Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 10th May 2008, 20:08   #1 (permalink)
trrk's Avatar
Default PS2 to USB adapter
Hi aaggoswami,
This is from another post of yours.
> There will be people who will give you one adapter where you will have One
> usb plug that goes into laptop, and the two other plugs from which PS/2
> keyboard and mouse are attached. STAY AWAY FROM THIS.
Any particular reason for the above?
We have been using it since more than 18 months with our laptops. So far have not faced any problems.
__________________
Rajesh
-Marina LS, Oct 05, 43100 (43578) kms, 13.93 kpl
-City CVT, Sep 07, 14301 kms, 13.19 kpl
trrk is offline   Reply With Quote
Old 10th May 2008, 20:28   #2 (permalink)
condor's Avatar
@trrk, which thread was this post in ? What was the context ?
__________________
Life is Analog. Digital is an approximation.
Old 10th May 2008, 20:45   #3 (permalink)
akshay1234's Avatar
i think instead of making a post hes made a new thread.
akshay1234 is online now   Reply With Quote
Old 10th May 2008, 22:43   #4 (permalink)
aaggoswami's Avatar
Default We did.
Originally Posted by trrk View Post
Hi aaggoswami,
We did face this problem on LG FD-224QA2 laptop and thats why I asked the person to avoid this set up. I have also mentioned that I had four USB ports that proved to be luxury while doing this. If someone is really comfortable and does not face problems, then its fine, but I did and so did a couple of my friends who have HP laptops ( remember that I have mentioned more than once that I am from computer realated field and so almost all my mates have 2 computers, i.e one laptop and one desktop and some desktops involve me as assembler ).
This post was not to target someone directly. I just had mentioned what I felt was best learning curve from my expeirence. We have 4 desktops and one laptop. Laptop and one desktop have intel hardware and 2 desktops are AMD and one is Cyrix with Windows 98.
Please note that I never pinpointed this to any other user.
Nowadays, we can easily plug USB keyboard and mouse ( our lab has all keyboards and mouse as USB in 120 desktops running with E6600) into desktops and use them and so we can do with PS/2 also. So USB is not a bad option.
I hope that I have made it very clear.
__________________
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Old 12th May 2008, 11:19   #5 (permalink)
trrk's Avatar
> @trrk, which thread was this post in ? What was the context ?[/quote]
@condor, this was taken from the thread regarding a heating up LG laptop. Since I wanted to ask about the using of PS2 adapters and did not want a ram from the moderators for taking off on an unrelated to the original topic matter, made a new post.
@akshay1234, I hope the above makes it clear.
__________________
Rajesh
Old 12th May 2008, 11:29   #6 (permalink)
trrk's Avatar
Hi aaggoswami,
I think you mistook my query.
Sorry. All I wanted to now was about your warning about not using the USB adapter with two PS2 inputs on the other side. I am using such adapters for the 4 laptops that I use. Is there any relation to this adapter and heating up of the laptop.
In my purely user's experience, my LG and Sahara Laptops (both 14.1" screens and of square shape) heat up and I keep a watch on the temperature with an utility called mobile meter. They obviously don't like DOS applications and my inventory software is DOS based and has to be used.
Though I don't have a widescreen laptop of the above brands, Acer's 14.1 and 15.4" widescreen laptops don't have any problems of overheating as I use 2 of the former and one of the latter.
As I type my LG is showing a processor temperature of 75degree C and HDD is at 37 degree C.
I still want to know about the twin PS2 USB adapter about which you have talked.
Once again, sorry for misleading you.
__________________
Rajesh
Old 14th May 2008, 23:36   #7 (permalink)
aaggoswami's Avatar
Hi aaggoswami,
NO, there is no realtion to the heating up of laptop with the adapter.
Overheating is generally caused be insufficient/improper ventilation.
Insufficient/Improper ventilation apart from poor quality of parts used and poor design are the major factors for overheating.
LG ( lower end models) laptops have tendency to heat up, and we are facing that.
Well, about the adapter, it goes like this. Its basically Y shaped, On one end you have USB port that goes into the USB port of laptop that happens to be the base of Y. The two upper points of Y are for PS/2 keyboard and mouse to be plugged in. It is pretty cheap and will cost about 20-30rs. i.e. the street price. The quality is a question also. Generally, they are from China with the worst possible build quality. This is also one of the reasons why avoid them. Getting this adapter with high quality is difficult.
Hope I am able to explain properly.
__________________
Old 16th May 2008, 19:20   #8 (permalink)
trrk's Avatar
I can understand about the quality. But apart from quality does it have any other ill effects?
I have been using it since more than 18 months in multiple laptops with no visible ill effects.
__________________
Rajesh
Old 17th May 2008, 09:37   #9 (permalink)
aaggoswami's Avatar
There are no ill effects at all. Its all about quality of the adapter. If the adapter quality is not good then there might be connection problems which, frankly speaking, are irritating. And apart from that the reliability is also not good. Thats why going in for the USB keyboard and USB mouse will help as there wont be any connection problems or reliability issues.
The one I had got was of not good quality, but the next three were also bad, so went on to purchase USB that are now working very fine.
Again: THERE WONT BE ANY ISSUES IN THE PERFORMANCE OF THE LAPTOPS LIKE OVERHEATING.
__________________
Old 18th May 2008, 20:08   #10 (permalink)
trrk's Avatar
> OVERHEATING.
Thats fine enough. I can live with the occasional trouble (they are not giving any trouble now) rather than waste all those PS2 keyboards and mice that I had from the desktops.
__________________
Rajesh
Old 18th May 2008, 20:15   #11 (permalink)
aaggoswami's Avatar
> OVERHEATING.
Yes, if you have any PS/2 keyboards or mouse, then this adapter is worth spending 20-30rs. We had one TVS-Gold keyboard from desktop ( that CPU was being repaired ) so thought that lets try this adapter. It did not work realiably and it was working well again with that desktop. So Went for USB. In your case what you have done is nothing to fault with.
What's more, its working fine so no need to worry.
__________________
Thread Tools
Help needed : ipod adapter ready roopakr Ask the Gurus 13 24th April 2007 10:24
USB adapter hacks for pioneer 6950ib overdose14 DIY - Do it yourself 3 17th April 2007 11:15
Any Delhi PS2 owners? DCEite Gadgets, Computers & Software 10 10th September 2006 13:22
PS2 Memory card problem DCEite Gadgets, Computers & Software 2 4th September 2006 01:21
USB GPS adapter for sale vivekiny2k Shifting gears 6 21st May 2006 03:42
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
