Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 24th April 2008, 12:52   #1 (permalink)
Default Personal Solutions For Push E-Mail On The E Series
Most of you know what push mail is. Basically it means that emails are pushed to our devices instead of being pulled from the server, hence we don’t need to continually check our inboxes. Until some time ago, the only available solution was BlackBerry service.
Push Email
RIM (Research In Motion, the company that makes BlackBerry devices) developed a compatible application called BlackBerry Connect to use non-BlackBerry devices with the BlackBerry service. Nevertheless, this application has not been homologated on all carriers, making a lot of S60 devices useless, despite the fact that we can indeed connect to BlackBerry servers. Beside it, sometimes we only want to check our personal emails because not all of us are corporate users and the whole BlackBerry service package is, to say, overkill.
This time, we will review two applications that can be a replacement to BlackBerry devices. I have narrowed the options to only two applications because I have tested them specifically on the E50, checking RAM usage, stability and overall performance. A much extended review can be found at All About Symbian. Since we are referring specifically to the E50, the options have been chosen to what fits best on this device. Other applications have not been chosen due to different reasons (either they consume too much memory, or they don’t fit nicely on the E50)
Just to note, the applications have been tested with a Gmail account, with POP access enabled, and both applications have been tested only with 24×7 push email settings, meaning, they are pushing emails all the time.
System Seven
The first choice that we have is System SEVEN by SEVEN Networks. Not to repeat what has been already said on the quoted article at All About Symbian, the future of this beta program is unknown, and we do not know if the final release will be free or not. The following is an overview of pros and cons:
Pros
* Emails can be truncated at any size. For people living in countries where carriers charge a lot for data transfer, email truncated at 1KB is enough to read sender, subject and first words of the email. The application provides through the menu the option to retrieve the complete email, and separately attachments (if any).
* Stability. It is indeed very stable. The connection can be paused at any time, and resuming it consumes just a few bytes and is very fast. New emails start to fall in the device inbox just a few seconds later.
* You can set more than one inbox for pushing simultaneously.
Cons
* Consumes more RAM than the other application tested, and for example, you can’t run simultaneously Active Standby, System SEVEN and Nokia Maps.
* Emails can’t be deleted on the device only yet. If you delete an email on the device it will be deleted on your Gmail account too.
Emoze
The second application tested is emoze. This has been selected as Editor’s Choice in the mentioned article on All About Symbian, and not without reasons:
Pros
* Consumes less RAM than any other email pushing application.
* It is fast*, really fast (most of the time, my emails arrive to my device even before the Gmail Notifier on my notebook tells me that a new email has arrived)
* It is very stable
* You can delete emails on your device only, your Gmail account will not be touched.
* With additional software, you can push your desktop email to your device, making possible to push any email that can be retrieved via your email desktop client (though, unfortunately, this additional application works with just a few POP desktop clients, namely Outlook and Lotus Notes).
* Scheduling is much more advanced on emoze, you can set specific days and times in which emoze will active push mail.
* When an HTML formatted email is sent, emoze strips all html tags, leaving a text-only email. This saves a lot of characters, and makes emails easily readable.
Cons
* You can only truncate messages to 5KB (less than 5000 chars) or 8KB (less than 8000 chars).
* Even if it uses much less RAM than any other email pushing application, you still can’t run at the same time Active Standby, emoze and Nokia Maps.
* You can set only one account.
* Startup takes much longer due to database integrity check on both device and server.
Conclusion
Both applications have their pros and cons. For me, one of the biggest advantages of System SEVEN is the possibility to truncate any email at 1KB and retrieve the whole email and/or their respective attachments. However, the fact that any email deleted on my device will be deleted also at my Gmail account is quite a big issue since the main idea of Gmail is not to delete any email anymore.
The only disadvantage of emoze is that emails cannot be truncated to less than 5KB. Considering the fact that we are testing applications to push personal email to our devices, I don’t see the “one inbox only” option as disadvantage (though this can be considered as disadvantage by many of you).
Finally, the unknown future of System SEVEN is a factor to consider before making a final decision. Despite the usual disclosure letter, emoze seems to be on the path of staying as a free service for personal use.
Personal Solutions For Push E-Mail On The E50
__________________
If the speed of light is 3x108 m/s, what's the speed of darkness?
nishantgandhi is offline   Reply With Quote
Thread Tools
How far can they push a common platform approach? rangaraj The Indian Car Scene!! 11 12th February 2008 14:20
Use of Push Button Starter mithun Technical Stuff 33 8th December 2007 23:45
SCOOP! BMW Spec sheet for India. 3 series & 5 series GTO The Indian Car Scene!! 48 4th September 2007 14:25
Personal Mail IDs naveendhyani Shifting gears 0 16th March 2006 11:18
What is the procedure for push-starting a car?? Deeps Technical Stuff 12 10th September 2005 14:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
