Old 8th February 2011, 08:22   #1696
mdsaab's Avatar
Thanked: 446 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
Sorry am travelling so i couldnt demonstrate. But you got it perfectly right there, thats exactly what i meant. It worked for me, so give it a try. Thanks sanagg1 for posting the example.
Originally Posted by sanagg1 View Post
If you pickup coordinated from google maps for Delhi these will be something like
28.650223,77.227707
By reversing i mean
77.227707, 28.650223
cheers
mdsaab is offline   Reply With Quote
Old 13th February 2011, 16:26   #1697
cool_dube's Avatar
Thanked: 397 Times
Default Map upgrade (for Garmin) from SatGuide
Guys,
I have April 2010 release of SatNav maps running on my Garmin Nuvi 205w. Am planning to buy the upgrade online - Current cost is INR 400. Has anyone tried upgrading their SatNav maps for Garmin? How easy/straightforward is the process? Given that the maps I am currently using are on a mini-SD card, would they send me another mini-SD card for the upgraded maps? Their web-site says that after purchase a link would be provided and I would be required to download a 'file'. I don't think I can get this file onto the mini-SD card I have. Also, there is no point copying this file to my Garmin device I guess.
Thanks in advance!
cool_dube is offline   Reply With Quote
Old 13th February 2011, 22:37   #1698
DCEite's Avatar
Thanked: 603 Times
Default Confused !
Guys,
I am a newbie to car GPS.
What i am looking at is a basic GPS navigation with street level maps and voice navigation. Don't require any thing more than this.
On the basis of posts here i have shortlisted following products:
Blaupunkt Travelpilot Lucca Gps Navigator With All India Navigation Maps
Cost: 7.5k
and
MapmyIndia Navigator RoadPilot For GPS Navigation | Maps
Cost: 8k
Whats confusing here is that travelpilot lucca has a bigger screen and more features than MMI road-pilot, but is still cheaper. Can't figure out why?
Also, my car does not have a car charger - its a old WagonR LXi with a covered car charging slot - i don't think there is any internal connection at all. Will it be difficult to get the charger installed in the first place?
DCEite is offline   Reply With Quote
Old 13th February 2011, 23:37   #1699
tsk1979's Avatar
Thanked: 16,015 Times
Car charger is an easy job, You can have it done either directly through car battery, or via a relay with the ignition acting as a switch.
Whatever you do, do not piggyback on any other circuit like Stereo system etc,
Old 14th February 2011, 00:25   #1700
esteem_lover's Avatar
Thanked: 451 Times
Install the cigarette lighter, costs only around 200 bucks.
If you want basic navigation, have you thought of a smartphone instead ?
Old 14th February 2011, 02:04   #1701
Thad E Ginathom's Avatar
Thanked: 8,341 Times
Does anybody know anything about Olive products, both in general, and specifically the OlivePad? Comes with MapMyIndia navigation.
Old 14th February 2011, 07:04   #1702
sanagg1's Avatar
May like to see
Olivepad (Samsung Galaxy Tab vs OlivePad VT100)
IMO a workable low cost solution
sanagg1 is offline   Reply With Quote
Old 14th February 2011, 07:21   #1703
sanagg1's Avatar
Default Re: Confused !
Guys,
Cost: 7.5k
and
Cost: 8k
Roadpilot is Window CE 6.0 with 500 MHz while lucca is window CE5.0 and 400 MHz.
See the tech specs at the link provided by yourself
IMO roadpilot is better product amongst two
Happy hunting
Old 14th February 2011, 10:18   #1704
DCEite's Avatar
Thanked: 603 Times
I have an unused Belkin car charger.
Belkin : AC Anywhere DC - AC Inverter
Will that do?
Already have a basic smartphone (smsung galaxy 3) with GPS. Still need a dedicated GPS device after having seen a glimpse of what GPS has to offer.
Old 14th February 2011, 12:30   #1705
sanagg1's Avatar
Will that do?
Just cross check the fuse ratings on lighter socket to avoid a blown fuse.
For 300W rating DC to AC converter current requirement would be ~25A
Old 14th February 2011, 12:58   #1706
shankar.balan's Avatar
Thanked: 5,343 Times
Thanks v much
One more query:
I bought my Garmin Nuvi 205W in England around 6-7 months back.
It worked perfectly well while I was driving around there and in Ireland etc because it came pre-loaded with UK Maps.
I chose at the time, to buy a device instead of renting one along with the rental car because the rental price for the Satnav and the buy price were more or less the same.
Then when I came back to India I bought and installed the MMI SD Card for India maps. Now its been working beautifully here as well.
I am visiting the UK again sometime soon and intend using my Satnav while Im driving around there - what will I have to do to get the Garmin back onto UK Maps mode? Will I have to remove my MMI SD Card from the device or is there a way of picking and choosing the country one is in and using the device while driving there, while leaving the SD Card as it is?
Thanks in advance.
Cheers.
SB
28.650223,77.227707
By reversing i mean
cheers
Old 14th February 2011, 13:21   #1707
cool_dube's Avatar
Thanked: 397 Times
Default Import of route from Google Maps/Google Earth to Garmin
Anyone tried this? Any pointers would be welcome.
Thanks in advance.
Old 14th February 2011, 13:23   #1708
DerAlte's Avatar
Thanked: 2,879 Times
If the UK map has not been deleted (unlikely that you would have), it will automatically use that map. Just make sure it is listed under Maps.
Old 14th February 2011, 13:26   #1709
cool_dube's Avatar
Thanked: 397 Times
Option A - Remove the SD card altogether. This would force the unit to refer to the default/internal maps (which I presume are still there in the device).
Option B - Instruct the unit to refer to internal maps only, while retaining the SD card. You need to check/uncheck the relevant options under - 'Settings' -> 'Maps' -> MapInfo
Hope that helps.
Old 14th February 2011, 13:33   #1710
May like to see
Thanks for the pointer to that thread.
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
