| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Support ![]() | Hi Guys, I have done a lot of google search for this problem but am stumped. I have a Nokia 6265 which I used for internet connection occasionally(Reliance). Few months back I got a new HDD and reinstalled XP, but did not bother with phone connection as I was always on airtel BB. Recently I downloaded the Nokia PC suite, and connected my mobile to the computer and was able to transfer data, do a sync etc., etc., but when I try to connect to the dialup internet using the "Nokia 6265 modem" I get Error 692. I first suspected that I am unable to access the modem. So I went into device manager, and right clicked on the modem, and in diagnostics did a query. It worked fine, and I was able to do ATI query. So the computer can query modem. After that I even tried to clear the initialization string in the advanced settings, but every time I get this error 692. In my connection properties, the modem shows up as Nokia 6265 on COM6 which is same setting as device manager. I am able to query the modem also in device manager, but I am unable to dial in to reliance(Error 692) which says that there is a hardware error. I suspect that for this modem I need some custom initialization string or something? Any tips I need to try? I have modem compression enabled in both my connection and the device manager as suggested.
__________________ Reclaiming.....! |
| | #2 (permalink) |
| BHPian Join Date: Mar 2006 Location: http://www.wandering-online.com
| Wrong place for this mr Moderator http://www.team-bhp.com/forum/gadget...-all-here.html (The Mobile Phone Thread - Queries, decisions, discussions all here.)
__________________ wandering-online.com 08 2.2 Safari - 08 Accent - 08 Civic - 05 E240 - 01 Lancer - 03 Santro |
| | #3 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ Reclaiming.....! | |
| | #6 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Does this help or am i going in tangent? "Error 692: Hardware Failure in the Modem" Error Message When You Dial an RAS Server Found this on further googling, gotta run now for a meeting PPCSG -> 818 Pro's Modem Link Hardware detection... On trial and errors testing out various config changes I found that the key cause of my XP popping out the Error 692 is when I disabled Modem Compression at any end whether one and not the other or both (meaning the setting at modem properties in the Control Panel and the modem properties in the Dialup networking sections). The fact is Modem Compression must be enabled on the Control Panel modem properties for the HTC USB modem and the modem properties in the corresponding dialup networking configuration. Typically on normal modems, one should prefer to enable software compression over hardware/modem compression for better performance, if software compression is available. So I typically disables the use of modem compression. However it seems that the HTC modem, whether hardware or driver need to have the modem compression turned on regardless.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 5th May 2008 at 15:16. |
| | #7 (permalink) |
| Team-BHP Support ![]() | I have been through both the links. Reading that I have enabled compression in both dialer and hardware settings. I will try disabling compression in both and see. But my gut feeling is that the problem is related to some part of Nokia Pc suite accessing the phone continuously. But then I am able to query modem from the device manager.
| | #8 (permalink) |
| Did you try re-installing the software? Sometimes this helps. One more stupid question, are the phone setting correct and are you able to access net from the phone?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #9 (permalink) | |
| BHPian Join Date: Feb 2007 Location: Delhi
| Quote:
And yes are you able to access net in-phone. Stupid question asked but will be helpful for troubleshooting the thingy. | |
| | #10 (permalink) |
| Newbie Join Date: May 2007 Location: Navi Mumbai
| @tsk, Go to device manager>Nokia modem's properties. Search for a text entry labeled "Extra Initialization Commands" (or something like similar sounding). Write the following text: AT+CRM=1 Hope it should solve the problem. This was the case with my Nokia 6235 (Reliance cdma) hence I guess this could be the solution. @mods: I posted this post twice by accidental pressing of enter key, pl delete the incomplete one. Thanks in advance.
__________________ A fine is a tax for doing wrong. A tax is a fine for doing fine. |
| | #13 (permalink) |
| Team-BHP Support ![]() | Tried both ATX and the above command, no luck Here is the result of query modem 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\tapisrv.dll, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\unimdm.tsp, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\unimdmat.dll, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\uniplat.dll, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\drivers\modem.sys, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\modemui.dll, Version 5.1.2600 05-05-2008 20:31:03.937 - File: C:\WINDOWS\system32\mdminst.dll, Version 5.1.2600 05-05-2008 20:31:03.937 - Modem type: Nokia 6265 USB Modem 05-05-2008 20:31:03.937 - Modem inf path: oem26.inf 05-05-2008 20:31:03.937 - Modem inf section: ModemDeviceInstall6265 05-05-2008 20:31:03.937 - Matching hardware ID: nmwcd\vid_0421&pid_0437&cdc_modem 05-05-2008 20:31:03.968 - 115200,8,N,1, ctsfl=1, rtsctl=2 05-05-2008 20:31:04.000 - Initializing modem. 05-05-2008 20:31:04.015 - Send: AT&F<cr> 05-05-2008 20:31:04.015 - Recv: <cr><lf>OK<cr><lf> 05-05-2008 20:31:04.015 - Interpreted response: OK 05-05-2008 20:31:04.031 - Send: AT E0 V1 &D2 &C1 &S0 S0=0 +dr=1<cr> 05-05-2008 20:31:04.031 - Recv: AT E0 V1 &D2 &C1 &S0 S0=0 +dr=1<cr> 05-05-2008 20:31:04.031 - Command Echo 05-05-2008 20:31:04.031 - Recv: <cr><lf>OK<cr><lf> 05-05-2008 20:31:04.031 - Interpreted response: OK 05-05-2008 20:31:04.046 - Send: AT+IFC=2,2;+CVHU=1<cr> 05-05-2008 20:31:04.046 - Recv: <cr><lf>ERROR<cr><lf> 05-05-2008 20:31:04.046 - Interpreted response: Error 05-05-2008 20:31:04.046 - Session Statistics: 05-05-2008 20:31:04.046 - Reads : 0 bytes 05-05-2008 20:31:04.046 - Writes: 0 bytes ATQ0V1E0 - OK AT+GMM - +GMM: Nokia 6265 AT+FCLASS=? - +FCLASS: (0,2.0) AT#CLS=? - COMMAND NOT SUPPORTED AT+GCI? - COMMAND NOT SUPPORTED AT+GCI=? - COMMAND NOT SUPPORTED ATI1 - COMMAND NOT SUPPORTED ATI2 - V HL190V0600.nep26-05-06RM-66(c)NMP, PRL:None ATI3 - Nokia 6265 ATI4 - 2004 W28 ATI5 - COMMAND NOT SUPPORTED ATI6 - COMMAND NOT SUPPORTED ATI7 - COMMAND NOT SUPPORTED
| | #14 (permalink) |
| Did you try reinstall? Trust me with windows this works most of the time. If not done, maybe worth a try and those restarts.
| Thread Tools | |
Similar Threads | ||||
| The latest fashion from Nokia - new Nokia 8800 | khanak | Gadgets, Computers & Software | 29 | 26th March 2008 01:56 |
| Error 11 and error 17 in pioneer MP3 | rajivanoj | Ask the Gurus | 20 | 30th January 2008 15:47 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
