Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 14th May 2008, 12:10   #16 (permalink)
Not sure is it works on Vista. There is an option in PM to create a bootable disk (once its installed).
So, you can install it on some PC Running XP and then create this boot disk (CD).
Boot from this CD and then you can create extended partitions (by expanding existing partition and then splitting it into two).
NetfreakBombay is online now   Reply With Quote
Old 14th May 2008, 13:01   #17 (permalink)
kb100's Avatar
Okay... Extended partition - will this be under the main partition - like a folder?
What are the possible downsides of having a 200GB C Drive?
I have had more than a dozen ppl telling me that this partition bizz is all passe' - as in should the disk go wrong one can always toss it into a USB mount and dig our data etc etc.
Any views folks??
__________________
A closed mouth gathers no Feet.
kb100 is online now   Reply With Quote
Old 14th May 2008, 13:13   #18 (permalink)
Yes it will be inside primary partition, but its like any other partition for all practical purposes. It will have its own drive letter (like I: / E.
I think only downside of 200 GB partition, that affects day to day use is difficulty in managing data. I find things easier to manage if partitions are earmarked for use like Music/Work/Data/Snaps.
Old 14th May 2008, 13:30   #19 (permalink)
kb100's Avatar
Hmmm... So does that mean that should something go wrong with C then it will take this partition down with it too? (cause C drive is where the space is right now)
IF it is so then I dont know if it'll be drastically different from having a folder saying "D", and then saving everything in it under various subfolders.
I Have the service enginineer dropping by for installtion etc - will this guy be able to fix this/ reinstall etc??
Last option - give it back to Dell and ask them to fix it!
__________________
Old 14th May 2008, 13:55   #20 (permalink)
trrk's Avatar
The guy who comes to do the installation will just do that and make sure you have received what you ordered. In fact, he is supposed to open the pack.
I was in the same boat as you regarding the 250GB HDD's partitioning in my 1525. While ordering, there was an option of choosing for a smaller C partition, but that was costing extra and so did not go for it.
I was new to Vista and the shrinking and creating a new partition did not work, though shrinking was possible.
I left it at that. I still have not started using it as I am yet to bring it to my old lap top's state regarding the programs etc.
By the way, if you have more than two partitions, the Dell Media direct won't work, according to the technician who came here. I was advised to talk to their support help line regarding the partitioning and that they would hand hold me through the process. I am a little hesitant at telephonic help and resigned to the fact that I have to use it a single partition, though I am comfortable with 4 partitions until now.
You could do that, I guess. Or you can always start from scratch. In this case your recovery partition goes for a toss and I was told that that can be created only in the factory.
All the best.
__________________
Rajesh
-Marina LS, Oct 05, 43100 (43578) kms, 13.93 kpl
-City CVT, Sep 07, 14301 kms, 13.19 kpl
trrk is offline   Reply With Quote
Old 14th May 2008, 14:16   #21 (permalink)
kb100's Avatar
Its way cheap of them - why should you charge more for just creating a partition - I am sure its an automated process at these factories - just plug the system into the network and the whole image or whatever is most likely dumped one shot. I doubt if it even requires a person on standby - maybe one for an entire batch to kinda eyeball for any system that stalls.
__________________
Old 14th May 2008, 21:13   #22 (permalink)
aaggoswami's Avatar
Default No.
Is Partition Magic Vista compatible?.. If so which version?
Just realized, that it crashed with Vista and there is data loss.
Do this:
Right Click on Computer and click on Manage
On the left pane, go to Storage and click on Disk management.
Right click on the partition you want to modify and then select shrink volume.
This has worked on Vista. I have personally done this.
__________________
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Thread Tools
Crashed Hard Disk - Data Recovery?! Gordon Gadgets, Computers & Software 52 30th January 2008 18:31
Mirroring partition while HDD upgradation tsk1979 Gadgets, Computers & Software 40 18th September 2007 07:36
Car Partition like New York Taxis - Installation advice please Murugan Modifications & Accessories 16 13th June 2007 21:16
Need to recover Data from my Extnl 200 GB USB Hard Disk muni Gadgets, Computers & Software 7 14th March 2006 22:19
Help: DVD rip to hard disk v1p3r Shifting gears 25 11th January 2006 17:33
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
