Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 9th May 2008, 08:47   #16 (permalink)
aaggoswami's Avatar
Default Tough to believe.
I really dont believe that 780G has the ultimate onboard graphics, but yes it is up with the best.
My AMD 690V came with X1250.
Check gigabyte.in and look for GA-MA-69VM-S2 model. I think gigabyte has two or three models with this chipset and the one with 690G has X1300.
Just as I mentioned, Intel 965 chipset motherboard wont play Crysis, but I did on gigabyte. Onboard graphics of AMD have most of the times rocked.
My father's AMD Athlon 64 3000+ with MSI motheboard ATi 200express chipset ( I might be wrong here, what I mean to say is that ATI at that time made so good onboard grahics that even quite old motherboard graphics could handle such a game ) was able to play NFS Carbon.
Intel onboard graphics have always been lions and tigers on the paper, but not is real world. you can observe in my earlier post that 780G does better than G33.
But I am not in for 8200IGP, I am waiting for Larrabee from Intel( this is the one that is creating trouble for nVidia ).
__________________
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is online now   Reply With Quote
Old 9th May 2008, 10:35   #17 (permalink)
madbullram's Avatar
WOW...thanks guys...as usual u al;l rock...now config after readin all looks like:
DUALCore AMD X2 4400+AM2 2850 Rs
Gigabyte GA-MA74GM-S2H AMD740G,V,16x,S,HDMI 3900 Rs
Seagate 320GB - SATA 16mb/Baracuda 7200 3250 Rs
OEM / Brnd.1.0 GB-DDR2 667MHZ- PC5300 825X2 1650 Rs
Cabinet:
Zebronics Class - 10 Models w/USB, Audio & Fan 1200~1400 Rs
Total - 13K
Is this good?
1. I slipped the Graphic card as I dont push my PC with games, its usually my PS2 and Xbox
2. Went for a higher Hard disk has have loads of music and DVDs
3. Thinking of a new cabinet as my old cabinet look as bad as me (is my choice good? what SMPS shd I look for?)
madbullram is offline   Reply With Quote
Old 9th May 2008, 11:01   #18 (permalink)
greenhorn's Avatar
get DDR 800 ram. should be only a few hundred rupees more.
and maybe a 4800+, since you do a lot of media encoding
I dont know , on the other hand if the 740G is worth this price. See if you can get a jetway M2A692 GDG. Its a 690G based board for <3k
__________________
2007 Indica DLG
My next Truck will be a Safari!
greenhorn is online now   Reply With Quote
Old 9th May 2008, 11:02   #19 (permalink)
im_srini's Avatar
Hi Ram, surprisingly something similar happened to me a couple of months ago ! Had a 2-year old AMD & ASUS K8V-MX combo which gave up the ghost in Jan. Have switched to an Intel & Biostar combo now. I use my PC primarily for gaming, so used the opportunity to switch from my 7300 to an 8800
Was pleasantly surprised to see that somebody had put up the price-list from "Delta Peripherals" here, the person who runs it is very knowledgeable. A basic SMPS should cost you around 400 bucks, but you can get ones from CoolerMaster for around 1,500 - their prices go all the way up to 4,500 & even 8,000 depending on your power needs.
im_srini is offline   Reply With Quote
Old 9th May 2008, 12:51   #20 (permalink)
splitsecond's Avatar
Cabinet:
Total - 13K
Is this good?
put 800mhz ram and Amd 4800+ then its ok
__________________
|~Pro UT Fragger~|
"I want to know God's thoughts; the rest are details."
--Albert Einstein
splitsecond is offline   Reply With Quote
Old 9th May 2008, 13:35   #21 (permalink)
madbullram's Avatar
Green: Is Jet boards as good as Giga ? Dleta guys have :
Jetway ATI690G,V,16x,8Ch,S 2975 RS
Split: OKay will do that...
Any suggestions on cabinet and what SMPS...to run this config effeciently...
Old 9th May 2008, 13:43   #22 (permalink)
greenhorn's Avatar
From what I've seen, jetway makes quite VFM stuff. as long as its not asus , you shouldnt have any issues.
Make sure when you buy that whatever you are getting is a 690G and not 690V which is a lower end variant.
__________________
2007 Indica DLG
Old 9th May 2008, 17:07   #23 (permalink)
aaggoswami's Avatar
Default Slightly upgrade.
Jetway are not problematic and RMA is reasonably effecient.
Originally Posted by splitsecond View Post
put 800mhz ram and Amd X2 4800+ then its ok
Yes X2 4800+ will be good along with DDR2 800mhz, but read ON.
Jetway are not bad.
Now if you look into some other of my posts, I have clearly mentioned that how my processor is spoiled along with motherboard because of wrong SMPS selection. Go to no158 reply of mine.
http://www.team-bhp.com/forum/gadget...ration-11.html (Help Computer Configuration)
So dont go for any bad SMPS. 400W is best if you dont plan to plug in a dedicated graphics card. If you do so, then buy 600W SMPS.
Regarding cabinet, iBall cabinets will do, but if your location is good ( read Megacity ) then buy from Antec or ASUS (ASUS are hard to find and 99% computer vendors dont even know ASUS does sell cabinets ).
Antec is best . usually a typical game console will have one 120mm fan running in front and two 80mm fans at the back.
But you are not utilizing for gaming, front fan should not be a prority and one 92mm fan at rear will do the job.
Iball Gamer cabint will do job for you. will cost around 1500-1700( comes with 400W SMPS and it works good, I am using the same ). Antec, if possible to put into your budget, is the perfect option to be implemented.
Also look for Intex Innovator cabinet, but this should be your last option if nothing else works out. If possible just avoid Intex.
My advice is to you is , if budget exceeds with X2 4800+, 800mhz RAM, then go for X2 4400+, 667mhz RAM but dont skimp on well ventilated cabinet and good SMPS. These two thing can some time make or break things.
__________________
Old 10th May 2008, 18:44   #24 (permalink)
madbullram's Avatar
aagg: Amazing...thanks for such detailed inputs. I will scout for iBall and Antec. The dealer has Zebronics...hows Zebronics?
So for now, my config looks like:
AMD X2 4800+.........3475 rs
ATI690G.................2975 Rs
1GB DDR2 800 x 2......2000Rs
Seagate 320GB - SATA 16mb/Baracuda 7200.......3250 Rs
iBall or Antec with 400W SMPS and 92 mm fan.....rs 1500
total comes to around 13000
Old 10th May 2008, 18:55   #25 (permalink)
If you want a good reliable smps go for "zebronics 500watts pure platinum " but it cost 1700/-.
A good looking cabinet is zebronics peace with led fans and transparent side panels which cost 1800/-(without smps)....or u can go for any cheaper but large cabins.
__________________
|~Pro UT Fragger~|
--Albert Einstein
Old 10th May 2008, 19:07   #26 (permalink)
greenhorn's Avatar
I've had bad experiences with not one , but two zebronics SMPS, and my current rigs run fine on iball, but aaggoswami had issues with his iball PSU's .
if you can afford, get the antec , else i suppose the iball ( or look for VIP or Powersafe- they are equally good )
__________________
2007 Indica DLG
Old 10th May 2008, 19:26   #27 (permalink)
madbullram's Avatar
Antec Cabinet is atr 3K without SMPS :(...add SMPS...it comes to 3500Rs...
One more stupid question...do I have to buy a USB port seperately or it comes with the motherboard?
Old 10th May 2008, 19:54   #28 (permalink)
greenhorn's Avatar
no, i meant buy a generic cabinet and an antec PSU. I wouldnt give too much thought to buying a PSU though. for me , whatever comes with the cabinet works quite fine , since you arent puttting in power hungry gfx cards and things like that. any generic 400W should do fine
the motherboard will have USB ports at the rear , and the cabinet usually has USB ports. ( some cheap generic cabinets skimp on these and the front panel headphone jacks) check that out before you buy choose a cabinet
__________________
2007 Indica DLG
Old 10th May 2008, 22:31   #29 (permalink)
aaggoswami's Avatar
Default Good options
Avoid Zebronics. Personally I dont have any experience, but one friend of mine had to replace 2 SMPS of Zebronics. The second one was lost today. He called me up and we realized the problem. This time its going to be iBall.
If you read carefully, I am presently running iBalll 400W SMPS and I had ISSUSES WITH INTEX SMPS, NOT IBALL. IBALL IS WORKING FINE WITH MY SETUP THAT DOES CONSIST OF ONE DEDICATED GRAPHICS CARD.
iBall is, I believe the best option for madbullram. I believe that you meant the same from above post.
Generally there are four USB ports at the back of motherboard in I/O back panel. Just for information, the chipset of your setup will mostly support upto 8/10 USB connections.
But when you decide on the cabinet, be sure to have atleast 2 USB front ports along with front audio ports. There are some really cheap cabinets avaiable that skip giving these front USB and Audio ports. Well just avoid them. You will really appreciate the convience of front USB and Audio ports.
__________________
Old 10th May 2008, 22:43   #30 (permalink)
madbullram's Avatar
So I will settle for iBall with 400W SMPS or if i can will buy an ANtec SMPS and fit it to iBall?
Thread Tools
Which Processor, Motherboard & RAM? shuvd Gadgets, Computers & Software 47 4th May 2008 23:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
