Old 11th April 2011, 11:57   #1876
nkapoor777's Avatar
Thanked: 91 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
Thanks NetfreakBombay! I tried the steps and right at the end got this error message in the cmd window. Any ideas what went wrong??
nkapoor777 is offline   Reply With Quote
Old 11th April 2011, 12:36   #1877
NetfreakBombay's Avatar
Thanked: 402 Times
Do you have cgpsmapper installed? If you have, we need to cgpsmapper visible to this .bat file. To do that, can you run this command :
dir c:\cgpsmapper.exe /s
That would tell us the location where cgpsmapper is present.
Then we will have to run a command before running install.bat to make it visible (add that exe to PATH).
Old 11th April 2011, 13:24   #1878
nkapoor777's Avatar
Thanked: 91 Times
Voila! I copied the cgpsmapper.exe file to the mapsource maps folder and then ran the install.bat and it worked. Now Mapsource lists the Satguide OneIndia maps but asks me for an unlock code???
Old 11th April 2011, 13:31   #1879
Thanked: 402 Times
In step 1, when you select the .img file in GmapTool and Press "Info", it will show some stats.
Unlock code is part of that. I think its towards the end.
Old 11th April 2011, 13:36   #1880
Has anyone tried MMI maps on Garmin Nuvi devices? I am getting a Nuvi 3790 shortly and apparently the MMI maps work on it.
harishsegar is offline   Reply With Quote
Old 11th April 2011, 13:38   #1881
Thanked: 402 Times
MMI maps are available for Nuvi 3790. These maps cost approx 7k.
Old 11th April 2011, 14:17   #1882
nkapoor777's Avatar
Thanked: 91 Times
Thanks a ton NetfreakBombay!
It works like a charm now! Finally I will be able to search for waypoints on the PC before exporting them to the Garmin. How I wish I had done this sooner?
Old 11th April 2011, 19:20   #1883
vnabhi's Avatar
Thanked: 1,317 Times
Congrats! I got tied up with something urgent today, so I will give it a shot tomorrow.
So are there any more instructions to add to what NetfreakBombay has suggested?
Old 11th April 2011, 23:06   #1884
nkapoor777's Avatar
Thanked: 91 Times
^^^^ Go through post# 1878 above. I got myself tangled up while using cgpsmapper app.
Old 12th April 2011, 10:56   #1885
sumathindra's Avatar
Thanked: 223 Times
Last friday i finally bought the mapmyindia vx 140s at lathangi motors, paid 10k for it. Next day hit the road to srirangapatna and the map worked like a charm. I was pleasently surprised when yesterday there was a guy from mapmyindia turned at my home for a demo!
I am told it still doesnot have door numbers however in the next 6 months it will be incorporated. Still exploring the device
sumathindra is offline   Reply With Quote
Old 12th April 2011, 13:37   #1886
vnabhi's Avatar
I got a different type or error today, per screenshot in attached file.
Any clues on how to overcome this?
The errror reads as :
'compiling preview map.
Cannot find import: DLL may be missing, corrupt or wrong version
File 'SENDG.DLL', error 126
File Missing: mapset.img aborting install.
Press any key to continue---
Garmin_MaprsourceError.docx
Old 12th April 2011, 15:29   #1887
Sudipto-S-Team's Avatar
Thanked: 266 Times
Default Any feedback on Garmin's Nuvi 215?
Is anyone here using the Garmin Nuvi 215 (that's the only one officially available in Calcutta)? I wanted to understand how authentic and dependable the Navteq maps being used in them are. I am not so concerned about the cities (though that feedback would also help) but for rural/offbeat India I would love to know will it solve our problems of navigation or complicate matters further?
Would like to hear from actual users before deciding whether to go hi-tech on Indian highways or stick to good old truckers' advice?
If there is already a thread on this then I am sorry and would like to be pointed please.
Sudipto-S-Team is offline   Reply With Quote
Old 12th April 2011, 16:30   #1888
Thanked: 7 Times
Sudipto,
Am also in the same boat as you can see from my earlier query regarding similar needs;, more interested in off city routes than city ones and caught between MMI and Garmin Models available in India. After looking at possible options , I am thinking it is more prudent to go Mapmyindia path as its tough to get reviews on the new Navteq maps - so no chance of verifying that part, whereas the new MMI ones seems to be pretty good.
With new SirF chipset, the satelite locking should also be a little better and more than that the in a GPS environment, the device is as only as good as the maps, which as per the current consensus MMI is definitely better.
Cheers.
Unbranded is offline   Reply With Quote
Old 12th April 2011, 18:09   #1889
Thanked: 266 Times
Unbranded
Thanks for your thoughts. MMI is tested in India. Very true. Many team-bhpians have gone to remote locations with it and have found it to be useful.
But being a Foretrex 101 user for long I am slightly biased towards Garmin ;-) Navteq is also a very big global player. I am more than confident that they will keep updating their maps pretty frequently.
I just need to catch hold of someone who is using a Navteq map. They show a map of your city when you log on to their site (Navteq I mean) and at least the Calcutta map that I saw is pretty decent. I will spend more time on their sample map from home tonight.
Sudipto
Old 12th April 2011, 23:19   #1890
vnabhi's Avatar
Attachment 530098
I've managed to overcome that error by copying the concerned DLL file to the same folder where the install.bat was located. The install ran to success.
But I've got stuck up on Mapsource with the same unlock code error. I tried connecting the Garmin device and then clicking on 'Unlock Online'. Though the product id and Sl Number of the device matched, the unlock code was not matching.
What is the unlock code? I see several lines when the 'info' button' is pressed on the Gmap tool. I tried the last 3 lines, but none worked.
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
