Old 20th November 2013, 09:45   #3061
BeingCynical's Avatar
Thanked: 411 Times
Default Re: Which GPS Navigator to buy?
Originally Posted by dushmish View Post
Hey BeingCynical!
I have been using MapMyIndia for over 4 years and can vouch for the build quality and maps. It has never let me down.
But does any MapMyIndia navigator give the Junction View/ Lane suggestion as Tomtom or Garmin do?
Sorry for this bloop of a question, but I am not aware of any.
BeingCynical is offline   Reply With Quote
Old 20th November 2013, 11:18   #3062
saket77's Avatar
Thanked: 4,598 Times
Have been using Map My India for about close to one year. Have done some outstation trips and I can tell you that it is fairly accurate. Most roads are marked fine. The only drawback is the build quality. It feels like a cheap Chinese phone when held in hand. Also the touch-screen is not as responsive as one would have liked, esp. while dragging the maps. These two points are simply unacceptable when the device costs about 12K! For 12K, one can get a good quality Andriod phone or tablet which is much better in terms of build quality...and has in-built GPS too. The only issue would be that the Google Maps need 3G or egde connection which may not be available in remote areas where the GPS can be a life saver.
Battery back up is not that great, but when in the car, it is seldom a worry. Have no problems regarding locking up with GPS satellites.
saket77 is offline   Reply With Quote
Old 20th November 2013, 11:24   #3063
TaureanBull's Avatar
Thanked: 311 Times
Originally Posted by smartindboy View Post
why not go for a smartphone under 10K, it could serve as a backup phone. You could use offline maps like Sygic (Android) or Nokia HERE.
Can you elaborate on that please? I have samsung galxy Tab 2. I guess Sygic is free at least for android.
Do you have personal experience on the use? I mean its performance vis-a-vis a proper Navigation device.
Does the voice direction system and saving waypoints and tracks work there?
TaureanBull is offline   Reply With Quote
Old 20th November 2013, 11:48   #3064
NetfreakBombay's Avatar
Thanked: 352 Times
Originally Posted by BeingCynical View Post
1. MapMyIndia
2. Garmin Nuvi Lm 50
3. Tomtom VIA 125/100
I will suggest Garmin LM50.
1. Well-made hardware and polished UI
2. Good coverage with Junction view
Have been using Garmin for 3 years now. Used MMI for sometime, but hardware was pathetic.
Old 20th November 2013, 12:23   #3065
Thanked: 411 Times
I am also thinking on the same lines. Tomtom also has a good hardware but its functionality is little questionable. I think, sticking to Garmin LM 50 would be good.
Old 20th November 2013, 12:42   #3066
Thanked: 22 Times
I have used Sygic as well as Google maps for my navigation purposes using my smartphone, and have not faced any problems.
I have not encountered any performance issues, but if the screen is on, then the phone may heat up. However, with AC on, this shouldn't be much of a problem. Also, you can switch off the display if there are no major turns and voice guidance still works. You may also use recording feature using apps like Auto box. Its just more versatile than a dedicated navigation device.
Since you already own an Android device, would suggest you to evaluate.
smartindboy is offline   Reply With Quote
Old 24th November 2013, 12:41   #3067
vu2pmc's Avatar
Thanked: 32 Times
Between the three mentioned below, I am inclined to recommend Garmin Product. However, mapmyindia map data for Garmin is way better than City Navigator India which Garmin devices comes with.
Having said that, I suggest you try Sygic India app, now available free on Play store, before you spent any money on a stand alone PND.
If you intent to use only for navigation, Sygic does a brilliant job. However, if you want to use your device for logging, mapping and track back options, then Garmin should be your choice.
Guys, I am in a fix. Though indecisions are not alien to me, this particular one is irritating.
I am planning to fix a GPS Navigator in my Safari since few long drives are coming up. Initially I zerored in on three options
1. MapMyIndia
The reviews of MapMyIndia and the build quality didn`t impressed me at all and subsequently I dropped MapMyIndia from my shorlist.
Now I am in a fix between Tomtom & Garmin and here I badly need some insight to both of these products. Anyone having some idea on the product I should go for, please do pitch in.
Thanking in advance and eagerly waiting for your advice/s
vu2pmc is offline   Reply With Quote
Old 25th November 2013, 09:34   #3068
Twiny's Avatar
Thanked: 47 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
I will be mostly buying a Garmin; as per recent posts LM 50 is most spoken. Would like to have a bigger screen; 7" or so.
Request post some Garmin models with good reviews you have with 7" screen.
Twiny is offline   Reply With Quote
Old 25th November 2013, 10:51   #3069
tsk1979's Avatar
Thanked: 15,684 Times
Garmin entry level units cannot save GPX files. Only few models are capable of that. As for trackback, again, not possible on entry level.
Old 25th November 2013, 11:52   #3070
Thanked: 352 Times
Does LM 50 have that limitation?
AFAIK, you can connect any Garmin unit to PC/Mac and can download tracks to BaseCamp. From BaseCamp, you can export to GPX.
If Garmin has removed this feature, this would be surprising since this works fine on ~100$ 255W taht I bought 4 years back.
Old 25th November 2013, 12:06   #3071
tsk1979's Avatar
Some garmins do date stamped trip logs. i.e. you can have multiple logs over various dates.
Does your 255 log have timestamps?
Some Garmin Nuvis do only one tracklog(latest trip)
Some do neither.
I am not sure what kind of tracklog Garmin does.
I always record tracklogs on my phone. If I am using sygic, I run oruxmaps or similar app on the background and it keeps recording logs.
Old 25th November 2013, 12:20   #3072
Thanked: 352 Times
Yes, it retains tracks with timestamp for each point. Once imported to PC, BaseCamp brakes that to individual trips.
Old 25th November 2013, 12:24   #3073
tsk1979's Avatar
If you make multiple trips over days, does it keep all the tracklogs?
Old 25th November 2013, 14:45   #3074
Thanked: 352 Times
Yes, and these are archived on MapSource/ BaseCamp one you connect the device to PC. On device itself, these are deleted after some time (might be based on size of tracks).
You can also turn on an option on device so that it highlights tracks. This can be used as a "breadcrumb" for navigation.
Old 25th November 2013, 15:18   #3075
tsk1979's Avatar
See if the software is non transparently deleting tracks, then its not a trackker. What if you are on a 25 day cross country trip with no laptop. Will it save 25 days of tracks?
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
