Old 23rd April 2008, 16:54   #1
Default Link exchange Program (for SEO) Solution
Mods : I am not too sure whether its write place / Section to pots this post, pls do the needful if necessary
Dear All,
As you know inbound links / link exchange program helps a lot in SEO, I have a site which has a logo on the top in header file which calls my homepage, I was panning to give absolute link to that logo e.g www.sitename.com/index.php, will google consider these links under link exchange logic? will this help in SEO ?
Pls comment
Jitendra
nicejits is offline   Reply With Quote
Old 23rd April 2008, 19:13   #2
abhibh's Avatar
Thanked: 33 Times
nicejits you mean to say that currently your site logo points to http://www.lalalalalalalallalaal.com/ and you want to edit it and pont it to index.php file. If that is the case it won't make any difference in SEO.
Unless you have links from different C class IPs pointing towards the index.php page.
Old 24th April 2008, 00:26   #3
Rehaan's Avatar
Thanked: 23,057 Times
Im not sure i understand your question either, but i think the answer is no.
Also, check out the "quality guidelines" on this google page :
Webmaster Guidelines
cya
R
Old 24th April 2008, 09:24   #4
Hey Guys, it helps in increaing PR number
Old 24th April 2008, 11:08   #5
srijit's Avatar
Instead of trying to increase PR number, try getting good content in your site. If the site is active Google will come. It will also give good PR. For some reason, Google loves Wordpress, so use that with some themes that give importance to SEO, like Cutline.
srijit is offline   Reply With Quote
"Automatic Link" for iPhone: OBD-based Car Monitoring Solution crazydave Technical Stuff 0 13th March 2013 09:22
Help with Website - getting onto search engine listings & SEO BUSA Shifting gears 12 18th July 2008 21:07
