Old 13th April 2011, 01:09   #1891
NetfreakBombay's Avatar
Thanked: 370 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
Originally Posted by Sudipto-S-Team View Post
I just need to catch hold of someone who is using a Navteq map. They show a map of your city when you log on to their site (Navteq I mean) and at least the Calcutta map that I saw is pretty decent.
You can check coverage of Navteq on Ovi Maps it has improved a lot in last update.
Overall, MMI covers maximum number of cities. Satguide and Navteq cover around 800. And within cities, MMI covers more buildings and other POIs.
Navteq's coverage is lesser, but accuracy is higher.
In terms of highways, all three have similar coverage.
Traveled to MP (from Mumbai) few weeks back. Had all three maps. Highways coverage is spotty for all of them. Best to use that as a guidance but confirm that for smaller turns out of city.
Originally Posted by vnabhi View Post
What is the unlock code? I see several lines when the 'info' button' is pressed on the Gmap tool. I tried the last 3 lines, but none worked.
Can you PM me the output of Info? One of these three should have worked. You can try doing that after removing the device.
Old 13th April 2011, 03:02   #1892
nkapoor777's Avatar
Thanked: 88 Times
I've managed to overcome that error by copying the concerned DLL file to the same folder where the install.bat was located. The install ran to success.
But I've got stuck up on Mapsource with the same unlock code error. I tried connecting the Garmin device and then clicking on 'Unlock Online'. Though the product id and Sl Number of the device matched, the unlock code was not matching.
Don't use the "Unlock online" option. Simply go to the other tab on this box which reads "Unlock Regions", click "Add" and paste the unlock code in the first dialogue box. The unlock code consists of 25 alpha-numeric characters (you can get this from the gmap tool).
nkapoor777 is offline   Reply With Quote
Old 13th April 2011, 11:32   #1893
vnabhi's Avatar
Thanked: 1,246 Times
Thanks guys. I followed the advice of using the 'Unlock Regions' and it looks like it worked. I am no longer getting that message to unlock the Satnav maps.
So the next steps I preseume are the connect the device and then use the transfer option on MapSource with 'Receive from Device' selected?
I don't see anything as of now in MapSource without the device connected.
Old 13th April 2011, 11:46   #1894
Thanked: 370 Times
Try finding some place without the device connected. Does that work?
Old 13th April 2011, 13:30   #1895
vnabhi's Avatar
Yes, now it works. I clicked on the Find menu and then on 'Find nearest places'. Somehow I was taken to a view of NH5 near Srikakulam.
Then using Zoom out function and scrolling around, i was able to reach Hyderabad.
So is this map that I see emerge from my Satnav SD card in the Garmin unit? I need to explore more to get familiar.
Thanks a ton for your patient guidance.
Old 13th April 2011, 14:11   #1896
Thanked: 370 Times
Yaa its the same map. Now you should be able to plan route and add your own trackpoints etc. These can exported to device as well.
Old 14th April 2011, 13:18   #1897
s3va's Avatar
has anyone used Polestar Navigator with Navteq loaded on it ? If Yes, please share your feedback. Thanks
s3va is offline   Reply With Quote
Old 15th April 2011, 14:39   #1898
Any one facing battery problem with MapMyIndia Vx240. I got the unit in July last year. I am facing problems like
- erratic battery life (sometimes the unit works for 10 mins sometimes for 30 mins),
- charging problem (the unit never charges fully)
Any help will be appreciated.
vivekparmar is offline   Reply With Quote
Old 15th April 2011, 14:59   #1899
ranjith.rajaram's Avatar
Thanked: 9 Times
I planning to buy a smartphone. One of my main purpose would be navigation.
I planning to buy
1) Nokia E7 or
2) Samsung Galaxy S2
If Nokia I think I can download Navteq maps from ovi.maps and for samsung galaxy s2 it comes with Andriod 2.3 I guess it uses google maps.
1) Please confirm which is the best for navigation Samsung Galaxy S2 with google map or Nokia E7 with Navteq maps.
2) Can I also load MMI on both phones ?
ranjith.rajaram is offline   Reply With Quote
Old 15th April 2011, 15:29   #1900
Thanked: 370 Times
Go with Galaxy S2. More navigation options are available on Android (as compared to E7).
S2 uses google maps, but you can install Mapmyindia for 2k
Old 15th April 2011, 15:46   #1901
Thanked: 9 Times
Does this mean I can't install MMI on a symbian ?
Thanks for the response, even I love the galaxy s2 (4.3" inch screen).
Old 15th April 2011, 15:52   #1902
Newpunter's Avatar
Thanked: 63 Times
Android has more navigation options like Ndrive, Sygic, etc with others joining in too. Sygic with MMI is available for Symbian too but not sure how long Symbian will be supported by Nokia. Galaxy S2 is a way better phone than the E7 though.
Newpunter is offline   Reply With Quote
Old 15th April 2011, 16:03   #1903
Thanked: 370 Times
For now, you can install it on Symbian. But that version is not well supported.
Old 15th April 2011, 16:12   #1904
Thanked: 9 Times
Great Thanks Newpunter & NetfreakBombay . Sounds like Android has won the battle. I will wait for galaxy s2 launch till then. My research tells me it might be launced by May end in India.
Old 15th April 2011, 16:21   #1905
f1fan's Avatar
Thanked: 42 Times
Netfreakbombay: Buddy, can you help in converting google maps to format accessible by garmin?
I have tried tools like gpsbabel and gps2kml but I am still not able to convert any kml to .gpx formats. The tools do the job but when I open the converted .gpx files in mapsource I cant see anything.
Any pointers in fixing this issue would be very helpful.
f1fan
f1fan is offline   Reply With Quote
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
