, ![]() Quote:
__________________ I (still) feel the need...the NEED for SPEED | |
| | #25 (permalink) | ||
| Newbie Join Date: Nov 2007 Location: Bangalore
| Quote:
Buy Transcend or Kingston Value RAM. DDR3 is not worth the price it demands. Buy 4GB DDR2 800 from Transcend or Kingston. ------------------------------------- For around Rs.9000 to 11000 u get: Quads: Q6600, Q6700, Q9300 and Q9400 Dual: E8500, E6600 Dont worry about FSB, multiplier, cores etc. Buy the quad core. It loses out to the high end E8xxx in gaming little bit but then ur not putting a lot into gaming. U can always buy a Nvidia 9xxx series gfx card later. The quad core performs very well in multi threading. Maybe u could try the Q9300 or 9400. They draw less power than the Q6600. ---------------------------------- | ||
| | #26 (permalink) | |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| Quote:
First of all its no trouble at all and we all keep learning from arguing even if its over nothing significant in our lives. More cores means better performance only if the software can take advantage of it with multi threading. Presently there are very few software that take advantage of 2 cores let alone 4 cores. AMD is releasing a 16 core version shortly as a tech capability and they do agree that more than 2 cores with present software is just a waste of money. Run any programme/application and then press CTL-ALT-DEL (if you are not running Linux or BSD) and then go into the Performance TAB and see what the cores are doing and for most of the time one of your cores will be inactive lying dormant. What ever you do buy a 45nanometer 1066MT/sec CPU with matching 1066mhz DDR2 memory.
__________________ Bye and wear your seat belts. Last edited by drpullockaran : 28th April 2008 at 23:53. | |
| | #27 (permalink) |
| the only reason i suggest you go in for DDR3 ram compatible board is so that sometime next year you don't regret your decision. correct me if i am wrong but you seem to be the kinda user who won't bother much with the system for a 3 yrs min. if so i recommend you go in for a quad core + ddr3 simply because its the next big thing. as many have already mentioned DDR3 does cost a bomb right now. so jus go in for 1GB for now..... you'l have 3 free slots on most new boards so u can expand later when prices drop. asus p5kkc mobo - 8550 intel q9300 - 12800 1GB ddr3 - 6000 seagate 500gb sata 7200rpm hdd - 4400 sony dvd dual layer drive - 1200 cabinet + psu = 2000 k/b + mouse - 750 total - 35700 *use your existing 8500gt u can upgrade it anytime later......(mayb even a 9800 gx2 sometime )*also assuming u have an existing display if not get a nice 24" viewsonic LCD - 14000 this might shoot up ur budget but i think its worth putting in the money for a better board and newer tech. cheers! *use the existing 8500gt that you have lying around for the time being
| | #28 (permalink) | |
| Quote:
The only real flaw I found in your rig is that you have recommended only Rs2000 for the Cabinet and power supply which is way too less to do justice to the rest of the system. I suggest spending at the very least Rs4000/-
__________________ Bye and wear your seat belts. Last edited by drpullockaran : 29th April 2008 at 07:59. | |
| | #29 (permalink) |
| Senior - BHPian | See don't go for DDR3 ram now,its price/performance ratio is poor,nor has it matured to its best potential.Get a Mother Board that is DDR2/DDR3 compatible so you can upgrade later when things become sane. Get DDR2 800 Memory and run it at 1066 MHZ.It will require some playing with the timings and voltages for value ram but you will achive it.If you are not comfortable get better performance ram.It may set you back by upto 2000 bucks over the normal one. As for Processor you can either go for the E8400 or Q6600.Remember not many applications are optimized for 4 cores,but it may change in the future.
__________________ No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz Last edited by merve_extreme : 29th April 2008 at 08:56. |
| | #30 (permalink) | ||
| Quote:
and yes....absolutely agree with you on the cabinet + psu...... i jus didnt wanna scare shuvd away with a + + on everything!! you should learn a thing or two about budgetting from the ICE section doc!!Quote:
good point there merve..... i should have checked that option before.
__________________ An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright | ||
| Thread Tools | |
Similar Threads | ||||
| Ram Ram dosto | Vikrocks | Introduce yourself | 11 | 24th May 2007 15:03 |
| AMD which motherboard to buy? | aseem | Gadgets, Computers & Software | 32 | 28th June 2006 13:52 |
| New member here . pug ram | pugram | Introduce yourself | 17 | 26th March 2006 21:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
Magnum ORVMs. Older ones are available..
