| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Guys, My 5 year old system hit bucket...I had an AMD processor dont even remember the config...now the processor and motherboard has gone... My existing system has: 1 Sony DVD writer, 1 Seagte 160 GB Hard disk, 1 one CD Drive.. 2 X 512 MB Infineon DDR, 266, CL2 RAM Dont remember the SMPS Now my question, can I just buy another processor and motherboard and just fit to my existing cabinet? WIll my existining RAM work? I can spare upto 15K I use my house system for movies and games as have my lappy for regular work... |
| | #2 (permalink) |
| BHPian | Ok. some bad news. Newer motherboards take DDR2 Ram. you can sell your old DDR RAM and buy 1 GB DDR2 ram with the buyback price ( DDR2 ram costs only 1/2 that of DDR1 ram - and its better !) Newer motherboards have only a single IDE channel . You'll have to say goodbye to either your hard disk or optical drives. I suggest you get a new SATA Hard disk ( the IDE HDD will slow your otherwise fast system). keep the two optical drives on the IDE channel, and put the IDE HDD in a USB enclosure , and use it as a backup hard disk ![]() I suppose this can be merged with this thread http://www.team-bhp.com/forum/gadget...board-ram.html (Which Processor, Motherboard & RAM?)
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 8th May 2008 at 21:29. |
| | #4 (permalink) |
| BHPian | A new dual core AMD processor(X2 4200+) -2700 motherboard(M2A VM) - 3400 Ram( 1 GB RAM - Branded) - 1k HDD ( 250 GB Sata Seagate) - 2.4k USB case for your IDE HDD - 500 comes to 10k you can improve on this - intel processor + mobo, more ram, or better processor, HDD etc made a VFM config to give you some good news. If you want cheaper , can come up with a lower end config which is cheaper by a few K Your old HDD seems to be Parallel ATA hdd. SATA = Serial ATA. its the new standard for connecting HDD's All rates from delta peripherals in chennai http://www.deltapage.com/
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 8th May 2008 at 21:41. |
| | #6 (permalink) |
| Newbie Join Date: Mar 2008 Location: calicut
| yoiu can also find a old Amd processor & motherboard,You will get Amd 3000+MB under 4k or may be less,so u can use existing HDD and ram from your older system.
__________________ |~Pro UT Fragger~| "I want to know God's thoughts; the rest are details." --Albert Einstein |
| | #7 (permalink) |
| BHPian | Being the shameless AMD Fan I am, i would recommend an upgrade to the gigabyte GA-MA78GM motherboard ( has the best onboard graphics currently available ) + processor upgrade to X2 4800+ and another GB of Ram would be another 3.3k . the rest i suppose you can use for a bigger HDD I'm not familiar with intel configs though :(
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 8th May 2008 at 22:07. |
| | #9 (permalink) |
| BHPian | yup, the 740G has the same onboard graphics as the 690G which is a generation older. the southbridge is the same as that of the 780G - but that doesnt make a big difference. the onboard graphics in the 690G/740G is from the old Radeon X1300 series. a bit lesser in performance, called the X1250. the one in the 780G owes its ancestry to the more recent HD3450, and is called the HD3200 ![]() of course , if you are more serious about gaming , get a dedicated gfx card. what sort of games do you play/ did you have a gfx card before ?
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 8th May 2008 at 22:22. |
| | #13 (permalink) | |||
| BHPian Join Date: May 2007 Location: Vadodara
| Quote:
Usually in other motherborads if you install a dedicated graphics card, then the onboard graphics will completely shut off. This is not the case with 780G, and thats why it has better performace. However if only the onboard graphics are used, they are not the masters of graphics, and perform slightly better than G33 from intel. Quote:
I would like you to go for AMD here as the budget is restricted. May be AMD Athlon X2 4400+ along with Gigabyte with 740 chipset ( I was able to run Crysis on gigabyte GA-MA69VM-S2 at 1024 X 768, with chipset 690V X1250 onboard graphics) motherboard is perfectly fine for you as far as motherboard and processor combination is concerned. Make sure that you have proper ventilation for Dual core AMD if playing a lot of games.
__________________ EVENTUALLY FATE DECIDES EVERYTHING. | |||
| | #14 (permalink) |
| If you are going for new system AMD Athlon 64 X2 4800+ (3550/-) M2N MX - SE (2600/-) XFX 8600GT(256mb) (4750/-) Seagate Sata 2 (2400/-) Transcend DDR 2 1GBX2 (2000/-) You can get this config under 15k ,This system with 8600gt can easily handle most of the games in high settings and can even play crysis in medium settings. Vista will run in full glory with this.
| | #15 (permalink) | ||
| BHPian | Quote:
. And the X3100 series from intel are just paper tigers. they fare well only in benchmarks , not in game performance
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 9th May 2008 at 05:53. | ||
| Thread Tools | |
Similar Threads | ||||
| Which Processor, Motherboard & RAM? | shuvd | Gadgets, Computers & Software | 47 | 4th May 2008 23:52 |
